11-27-2018, 11:55 AM | #1 |
272
Rep 668
Issues with trunk foot sensor?
Anyone else having issues using the foot sensor to open the trunk? It's pretty rare that my hands are full enough that I need to use it, but whenever I do, it seems like I have to wave my foot back and forth like 12 times to get it to work. And I always make sure my key is in the pocket of my pants closest to the trunk.
11-27-2018, 12:00 PM | #2 |
37
Rep 48
Here's your problem... it's not a wave (left to right) that triggers it. It's a kicking motion forward and back quickly that triggers it. Give that a try.
11-27-2018, 12:01 PM | #3 |
94
Rep 249
I haven't had an issue. Just make sure to quickly put your foot under and then back out. It should be one motion. No waving under the trunk.
Speaking of the trunk, I do have a problem with the lock button in the trunk sometimes. On occasion when I press it, the trunk doesn't close and lock. I'm not sure if there is a proximity sensor that prevents it or something else. Seems random when it works and doesn't work. |
11-27-2018, 12:02 PM | #4 |
34
Rep 55
It seems a bit hokey for sure. When the Genius demoed it to me, she actually bent her knee, lifting her foot off the ground and did a distinct kick under the bumper. It's almost as if it's an animated slo-mo kicking action rather that just waving your foot under the bumper.
2018 M5
2017 430i Convertible 2016 GMC Yukon Denali XL |
11-27-2018, 12:26 PM | #7 | |
272
Rep 668
11-27-2018, 12:34 PM | #9 |
420
Rep 862
There are two sensors that trigger the trunk opening: One senses your shin close to the bumper, the other your foot as it moves under the bumper and back. Both have to trigger properly for it to work. The trick is to quickly make a kick motion near the center of the trunk, starting with your foot off the ground and your shin close to the body.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
11-27-2018, 06:23 PM | #11 | |
73
Rep 87
11-27-2018, 08:02 PM | #12 | ||
420
Rep 862
11-27-2018, 09:41 PM | #14 |
50
Rep 128
Test it to find the orientation point relative to the license plate. Side to side positioning is as key as the perfect karate kid kick!
11-27-2018, 11:38 PM | #15 |
272
Rep 668
11-28-2018, 12:18 AM | #16 |
420
Rep 862
My 550 has a park button but if you just turn the car off it will put itself into park automatically anyway. I imagine the F90 does the same?
11-28-2018, 01:19 AM | #17 | |
272
Rep 668
Such a stupid feature because no valet understood it. |
11-28-2018, 10:47 PM | #18 | |
Rep 7
11-28-2018, 10:55 PM | #19 |
420
Rep 862
My 550 will just put itself into park if you turn the car off. It will even return the shift lever to the center if you have pushed it left into sport mode.
09-27-2019, 06:39 PM | #21 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
For the past several days I couldn’t get the “kick to open” the trunk and on occasion the handle button wasn’t working either. I open/close the trunk twice daily to retrieve and store and my car cover (my garage is a storage facility and is controlled by the local Warden [wife]) so our cars stay outside in the harsh FL environment. Anyway, I kept thinking that when it was last in the shop for the 1200 mile break-in service they might have changed something. But they didn’t seem to make any sense.
What I think was causing my issue was my iPhone XS Max. I have been using it to stream the radio and I keep my keys in the same pocket the iPhone. Well, tonight I went to cover my car and left the iPhone on the night stand to charge. Lo and behold, I was able to kick my trunk open as many times that I wanted. Bottom Line: If your kicking routine is perfect and it still doesn’t open, verify you’re not emanating strange signals from your pocket region! |
