06-17-2016, 06:42 PM | #23 | |
236
Rep 838
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
01-07-2018, 04:22 AM | #25 | |
355
Rep 719
had a 15mm on front and it would touch the inside of bumper at top. I think it safe to say 10mm in front and prob 12mm at rear but 10/10 is safe. BTW i was running Pilot 4s rubber. why would you want to run such big spacers on stock height it looks so odd! unless you trying to go for this look. |
01-07-2018, 07:31 AM | #27 |
355
Rep 719
are you on Michelin PSS or 4s
the 4s are known to run a bit wider than the OEM PSS good to know that there is no problem with 20" but I think a 265/35 19" is a smidgen taller than the 265/30 20" I am going to install my spacer today and test again with 10/10 and than I will test with 12/10. I will drop feedback back here once I have tested Last edited by whoop_ass; 01-07-2018 at 07:37 AM.. |
01-07-2018, 07:53 AM | #28 | |
Addicted to Speed.
714
Rep 2,375
2017 991.2s
2015 F15 35i 2017 Macan gts |
01-07-2018, 10:06 AM | #29 |
355
Rep 719
11-27-2021, 02:31 PM | #30 | |
30
Rep 119
I am getting rubbing on some turns especially with suspension compression on my stock ride height, base M3. Unsure what my alignment specs are, I have to dig up the sheet, but it was last aligned by a BMW dealership, likely within stock specs. Might try to swap the front and rear spacers to run 10/12, or just go down to 10 all around which was my original preference anyhow. |
11-27-2021, 02:57 PM | #31 |
606
Rep 646
I run 12 front and 10mm rear. That is perfect if you want your tires to not stick out from the fenders and blast your sides with stones and debrees to much.
11-27-2021, 07:35 PM | #32 |
17627
Rep 10,712
Drives: M4 CS. Former G82, x2 F82, F80
Here’s my setup, took a lot of trial and error as I ripped off my first front lip. We initially had the front much lower, but with the height now I haven’t scraped a single time and she’s still LOW. There is absolutely no rubbing on front or rear, I think we’re at the limits of my current setup. While I’d like the front to be a smidgen lower, I think it still came out great and I get asked all the time if bagged. Specs below:
KW V3 coilovers. 10mm front with 5mm rear spacers. PS4 265/30/19 front and 295/30/19 rear. Stock 437m wheels. |
04-17-2024, 12:03 PM | #33 | |
Rep 15
P.S. Sorry to revive an old thread im so on the shelf about what tyres to upsize too. |
04-17-2024, 12:05 PM | #34 |
Rep 15
04-17-2024, 01:54 PM | #35 | |
266
Rep 644
That’s my 2018 F82 on 10mm front and 12mm rear on stock 666 with PS4s And then the 763m with PSS 666 are 265 front 285 rear 763 m are 255 front and 285 rear |
