BMW M3 Forum (E90 E92)
      03-27-2009, 03:44 PM   #23
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Originally Posted by lucid View Post
Also, I've read mixed reports on pulling out the pin--if the pin even exists or not on the E9X M3. So, does it exist? And, is the -1.3 max negative camber people are reporting obtained with or without pulling out the pin?
When I had my car aligned at stock height, I asked to have the pin removed and when the service was done I had 1.3 degrees negative camber in front.
      03-27-2009, 05:10 PM   #24
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Thanks for the info. I guess that means you'll get the max 2 degrees with the Dinan camber plates only if you have the pin pulled.
      03-27-2009, 08:16 PM   #25
Radiation Joe
Veni Vidi Vici
2003 M3 SOLD  [0.00]
old 2002  [10.00]
I ran 2.25 negative on my e46 with no problems for several years. No abnormal wear. I ran -1.5 in the rear and still wore out the insides first. Got a little less than 10k miles out of the rears and around 20k out of the fronts. Pretty normal for these cars I think. This is why I'm running 265s on four corners now. So I can rotate the tires.
      03-27-2009, 09:25 PM   #26
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
After 2000+ posts, I finally made a sticky-worthy thread
      03-27-2009, 09:53 PM   #27
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Originally Posted by PencilGeek View Post
Now you're banned for being cocky about it.
      03-28-2009, 12:49 PM   #28
lucid
lucid's Avatar
I made over 5000 posts, but still do not have a sticky-worthy thread.
Anyway, good idea to stick this thread.
I'll post more info on the Dinan springs + camber plates after I get them installed. Currently scheduled for 4/14.
      07-01-2009, 04:43 AM   #29
Jimmer
Jimmer's Avatar
8
Drives: 2014 M235i with MPE
Any info on your Dinan Springs and camber plates? I'm getting my camber plates re-installed next week after they went on the first time but not set up properly and made the car really loose.
The dealer wants to know what set up I want and I have no idea what to tell them. Can I get some help? What camber are you running up front and rear for track and street? Does anything else change (toe, etc) or does everything else remain stock?
Thanks so much!
Certified High Performance Driving Instructor - BMW of North America, Porsche Club of America / Chief In-Vehicle Instructor - Fleet Safety International
Gone but not forgotten: 2008 E92 M3; Eisenmann Race Exhaust / Dinan 3.62 Limited Slip Differential / Dinan Software / Dinan High-Flow Intake / Dinan Camber Plates / Dinan Lowering Springs / Dinan Sway-Bars
      07-01-2009, 04:59 AM   #30
bobbyd1961
43
Drives: 2009 M3 sedan LeMans Blue
is that at 3200 mile ? my dealer didnt mention this service at all . i will check the manual
      07-12-2009, 10:42 PM   #31
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Here is a handy conversion chart for converting minutes to inches for those that like to check alignments at home. It looks like the 10' toe that BMW lists is approx 1/16" toe in.
      03-25-2010, 04:18 PM   #32
STALKER
169
Drives: 997.2 GT3, Golf R
Can we get members to post their alignment specs here as well, especially those that are lowered or with more aggressive non factory specs.
Thanks.
      05-11-2010, 09:09 AM   #33
kmac1980
36
Drives: '19 540xi
here are my alignment specs, before is after eibach pro-kit install, after is after alignment:
here are my alignment specs:
BEFORE:
LF -1.2deg camber, 0.0mm toe, 6.9deg caster
RF -1.7deg camber, 1.9mm toe, 6.5deg caster
LR -1.7deg camber, 4.3mm toe
RR -2.0deg camber, 4.3mm toe
AFTER:
LF -1.2deg camber, 0.6mm toe, 6.9deg caster
RF -1.7deg camber, 1.2mm toe, 6.5deg caster
LR -1.7deg camber, 1.2mm toe
RR -1.9deg camber, 1.2mm toe
Do these looks normal to those who know something about this?
thx
      06-21-2010, 01:00 AM   #34
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
Sorry I am new to this - and have 2 questions:
1- wouldn't you want to have the same amount of everything on both sides? or because of the driver's weight you would need less neg camber up front or something?
2- what are these pins everyone is referring to?
      06-21-2010, 01:15 PM   #35
JH M3
JH M3's Avatar
Drives: 2017 F80 M3 ZCP Azurite Black
There are specified tolerances for each setting, so they don't have to match exactly to be good. Also I'm assuming that the settings differ from L/R to take into account driver weight. For example, camber on the left side will increase with someone in the drivers seat. I think a good alignment shop will take this into account.
      08-09-2010, 02:39 AM   #36
ImStig
ImStig's Avatar
Drives: Acura TL 04
Can anyone post the ZCP alignment specs?
2004 Acura TL (Current)
2000 E46 323i (Sold 2007)
"Some say, he has a stripy top, just like mine" - James May
      12-26-2010, 02:01 PM   #37
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25117
Drives: '22 Chalk Gray Porsche C2S
Great thread! I'd like to see more alignment specs before/after lowering. What is the OEM M3 camber adjustment range? I want to make sure that I can stay within spec with H&R or GC springs.
      06-03-2011, 12:02 PM   #38
adams
Drives: 2011 M3 comp package
to echo prior questions:
1) what are those pins everyone is talking about
2) what is the factory comp package suspension/camber settings, and what is the max you can get of the factory suspension... and by factory I am talking about the competition package -10mm suspension
Thanks !
      06-24-2011, 04:00 PM   #39
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
It's not that I don't trust rzm3, it's that I don't trust BMW : ) Has anyone confirmed these specs again? Reason I ask is that the computer printout the dealer handed me showed a totally different range for the M3.
The TIS scan in the first post shows the following:
F Camber 0.9-1.3
R Camber 1.33-1.57
The dealer printout shows:
F Camber -0.8 to -1.5
R Camber -1.6 to -2.0
I think the rear camber on the above TIS is incorrect. Can anyone confirm? I think I just screwed up my alignment as a result.
TIA!
      01-26-2012, 08:41 AM   #40
alaskanrb
Drives: 2009 m3
nice
      01-26-2012, 10:49 PM   #41
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
F Camber 0.9-1.3
R Camber 1.33-1.57
TIA!
check your units the printout here is in degrees and minutes.
      01-26-2012, 11:05 PM   #42
Malek@MRF
BimmerPost Supporting Vendor
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
BMW recommends to load up the chassis with a specific amount of weight in specified spots with a full tank of fuel before aligned.
68kg on each of the front seats, 20kg luggage in trunk and 40kg of weight on the center of the rear seats.
If aligning with ONLY a driver in the car, then the alignment settings will not be the same without a driver inside the car when static. Alignments should be performed with a decent amount of fuel inside the car.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      02-01-2012, 12:40 AM   #43
BMW9
Drives: BMW M4 / Nissan GTR
....what about the comp pack? any difference in alignment settings?
      03-08-2012, 06:46 PM   #44
iAmCoolguY
Drives: 2008 E90 M3 Sedan
If I just want to do the OEM spec, can I just let any shops to perform the wheel alignment if I show them the OEM spec's print out or I should take the car to the shop who is specialize in after market suspension and wheel alignment field.
I heard some shops near my area has good rating for their wheel alignment work but the charge is high compares to firestone's life time wheel alignment. How much does everyone paid for your wheel alignment for E90-E93 here?
m3post
