Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > E91 cranking, not starting
      04-16-2024, 05:58 AM   #1
nshack31
Drives: x3 F25
Hi all, I have a 2010 E91 which had an engine light on for the EGR. I took it out and the plunger couldn't move due to carbon deposits, cleaned the whole thing up and fitted it again - only now I have problems with the engine cranking without starting.
BimmerLink is showing the attached codes
Any ideas? Thanks
      04-16-2024, 08:02 AM   #2
Silver Streek
119
Drives: 325d E91
Clear the codes and see if it starts.
      04-16-2024, 08:03 AM   #3
nshack31
Drives: x3 F25
Same sadly. Time for a new glow control unit?
      04-16-2024, 02:11 PM   #4
Silver Streek
119
Drives: 325d E91
Glow plug control unit wont stop it starting even on a cold morning. The first fault code is to do with the injectors which could be your problem. Did you disturb any of the connections ect when you were sorting the EGR?
      04-16-2024, 02:17 PM   #5
nshack31
Drives: x3 F25
Not that I'm aware although the injector connectors are at the top I think? So I wouldnt have thought they'd have been disturbed. I do have new injector seals which I'm wondering whether to fit
      04-17-2024, 01:55 AM   #6
Silver Streek
119
Drives: 325d E91
You've got a code for throttle valve actuator, did you do anything to the throttle body when you took the EGR off? Maybe unplugged it and forgot to plug back in or something?
      04-17-2024, 02:06 AM   #7
nshack31
Drives: x3 F25
After cleaning the egr the car ran fine for a period so I assume this is a new issue
      04-17-2024, 02:55 AM   #8
Silver Streek
119
Drives: 325d E91
Hmmm maybe get the car booked into a decent independent garage so they can go through it. Might be something simple.
