BMW M5 F90 (2018+) General Forums F90 M5 General Forum    M5 CS on order
      09-12-2021, 10:13 AM   #1
girdwood
66
Drives: G80 M3 - on order
M5 CS on order
Received an allocation for an October build (fingers crossed) for my M5 CS.
Now that things are getting a bit more real, I'm researching the nuts & bolts and am curious about the carbon ceramic brakes. I've read statements that they will effectively last the lifespan of the car "under normal driving conditions" while others have stated you'll burn through both pads and rotors in "2-3 track days". Both statements seem hyperbolic.
Does anyone have real-world experience with ccb and lifespan with both normal driving conditions as well as a few track days?
      09-12-2021, 11:22 AM   #2
AngryInch
213
Drives: 2021 BMW M5 Comp
Get them, they are 50lbs lighter than steel rotors and I don’t think you get the brake dust like steel.
      09-12-2021, 05:46 PM   #3
Ex_Stig
Ex_Stig's Avatar
2609
Drives: '24 X7 M60i
2024 BMW X7 M60  [10.00]
Originally Posted by AngryInch View Post
Get them, they are 50lbs lighter than steel rotors and I don't think you get the brake dust like steel.
The CCBs are standard in the M5 CS.
Ex Stig
'25 M5 Touring (on the list, first slot)
'24 X7 M60i
'22 M5 CS - (sold)
      09-12-2021, 07:09 PM   #4
Dark-Knight
79
Drives: M5
^^^ correct, you have no choice if you want a CS, the reason people dont use them for tracking is the rotors are expensive and if you runoff into gravel and get the wheels full you could damage them because they are fragile, I think if you autocross and do an occ driving event theyre fine, if your a hard core track guy, buy a different car to fulfill that need like a GT3, The ceramic rotors are great no brake dust and much lighter, real race teams use them because money is no object for them.
      09-12-2021, 07:29 PM   #5
Day Laborer
Day Laborer's Avatar
Drives: M5 CS / iX 50i
  [0.00]
Plenty of track days (15+) in my M4GTS on the standard CCB rotors and pads.
Biggest advise I can give is replace the pads at 50% remaining pad (on track) as any less would increase the heat significantly, which can cause the fibers in the rotors to wear faster.
Ensure proper cool down laps + around the paddock too
Appreciate 2
Ex_Stig2609.00
      09-12-2021, 07:55 PM   #6
girdwood
66
Cheers. Admittedly a completely newb question, but how do you determine 50% wear on the pads?
      09-13-2021, 07:19 AM   #7
Day Laborer
  [0.00]
Pad thickness; measure when new; then 50% of that. I like to use this brake pad lining thickness gauge- you can find on Amazon
Appreciate 2
Ex_Stig2609.00
      09-13-2021, 12:48 PM   #8
shawnhayes
1839
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
The fellow above is probably right. I've used CCB on track, and while AWESOME, if you use the pads all the way to manufacturer spec, they overheat. That destroys those rotors. I destroyed two sets of carbon rotors on track by using the pads down to the wear indicators. A very expensive proposal.
If you don't use them on track, they will probably last forever. We were never able to document almost any weight reduction under street use.
Shawn
