What did you do to your car today?
04-30-2024, 07:17 AM | #24377 |
221
Rep 364
Drives: 2007 BMW 328xi E92 6mt swap
04-30-2024, 08:08 AM | #24378 | |
2817
Rep 1,601
Already used their services and never had issues |
StradaRedlands5009.00 |
04-30-2024, 12:00 PM | #24379 |
1339
Rep 1,184
Virginized the donor CIC, been trying to change the VIN of the new one so that I can load the new FSC certificates. Of course Tool32 is not cooperating (loads to a blank screen after selecting CICR.prg), so I’ve wiped a spare HP laptop to see if it’s something with my Windows 7 install (and I remember now why I avoid Windows like the plague…)
Once I have a process that works, I’ll do a little write-up. |
StradaRedlands5009.00 johnnyorange58.50 |
04-30-2024, 12:11 PM | #24380 | |
2817
Rep 1,601
or even manual install. Can you explain why the VIN need to be changed? I did swap a lot of item, different VIN, and the car runs fine, I can flash it, and use INPA, ISTA, no issue. Yes on a full scan it report mismatch VINs, but no issues. |
04-30-2024, 12:37 PM | #24381 | |
1339
Rep 1,184
Tool32 loads the prg, but clicking it it returns an “invalid argument” error. |
04-30-2024, 05:20 PM | #24382 |
Great Teacher
1130
Rep 1,315
Drives: 06 e91 325ix
Little things. Had my computers out helping someone with a e39 correctly config their Kombi so I decided to also do a little coding on e91 Sunday, when I bought it had only bixenons for high beam and also for flash to pass, so FTP didn’t work with headlights off. Originally changed it to inner FTP, so they’d work with headlights off and later did the amber Hella bulbs so they were more visible in daylight… frankly sunlight is so bright out here in the cloudless desert you can’t tell if someone’s headlights are on/flashing to you or it is just the sun’s reflection in the housing.
So on Sunday I finally found out how to change it to be inners for flash to pass but have both inner and the bixenons for high beam which adds more light instead of just more height on hi beam. Also changed the Adaptive/auto “A” led to only be on when headlights are actually on, which I prefer.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
04-30-2024, 06:08 PM | #24383 |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
Neat idea on the hella bulbs Onizukachan. I'm going to copy you after I rebuild mine. Do you by chance have the part # you used?
Things I've done recently- Saturday: Got blue car back. Person who was using it didn't clean it once, trash and dirt everywhere. Oil was a quart low. I was appalled 😳. Washed it & did a "quick" interior detail for an hour. Sunday: went on an amazing mountain run. I had the whole road to myself, really got to put it through its paces (safely) Today: got sick of seeing the muffler from behind the car. Used BBQ flat black paint as a base and topped off with heat resistant satin black. Soo much better. Just needs exhaust tips
Common sense is a flower that does not bloom in everyone's garden
Cal122203.50 Onizukachan1130.00 StradaRedlands5009.00 oVeRdOsE.2816.50 Seattlesquash912.50 johnnyorange58.50 |
04-30-2024, 06:21 PM | #24384 |
1339
Rep 1,184
Finally got the CIC to match my VIN. Now I need to see why the old FSCs are still present…
Onizukachan1130.00 |
04-30-2024, 07:59 PM | #24385 | |
Great Teacher
1130
Rep 1,315
HELLA H7 YL Xtreme Yellow Bulb (12V 55W), 2 Pack For about $24. Head up, they are either super easy or a Big Bitch to install, you can use a mirror and long pick tools (not a Phillips, that was my mistake) but if you press the retainers too hard then you will wind up taking the bumper off to take the headlights out to be able to bend/reshape them back. One side only took me 10-15 minutes, the other 8+ hours because of pushing ot hard and tweaking the retainer tab and having take it all off, and rebend it back into position. FYI, You do them from the engine bay, not fender liners,unlike all the videos say. I also did the high temp black on rear of sons r53 JCW’s mufflers because those big SS cans hang over an inch below the bumper. It actually worked fine, no peeling or anything
colorado.e9x3109.00 |
04-30-2024, 08:08 PM | #24386 |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
Onizukachan 'precciate it. And tell me about it. I tried stuffing S V.4s in my 330's set of headlights. Worst idea ever. Many hours of dremeling, cutting, and placing the converter box later, I got it. Never again.
Nice! Curious to see if mine peels. Prep was lazy. Not concerned though, its not a glamour piece, I'll touch up when I have to lol
04-30-2024, 11:01 PM | #24387 |
Rep 22
I gave my E91 some new e90 sport seats from a car that was being parted out. I really like these better than the stock flat buckets.
8
Onizukachan1130.00 colorado.e9x3109.00 StradaRedlands5009.00 tcphoto3555.00 eljay1452.50 Runnin'Rich99.00 johnnyorange58.50 Seattlesquash912.50 |
05-01-2024, 12:08 AM | #24388 |
Great Teacher
1130
Rep 1,315
Once you get them dialed in to how you like em to fit they are sooo comfy. Takes a bit ot get everything Juuuuuuuuuust perfect…
If you ever road trip, set a second setting just slightly more vertical or reclined on back and bottom, just a little bit, and you can switch up positions every hour or so. I’ve done 800+ miles on a day like that and gotten out feeling relaxed and not tired or sore at all.
05-01-2024, 07:22 AM | #24389 |
221
Rep 364
BRG_N54310.00 StradaRedlands5009.00 |
05-01-2024, 07:29 AM | #24390 | |
1055
Rep 783
Drives: 2010 328ix E91, 2011 128i E82
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black |
05-01-2024, 12:53 PM | #24391 |
210
Rep 169
I flashed the hassmaschine / Bimmerlabs 330i NoMAF tune using my new Bimmergeeks cable!
05-01-2024, 04:29 PM | #24392 | |
2817
Rep 1,601
But the top seal look OEM and new. The owner told me he knows bmw. We'll see, anyway , planning doing 1000-2000km max/year with my e91 |
05-01-2024, 06:07 PM | #24393 | |
152
Rep 437
05-01-2024, 06:11 PM | #24394 |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
Every E90 I've worked on has had a condensation sensor code at some point. Do some preventative maintenance and have the windshield installer put a new one on. Much easier for everyone! The new part even comes with a built in guide template for placement
05-01-2024, 08:00 PM | #24395 | |
1339
Rep 1,184
Still having issues with loading the FSCs themselves. The script I have to virginize it doesn’t seem to be working. FSC Tools still shows stored FSCs (rejected but installed). I’m also not sure if I need to use the certificates provided in the repair kit from BMW in addition to the FSCs themselves. Tried both ways but I get an error storing the codes. Last edited by Hoody007; 05-01-2024 at 08:08 PM.. |
05-01-2024, 11:03 PM | #24396 | ||
Rep 22
I'm still fiddling with the position every time I get in, we'll see how long it takes to get just perfect, but they're already better than the flat ones that came out. |
05-02-2024, 01:38 PM | #24397 |
59
Rep 48
Drives: 2009 lci e91
Oil Change + Windshield Washer Pump/Filter
Small update on the e91 currently at 164449 -
Did an oil change with LM 5w30 and took an oil sample that I shipped off to Blackstone for review Replaced the front windshield washer pump and filter that had failed after almost 14 years. New part number on the pump had tabs I needed to grind off in order to make the connection fit. bottom line this thing is kind of a hassle to get to and replace as it takes a couple hours to get everything out of the way, but once again I have no orange triangle and washer fluid doesn't drain to the ground anymore; so I've got that going for me, which is nice. a small update, but ill take it - Lastly, next moves are: - diff fluid replacement (all records from purchase suggest original fluid!) - brake fluid replacement (along with rotors / pads / etc) - install of the m3 arms in the rear to match the m3 bits which I have installed in the front |
05-02-2024, 05:16 PM | #24398 |
2817
Rep 1,601
Report on my issue few pages back : ABS, DSC, AWD , error.
- did turn the steering all the way around : did nothing - check live data for 4 wheels speed sensor : all good. - check steering wheel angle sensor live data : all good - reset oil change in the transfer case : did nothing. ........... - reset error code via MHD : all fixed . so clearing code fix cars ? |
