BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Asia > Hong Kong > CC ID 29 today, Bmw service or Other shop
      03-03-2012, 08:22 AM   #1
scflaw
208
Drives: M135I, Macan S, G26 i4M50
Hey guys, just got a cc id 29 when i put the car into DS and gave it some gas, now i did some research and it can be due to many things. One of which is the fuel pump? I never had a recall on the fuel pump and the car should be out of warranty now (08 335) do you guys recommend to bring it to bmw and check or goto an aftermarket shop? Could it be something simpler such as the ignition coils? code goes away once i drove slow again, which is weird... Thanks in advance guys !
      03-03-2012, 10:21 AM   #2
scflaw
208
Is bmw warranty in hong kong 3 years or is it just 1 or 2. i totally forgot....
      03-03-2012, 10:54 AM   #3
ct087ct087
8
Drives: E90
2 years parts but only 1 year labour. extendable up to 4 years.
      03-03-2012, 11:59 AM   #4
K3VMO
11
Drives: E93 AW 335i
Well I would advise taking it back to bmw... the pressure pump is a known problem on the 335i... Its a design flaw and invariably fails on all the models...
Therefore it could be argued they should be changing it irrespective of warranty... They were supposed to officially recall all models and refit with a new HPFP... I think you should just go talk to them...
      03-03-2012, 01:17 PM   #5
Harriz.c
Harriz.c's Avatar
Hong Kong
35
Drives: E92 M3 // F07 5GT // X5 G05 //
2012 BMW m3  [0.00]
Agreed. Just be a little harsher when talking lol. As they love to evade these problems ^^
      03-03-2012, 09:25 PM   #6
scflaw
208
i'm gonna see if i can replicate the problem again today. i hope its just somthing simple.... sigh update you guys later. Probably end up bringing it to BMW either way, i hate talking to SA.
      03-04-2012, 10:06 PM   #7
scflaw
208
Weird, tried to replicate the problem. its not coming back (thank god). I checked all the hoses if they were loose and tightened all the clamps to see if anything was loose. Engine doesn't have rough idle and doesn't have a long crank (1-2 second crank). Maybe its not the HPFP?
      03-05-2012, 09:57 AM   #8
scflaw
208
so i got the cobb today and couldn't get it to install but i did get it to read some codes off. apparently i have a p30FE code. Somthing about boost too high and the waste gate "clamping?" closing? Are my diverter valves or wastegates going south? watcha guys think?
      03-05-2012, 11:13 AM   #9
AlanYoro35i
Senior Troll
AlanYoro35i's Avatar
United Kingdom
225
Drives: Coming soon-718 Cayman S
best get it checked out before you install the Cobb. its always better to make sure the car is okay before you tune it.... hope you will enjoy the Stage 1 agressive map!! its truly pant shitting.. you will DLM when you feel the big difference lol
Gone:
N54 335i is the Legend!
N55 435i
Now: 718 Cayman GTS / F83 M4
      03-05-2012, 07:25 PM   #10
scflaw
208
haha thanks yoro! i was thinking of just putting it into sport. Aggresive will give me a "pant shitting" experience for sure, but in the form of tickets and court notices haha. The outcome of a heavy foot and low willpower!
      03-05-2012, 07:45 PM   #11
AlanYoro35i
Senior Troll
United Kingdom
225
Believe me bro, you don't want any other mode than aggressive
Gone:
N55 435i
      03-05-2012, 07:50 PM   #12
scflaw
208
haha, i'll definately try it out! Would you by any chance know what octane V power is?
      03-07-2012, 09:53 AM   #13
fhenix
Drives: E87
Did you ever resolved the CC id 29 problem?? what happened ??
      03-07-2012, 07:52 PM   #14
scflaw
208
i think it was ecu adapation of the different fuel grades. It never came back after multiple tries of recreating the problem. (knock on wood). Probably somthing to do with different fuel grades from caltex and shell.
      03-07-2012, 08:00 PM   #15
AlanYoro35i
Senior Troll
United Kingdom
225
If shell V-power in hk is the same as uk then it is 93-94 octane, best do you own research cuz im not sure if the hk one is 99 ron?! i only use normal unleaded when i drive in hk!
Gone:
N55 435i
      03-07-2012, 09:40 PM   #16
scflaw
208
I'm not sure myself, i tried doing some research but shell hong kong site doesn't list what ron V power is. Just kept repeating marketing shit. if it caused an overboost issue, would that mean that shell has a lower octane than caltex platinum? or would it be the other way around, haha. I would assume that it was lower since lower octane gas has higher combustability but less stable combustions and i'm guessing thats what happened.
      08-25-2012, 09:23 AM   #17
hez133
Drives: BMW e90 320i
CC-ID 29
Also had this issue. First there was no difference in driving, tech at the workshop reset the errors and everything was normal. About a month later same thing, but this time the car stayed in limp mode.
Ended up being the valve-tronic sensor that needed to be replaced. About $600. 3 months later and everything still ok
      08-26-2012, 10:46 PM   #18
scflaw
208
Mine turned out to be a bunch of problems. HPFP was going, Injectors were replaced with it, something wrong with the wastegate that was causing it to be caught stuck. Car runs like a champ but has a bit of a rough idle with cold start, hopefully nothing goes wrong.
