08-06-2021, 08:12 PM | #1 |
Joint Chiefs of Staff
5799
Rep 78,748
Eventuri BMW F90 M5 Carbon Fiber Intake System
Eventuri sets a new benchmark in the aftermarket intake industry. No more unverified and misleading performance gains, Eventuri are consistently developing bespoke intake solutions which bring genuine power and torque increases. Extensive prototyping, testing and rigorous validation methods ensure Eventuri's designs enhance the driving experience of your vehicle in the real world. With a construction quality that is second to none. Eventuri is raising the bar on every front.
The intake was tested on the road using a Vbox unit to record the acceleration from 60-130mph . Testing was carried out on the same stretch of road - again on the same day to keep variables minimum. Results show that with just the intake added - on stock software, the acceleration times from 60-130mph reduced by 0.22 seconds which is a significant improvement at such speeds. Acceleration results summary: 60-130mph with Stock intake = 8.48 seconds 60-130mph with Eventuri intake = 8.26 seconds The gains are from a combination of reasons: 1) The larger inlet tube volume alows the turbos to work with less drag. 2) The Venturi housings provide a smooth transition from the filter to the intake tube keeping airflow laminar. 3) The large front scoops force ambient air into the intakes keeping the IATs low. Each intake system consists of: 2 x Carbon Fiber Venturi Housings with Integrated Tubes 2 x Bespoke High Flow Generation 2 Filters 2 x Carbon Fiber Filter Shrouds 2 x Aluminium Inlet Cowls 2 x Carbon Fiber Air Scoops 2 x Laser Cut Heat Shields lined with Gold Heat Reflective Material 2 x Laser Cut Air Ramps integrated into the Heat Shields High Quality Silicon Couplers and OEM Spec Hose Clamps Free shipping within the US. If you are outside of the US, please contact me for the shipping quote. Please order on: www.jbspeed.com |
08-10-2021, 03:22 PM | #2 |
5799
Rep 78,748
