2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      07-14-2014, 12:30 PM   #89
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
interesting... did you compare it with the cruise control speed....?
my BC_Digital is off about 1 mph from the cruise control speed which seems odd... maybe the Korrektur is to match BC_digital to cruise control speed... ?
      07-14-2014, 02:45 PM   #90
Shankska
Shankska's Avatar
Drives: 2019 BMW M2 Competition
2019 BMW M2 Comp  [0.00]
2016 BMW M2  [0.00]
2014 BMW M235i  [0.00]
My BC digital is 1 mph off from cruise as well. It is -1 MPH than what cruise said my speed was when I set it. Cruise said 75 mph bc said 74 mph
2019 F87 M2C, Long Beach Blue, Exec, 6MT
2016 F87 M2 - Sold 9/2018
2014 F22 M235i - Sold 5/2016.
      07-14-2014, 02:47 PM   #91
pikcachu
pikcachu's Avatar
1403
do you have the KORRECTUR setting active or inactive ?
      07-14-2014, 02:48 PM   #92
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
I dont believe so, unless it is default. What module is that located under? Is that the speed curvature fix?
      07-14-2014, 03:05 PM   #93
pikcachu
pikcachu's Avatar
1403
KOMBI 3000 BC_V_KORREKTUR aktiv nicht_aktiv
but i think that's only for head up display now that i think about it
      07-14-2014, 04:01 PM   #94
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
Ahh ok. Yeah I definitely did not code this on mine. Not sure if it's for hud or not though.
      07-14-2014, 10:38 PM   #95
Oyinko
40
Drives: M235i
Originally Posted by Oyinko View Post
My FEM Body doesn't match the spreadsheet.
For example, I used to activate the feature "close windows with FOB". In the spreadsheet, I must find the line 3053 KOMFORTSCHLIESSUNG_FB
But if you look at my sprint screen, the line 3053 doesn't match anymore.
Anyone has an idea?
      07-15-2014, 08:31 PM   #96
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
What are you expecting 3053 to say? The close with fob is located in the PW Master. I'm thinking you already know this because you have coded before but You have to click into the functions using the plus sign.
Anyone has an idea?
      07-15-2014, 08:52 PM   #97
pikcachu
pikcachu's Avatar
1403
Anyone has an idea?
expand the tree
      07-15-2014, 08:56 PM   #98
pikcachu
pikcachu's Avatar
1403
added to the sheet
Allow to import routes Yes HU_NBT 3000 NAVI_TRIP_IMPORT nitch_aktiv aktiv
now you can do stuff like
Trips need to be in BMW format .tar.gz and stored in a usb stick in BMWData\Navigation\Routes folder
Then go to Navigation Menu - My trips - Import from USB
      07-16-2014, 01:01 AM   #99
lichenlt
28
Drives: M235i
So you are saying that going at constant speed in a straight line with the high beam on, if there is oncoming traffic your left high beam moves to the center?
sunset here is not till around 1hr from now so it won't be dark till around 2hrs but I'll see if I can give it a try...
Also what speed where you testing?
Also I coded this which is for the anti-dazzle just to see what happens but because I don't have the HBA or the camera i don't think it will work but just in case here are the 3 settings in FEM_BODY that get changed if you remove 5AP (anti-dazzle decoding) if you had 5AC (high beam assist)
3073 C_HBA_ENA
3073 C_HBA_GRHB_ENA
3073 C_HBA_ADAPT_SHUT_ENA
I didn't remove 5AC from VO and only changed the above-mentioned three entries. I then did a test drive and only noticed high beam coming on and off, didn't see the "tunnel" effect.
Where do I remove 5AC?
      07-16-2014, 02:32 AM   #100
pikcachu
pikcachu's Avatar
1403
You don't have to remove 5AC (high beam assist) you need to remove 5AP(Decoding anti-gl. high beam assistant) and VO code FEM_BODY
but that's the same as adding those 3 entries...
Are you sure the the high beam wasn't coming on/off individually? The tunnel thing might be only if you have LED high beams
Do you have any KAFAS or FLA ecu on your list ?
You can try coding the variable light distribution by changing these also (maybe you need this too for the anti-dazzle to work):
Variable light distribution Yes FEM_BODY 3073 C_AFS_ENA nitch_aktiv aktiv
Variable light distribution Yes FEM_BODY 3073 LUT_FLC_FORWARDLIGHTING_Y 9C 9C B0 9C 9C 9C
      07-16-2014, 11:07 AM   #101
lichenlt
28
Drives: M235i
I'm pretty sure it wasn't just one high beam off, because I also looked at the instr. cluster and noticed the high beam symbol was gone when the high beams went off.
I did code both entries for the variable light distribution, which I presume is the same as removing 8S4? and I have the same low beam effect as shown in your video.
Have you tried to change the speed thresholds for the different patterns of low beam? 68mph for highway speed is too high considering the speed limit is only 60. I would like to make it 50mph.
Not sure what KAFAS and FLA are, but I think I have FLA.
      07-16-2014, 11:13 AM   #102
lichenlt
28
Drives: M235i
In addition, is there a place on the instr. cluster to show a bigger digital speed? It's so tiny on the BC.
      07-16-2014, 11:24 AM   #103
pikcachu
pikcachu's Avatar
1403
in the same way you have a FEM_BODY on the SVT list check if you have FLA
haven't tried changing the speed thresholds
this are the 3 settings for anti-dazzle
3073 C_HBA_ENA
3073 C_HBA_GRHB_ENA
One guy also got the FLA module changed
DFL_Vehicle: Verbaut
but not sure if you have it or not as i don't have it cause i don't have HBA
      07-16-2014, 11:26 AM   #104
pikcachu
pikcachu's Avatar
1403
don't think so
      07-16-2014, 11:31 AM   #105
lichenlt
28
Drives: M235i
3073 C_HBA_ENA
3073 C_HBA_GRHB_ENA
Great, thanks. I will check later today.
      07-16-2014, 02:46 PM   #106
lichenlt
28
Drives: M235i
I found another issue with AC after coding. I coded it to remember last AC setting but now when I turn off the engine the AC shuts off before I open the door.
For some reason the auxiliary ventilation is also grayed out after I used it once yesterday and turned it off subsequently. Weird.
      07-16-2014, 02:53 PM   #107
pikcachu
pikcachu's Avatar
1403
what's the auxiliary ventilation?
      07-16-2014, 02:57 PM   #108
lichenlt
28
Drives: M235i
Under Settings->Climate you'll see Auxiliary Ventlilation or Comfort ventilation (can't remember which one). If you turn it on, it will open the vents and use the fan to vent the car for 30min after you turn off the engine and lock the doors.
The other two options are timers for the same function to work at your designated time in the next 24hours.
      07-16-2014, 03:03 PM   #109
pikcachu
pikcachu's Avatar
1403
nice thanks
      07-16-2014, 03:09 PM   #110
lichenlt
28
Drives: M235i
Do you know what might be the problem with the AC shutting off along with the engine?
I should clarify, it's the entire climate control that I wanted to keep on after I turn off the engine and before exiting the car.
2addicts
