10-19-2016, 11:49 PM | #45 |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
It actually pulls more styling cues from the X6M than the F80 M3 IMO. Its just been slimmed down a bit but the design cues are very similar.
10-20-2016, 12:08 AM | #47 | |
Plenipotentiary
2614
Rep 3,046
There are some items that confirm speculation on some new and advanced equipment but anyone who knows what they are specifically won't be commenting with detail. |
10-20-2016, 12:11 AM | #48 |
513
Rep 985
I'm hearing all 4 tires will produce smoke...
But that it (X-drive) will be able to be turned off, so you have the "standard" RWD. The render looks great, and since the G30 looks like an evolution to the F10, so will the M5. That's not an bad thing, the G30 looks superb live!
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
10-20-2016, 12:24 AM | #49 | |
Plenipotentiary
2614
Rep 3,046
It's an AWD simply because it does turn all 4 sometimes but won't carry a thing like X Drive as a label. The RWD version (if both do come) looks to have a lowered engine torque figure. Last edited by lemetier; 10-20-2016 at 12:29 AM.. |
10-20-2016, 03:27 AM | #51 | |
1318
Rep 2,350
It would be good if that was the case with the engine/front axle mounting done more like the FF than the standard BMW through the engine sump configuration which does NOTHING for weight distribution. I'm really afraid the new M5 is going to feel like a numb and understeering Audi with torque steering due to the off centre front diff and the trend of a higher percentage of weight at the front, as per my the thread I made a few days ago. |
10-20-2016, 05:51 AM | #52 | |
1454
Rep 1,725
~ 24 M4 Comp
~ 24 X3 M40 ~ Prior BMW's - Too many to list here (27) |
10-20-2016, 06:38 AM | #53 |
1081
Rep 1,761
Drives: S2000, MacanS, M4CS
BMW did it to M2. looks aftermarket but it works on modern day BMWs.
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
10-20-2016, 06:54 AM | #54 | ||
Plenipotentiary
2614
Rep 3,046
I'm actually thinking about it in depth as to exactly what I'd expect as a consumer and professionally how I'd design the system. You managed to spend some time in the RS6 right? The weight distribution is barely perceptible on the BMW. XDrive with performance Drive is pretty good for a full time AWD. Weight reduction factors are more significant for F90 and suggested to be up to 200kg. In my opinion, the weight loss isn't as import as getting more power down. What is going to have a significant impact is the noise level. G30 has extensive and very effective sound deadening and brings back double pane acoustic glass to normal models. The F90 needs to have more NVH noise than F10. Last edited by lemetier; 10-20-2016 at 02:35 PM.. |
Labrada_Exoticz125.50 freezey159.50 |
10-20-2016, 10:55 AM | #56 |
651
Rep 4,323
Can't wait for the CP!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
10-20-2016, 02:46 PM | #58 | ||
172
Rep 378
Well, blanks at least....... |
10-20-2016, 03:35 PM | #59 |
102
Rep 299
Drives: F80 MG/MT/ZCP & 2023 X7
Just needs the mirrors!
10-21-2016, 07:09 AM | #60 |
Fitness Gene
1114
Rep 2,413
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
how about cf roof and M mirrors?
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
10-21-2016, 01:26 PM | #61 | |
1318
Rep 2,350
The RS6 has a large amount of torque steer due to how far offset the front diff is to the driver (In New Zealand, in the USA it is offset to the passenger) and on small windy roads it gives me no confidence at all when I'm trying to place the car or corner accurately. Of course it also feels very front heavy. I hope that the BMW system of having the front diff set to the side of the engine sump at about the location of cylinders 3 and 4 in a V8 will reduce these issues due to it being closer to the centreline of the car and not hanging the engine out over the front wheels in its entirety. One option which I think is doable is to run the shaft out of the transfer case to the very front of the engine, and have the crown wheel casing kind of like a large hollow shaft to locate the front diff centre right in the centreline of the car, just in front of the engine. This also allows for a lower engine height and less complexity than two gearboxes and won't add much weight at all to the car compared to what BMW are doing at the moment. It does still impeed on the cabin room or create an extra long nose to the car with a long wheelbase, probably 200-250mm longer than now for the same interior room. Mitsubishi used something simlar in the Evo and VR-4 with the centre diff in the gearbox where you think the front diff would be located, then two hollow shafts sending power for both front and rear wheels to the centre of the car, the outer was connected to the rear prop shaft and the inner was connected to the front diff, the shaft coming out for the passenger side (again in NZ) went back through these hollow shafts. This meant no torque steer at all, however doing agressive launches would bend and eventully snap the hollow shafts. But those systems sent more power to the front and the hollow shafts needed to be quite thin as there were two of them, I'm suggesting with the system above it could effectively be the entire crown wheel of the front diff is simply offset with this hollow shaft, which would allow it to be thick and the larger diameter would also make it stronger. I don't see that this will happen though, it is too much to change for just one car in the same chassis as other volume cars. |
10-21-2016, 04:07 PM | #62 |
1033
Rep 1,997
looks like a great start. I hope it handles decently well (for a large car), if so, I want one!!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
10-22-2016, 11:39 AM | #63 |
krrrraaauuuuut
180
Rep 524
Can I ask a noob-ish question? Wouldn't the new M5 be based on the G30? I'm not totally up to speed on all chassis designations and news since the E60 and now F10.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art (Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx |
10-23-2016, 02:32 AM | #64 | |
Plenipotentiary
2614
Rep 3,046
It's only active with the manettino in comfort or winter mode, and with the main DCT in gears 1-4. The front Transmission has 2 gears (Low covers 1-2 and High 3-4). To make it even more complicated, they don't have the same ratios. The clutches are in constant slip. When it's slippery, that 4-5 change up can be "not normal" since its suddenly a RWD. |
10-23-2016, 03:17 AM | #65 | |
1722
Rep 5,110
Audi traditionally use a different front wheel drive and AWD layout than other manufacturers. Audi mounts the engine in a "North-South" direction, just like on a traditional RWD car (just like on a BMW 1, 3, 4, 5, 6 and 7-series) while the traditional FWD engine layout is a "East-West" layout. Also called a transverse layout instead of the longitudinal layout of a RWD car. The Audi layout means that the engine is mounted in front of the gearbox and the driveshafts to the front wheels comes out on either side of the gearbox. This is also why Audis are so front heavy, the engine literally hangs out in front of the front axle centerline (while BMW tries to have as much as possible of the engine behind the front axle centerline). Audi do have a diff to one side on their modern transmissions (in order to get the engine as far back as possible compared to the older layout) but is clever enough to mirror the protrusion from the case, caused by the diff, on the opposite side. This means that the driveshafts on a RS6 (or any other Audi with this layout such as any A4, A5, A6 based car) are equal length and aren't the reason behind torque steer. Any car with drive on the front wheels is susceptible to torque steer as long as you have some power going to the front wheels. Also, on the traditional East-West (transverse) FWD cars it has been a long tome since at least higher powered cars doesn't have equal length drive shafts. What they do is to have a intermediate shaft along the engine block going to the wheel that is farthest from the diff. The intermediate shaft basically serves as an extension of the diff flange on that side, and since it's solidly attached via bearings to the engine, the flange at the end of it really is just an extension of the flange at the diff. This means that both front wheels have equal length drive shafts because they have moved the mounting flange for the drive shaft to the same position on both sides. https://en.wikipedia.org/wiki/Torque_steering Audi RS4 engine layout: Shows the architecture of a typical Audi transmission which allows for equal length drive shafts (notice there is an extension on the casings right hand side to mirror the distance created by the diff on the left hand side): RS5 showing how the drive shafts are equal length: Old Audi design with diff centrally mounted in the transmission but which also means the engine is hanging even further out in front of the axle centerline. This is a "cleaner" design than the modern Audi transmissions but is horrible for weight distribution...: Traditional FWD with East-West layout showing unequal and equal length drive shafts: Last edited by Boss330; 10-23-2016 at 03:27 AM.. |
10-23-2016, 01:55 PM | #66 |
1318
Rep 2,350
I'm aware of all of this, it was the A5 and 2008 A4 I think that changed the location of the front diff iirc.
I understand that there is the equal length setup now with the fixed intermediate shaft running through the middle of the gearbox, but that still means that from the diff, one side just has the weight of a shaft and the other side has a both that weight as well as the weight of the intermediate shaft. Perhaps I shouldn't have worded my post quite that way, but in my mind the front diff isn't in the centre line, so there is still an effective difference in inertia between left and right. It is 100% noticable in the lower gears and makes for a crap driving experience. As per my sig I have a C63 as my daily driver and the owner of the company I work for has had a number of quick Audis including the previous 3.0 Supercharged S4 and two of the current gen RS6, one prefacelift and one facelift. I've driven all of the cars quite a bit and I really enjoyed the DSG in the S4 as well as the lighter weight. The steering was a bit weird in regards to weight and consistent feel, but perhaps the 440nm wasn't enough to really show off the torque steer. The first time I drove the RS6 however I remember when I floored it in 2nd gear at about 60kmh on the Auckland Harbour Bridge and it pulled the car noticeably to the left, then when I lifted off the throttle the car jumped back across to the right. It probably feels a lot more than it actually is, but it makes for hard precise driving on the narrow country roads that we have over here. As soon as I experienced this again on a tight road where you don't get above 100kmh at all and still manage to use 40l/100km (6mpg) I thought to myself no, I'm never having one of these, even if it is a free hand me down from the owner when my C63 needs to go back, I'd prefer my C63 thank you! I've driven an X5M and X6M on the BMW xdrive alpine experience but it wasn't clear on the snow if they had the same issue as all 4 wheels were spinning the entire time and depending on what previous tracks you were running over the cars could move massively all over the place (was so much fun) so I can't say if the BMW solution of having the front diff hanging off the side of the block will be an issue. What it will do however is give the M5 a very similar weight distribution to the current RS6/7 and I'm afraid it will feel quite nose heavy like the RS6 does. |
