BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > E90 Heater Core DIY
      01-17-2019, 02:36 PM   #23
fozzydj
DIYer, 335i N54 lover
70
Drives: N54 BMW 355i SE 2007, 148,000
Originally Posted by zigsman View Post
Okay, here is a comprehensive DIY for replacing the heater core on an E90. Mine does not have the iDrive, so, if you do, there will be a few additional and different steps. Hopefully you can work around it. If you need a larger photo (better quality), PM or email me with the task number and photo description, I'll get it sent over as soon as I can. If you get stuck somewhere along the way or have a question, feel free to PM or email me. Good luck!!
Mike
zigsman@aol.com
Hi Zigsman, thanks for the DIY.
My systemis blowing white dust out, which requires an evap change. Am I correct in thinking there is an Evaporator and a Heater core pretty much next to each other? Im thinking for the cost of a new one I may as well swap both out while Im there...
      03-08-2019, 02:06 AM   #24
niksss
10
Drives: 2016 BMW F10 535i
Hello guys ! Is this possible without removing the R134a A/C freon ? What does change if I don't remove it ?
      03-10-2019, 03:57 PM   #25
zigsman
36
Drives: 2009 M3 E92; 2006 330i E90
I did not change the evap out when I did the heater core, but normally both are located inside the A/C plenum. So, if you are going to be removing the plenum, it would not be a bad idea to change both...it'll save you from having to remove the dash again in the future to replace the other if you only replace one now.
      03-10-2019, 03:58 PM   #26
zigsman
36
No, you cannot do the job without recovering the A/C system and disconnecting the lines. The A/C lines connect directly into the A/C plenum, which has to be removed from the vehicle.
niksss10.00
      03-10-2019, 03:58 PM   #27
fozzydj
70
Thanks Zig
The issue only occurs for me when the A/C is on. The heating works fine and doesn't blow any dust
Fozzy
BMW 335i BLACK E92 SE 2007 158,000k
Bilstein B3 suspension, Catless downpipes, Turbonetics intercooler, MHD stage 1
      08-14-2019, 07:33 AM   #28
Roxxen
Australia
Drives: 2005 E90 320i N46
Big thanks zigsman for this extremely detailed DIY
      08-16-2019, 10:00 AM   #29
bimmerzeit
44
Drives: E28, E39, E90
Wow, pretty involved DIY. Hope I never have to do this!!
      10-31-2021, 09:46 PM   #30
Bmwater
Drives: BMW 325i E92
Thank you immensely Zigsman.
Could a blocked heater core be the reason for no heat coming from the driver side (UK model E92 325i)? The heat is perfect from the passenger side. Also the intensity of air blowing is less in the drivers side. I have seen something on the lines of 'blend door actuators'...I called BMW parts and mentioned this and he had no clue what it was. Is there a part number or a diagram to identify this part, if this is the reason for the problem?
      11-01-2021, 06:02 PM   #31
zigsman
36
Here is a link to the heater box (parts) for the E90:
https://www.realoem.com/bmw/enUS/sho...diagId=64_1454
In the diagram, you'll see the breakdown of the actuators (#4 & #5) that control the doors in the box. I believe there is only one blend door for the temperature, not two. That being the case, if the door were broken or the actuator were broken, the temperature would still be the same on both sides of the car, it would not be different. However, I could be wrong! Beings the AC unit is dual climate, meaning you can independently adjust the temperature on each side of the car, clearly there is a mechanism that allows for different temperatures on both sides at the same time. Without doing additional research on how the AC unit functions, I don't know exactly how the unit manages temperatures. Essentially, what I'm get at is this... It might be a blend door OR it might be a clogged heater core. It's important to test the blend doors BEFORE replacing the heater core. If you don't have the diagnostic software (ISTA, DIS, etc.) to independently test the blend doors, find someone that does. With ISTA, and several other software suites, you can independently activate blend doors to ensure they ware working properly. If you find that you have a bad blend door actuator, great! If, however, you find that all the actuators are functioning properly, then it is most likely a clogged heater core.
I had the same issue with my car that you are having with yours; it was warm on one side but cool on the other. My problem was a clogged heater core.
I hope this helps!
      01-16-2024, 04:44 AM   #32
tino_tino
Drives: BMW E90 N52 3.0
Is it easier to change the heater core on a right-hand-drive? Just remove lower dash and get the core out?
      03-31-2024, 03:35 AM   #33
GSB
Electronics Engineer
Drives: 2008 335i E92 Coupe (N54 6MT)
Just WOW. What an amazing DIY, but what an awful job. I hope I never have to do this!
If anyone has a heater core that has blocked and gone cold, but is NOT leaking, try a heater core flush before attempting this job...
DIY: Flushing the E9x Heater Core (Caution Required!)
      03-31-2024, 08:36 AM   #34
zigsman
36
That's a question I cannot answer. I have never worked on a right-hand drive.
      03-31-2024, 08:37 AM   #35
zigsman
36
Thanks! It was not a fun job and I knew it was a semi-common problem and figured a DIY could be helpful for many others.
      03-31-2024, 08:14 PM   #36
GSB
Absolutely. Doing a DIY with your level of detail is extremely hard work, time consuming, and often goes unappreciated. So, thank you!
