BMW X5 and X6 Forum 2014-Current
      04-10-2024, 07:09 PM   #1
tfunk88
200
Drives: F15 X5 50i
Do updated PCV hoses still need to be replaced?
Anyone know if even if you have the updated design PCV hoses if they still need to be replaced every “X” thousand miles or time-wise?
My 2016 N63TU has the updated hoses. I’m guessing they are original, not sure when BMW updated from the “ribbed” hoses that cracked. Anyway, I was replacing the o-rings on the end of the single hose that goes into the top of the valve cover. I wanted to see if the hoses were clogged up and tried to blow through it. I couldn’t. I can’t imagine the flaps inside the two valve sections are supposed to give a lot of resistance since they are supposed to vent crankcase pressure. Perhaps mine need to be replaced?
      04-10-2024, 08:18 PM   #2
Chilled
Chilled's Avatar
Australia
365
Drives: F85 X5M
What were the updates? I replaced both sides on my 2017 and the new ones looked the same as the ones I took off.
      04-10-2024, 08:37 PM   #3
tfunk88
200
Drives: F15 X5 50i
On the N63TU the hoses were originally “accordion style” plastic, like the ones the S63 seems to still use. Now they are smooth rubber hoses.
      04-10-2024, 08:39 PM   #4
tfunk88
200
Drives: F15 X5 50i
Now they look like this
Chilled365.00
xbimmers
