03-30-2023, 01:53 PM | #1 |
258
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
EDIABAS / Tool32 Help
After installing my rear springs, I have a rear seatbelt restraint fault code and airbag light on.
I know that this can be cleared using ISTA+ or tool32.exe, neither of which I have experience with. I just have an ENET cable with ESYS. For the last two days, I’ve been piecing together how to install Transmitter in to ESYS (failed - nothing happens when double clicking Transmitter), and also trying to get tool32 to work. I finally got tool32 to work, and reached the stage of attempting to clear ACSM5 faults. However, I get the following error when hitting F5 under STEUERN(ARG;VERRIEGELUNG_SG;0). Any help much appreciated. apiJob("ACSM5","steuern","ARG;VERRIEGELUNG_SG;0"," ") Satz : 0 OBJECT = acsm5 SAETZE = 1 JOBNAME = steuern VARIANTE = ACSM5 JOBSTATUS = UBATTCURRENT = -1 UBATTHISTORY = -1 IGNITIONCURRENT = -1 IGNITIONHISTORY = -1 Satz : 1 JOB_STATUS = ERROR_ECU_REQUEST_OUT_OF_RANGE _REQUEST = 4 Bytes 0000 : 2E D4 82 00 .Ô?. _RESPONSE = 3 Bytes 0000 : 7F 2E 31 1
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
03-30-2023, 02:52 PM | #2 |
1719
Rep 1,913
Drives: 2023 M5C
Sounds like the rear springs weren't installed properly. I recall seeing this being a common problem on the rears. It shouldn't have to be coded out. I don't have anything readily available to spout off, but I'd check the "Suspension" subforum as there's some helpful threads regarding this issue.
Edit: Found a few for you... https://f90.bimmerpost.com/forums/sh...ighlight=error https://f90.bimmerpost.com/forums/sh...ighlight=error https://f90.bimmerpost.com/forums/sh...ighlight=error
IG @windtendo_m5
Jambo1257.50 |
03-30-2023, 02:56 PM | #3 | |
258
Rep 235
04-04-2023, 03:51 PM | #4 |
258
Rep 235
An update, so that this thread doesn’t fall into a black hole.
The problem was solved using ISTA+.
