04-28-2019, 05:44 PM | #1 |
Rep 10
Kidney Grill and side vents
Hey everyone,
I was hoping you could help with a small dilemma I have. My M5 is coming next week in Singapore Grey. However one thing has been bugging me is the front grill. As I’ve not got the comp version the grill is black but with a chrome trim. I’m in two minds as to ask the dealer to change the grill and side vents to the all black versions. What are you thoughts? (Just to note I’m not trying to make it look like a competition version, I just think it might look better. It would be great to get your thoughts) |
04-28-2019, 05:55 PM | #2 |
266
Rep 770
The dealer will likely have to order those parts for you if you want them to install factory parts.
Or you can order these things from IND and have your dealer install them prior to delivery, or install them yourself which is relatively easy depending on your basic technical skill level. That latter would be a cheaper option unless you go with carbon parts. https://ind-distribution.com/collections/m5-f90 Also, you can add black grille and side vents as port-installed options, though I’m not sure if it might be too late at this point if your car is arriving next week - is it arriving at the dealer or at destination port next week?
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 Last edited by masmole; 04-28-2019 at 06:09 PM.. |
04-28-2019, 06:28 PM | #3 | |
199
Rep 292
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp |
04-28-2019, 10:00 PM | #5 | |
75
Rep 76
04-29-2019, 12:08 PM | #6 |
Soporificist
160
Rep 327
+1 to do it yourself. It helps to avoid scratches if you have a set of soft plastic trim removal tools. Available on Amazon. Four piece replacement took me 15 minutes.
2019 M5 Rhodonite Silver// 2016 M4- retired// 2011 750i- retired// 2004 740i- retired//
2001 740i- retired// 1998 M3- retired |
04-29-2019, 12:15 PM | #7 |
1691
Rep 2,699
Drives: 23 X5MC
I vote for black
04-29-2019, 12:35 PM | #8 |
4074
Rep 5,233
I have a SG M5C so it came from the factory with black pieces (front and sides). I would also suggest deleting the front and rear reflectors. IND can help you with all of these pieces as well as the soft tools. I installed the rear and front reflector deletes myself and it took about 30 min.
I also did this on two F10 M5's.
Himaia_M512.00 |
04-30-2019, 04:07 PM | #9 | |
51
Rep 31
Good luck with your choice, B B |
IND-Distribution9586.50 |
05-01-2019, 08:18 AM | #11 |
1716
Rep 1,909
Drives: 2023 M5C
Just get them installed from the dealer before you take delivery, that way it's one less thing to worry about doing later on. It will look good.
josec70 is right about the other extras from IND... They're a must IMO.
IG @windtendo_m5
05-02-2019, 04:52 PM | #12 | |
407
Rep 2,704
took me 30 seconds, i literally just pulled them by hand, no tools. Maybe I'm the hulk, |
05-02-2019, 07:07 PM | #13 | |
4425
Rep 4,109
