Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > E90 dash heater problem
      04-24-2024, 03:20 PM   #1
Walby
Walby's Avatar
United Kingdom
Drives: BMW E90 2008
Apologies is this isn’t the place, it’s my first post. I have a 2008 E90, when I put the heater on, it only blows hot air into the passenger side, the driver side remains cool. I’ve replaced the thermostat, the water pump and radiator, I’ve also flushed and replaced the coolant and had the air con re-gassed, I’m running out of ideas now, any help would be appreciated.
      04-24-2024, 04:13 PM   #2
Silver Streek
119
Drives: 325d E91
There is a part called the heater resistor, also known as the hedgehog due to the way it looks. When this goes bad it can give similar symptoms also makes the heater pulse sometimes. Have a Google, this could be the problem. It's an easy fix and fairly cheap too
      04-25-2024, 06:09 AM   #3
Walby
Walby's Avatar
United Kingdom
That’s very much appreciated, thank you. I will let you know how I get on.
      04-25-2024, 07:12 AM   #4
Silver Streek
119
Drives: 325d E91
Good luck, hope you get it sorted.
