11-24-2019, 08:54 PM | #1 |
293
Rep 456
How to disable TC?
I posted this in the Whatsapp group a few nights ago. No one was able to come up with a solution. Is there any way to turn off DSC completely? Every other BMW I've had you just have to hold the DSC button for about 10 seconds and it goes off completely. With this car, after a while it just turns the DSC back on. I also tried Dyno Mode, it didn't work either.
The issue I'm having is that with DSC off, the car still cuts the power all the time. I feel like maybe what's happening is DSC keeps the car from spinning out, TC keeps the wheels from spinning too much. There doesn't appear to be a way to disable TC. Here's an example for anyone that doesn't believe me. I was flat out here, did not lift. It does the same in 1st, even if I try power breaking it, it wont let me spin the wheels. https://www.youtube.com/watch?v=mo7GzV2FyHM
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
11-25-2019, 03:02 PM | #2 |
1745
Rep 1,700
Random memory, but I believe that you can only disable TC in RWD mode, not AWD. Think of it as burn out mode. Could be that I am not remembering correctly.
11-25-2019, 03:14 PM | #3 |
293
Rep 456
I've been trying in RWD mode, it's still cutting the power.
2018 BMW M5
11-25-2019, 06:41 PM | #5 |
293
Rep 456
Just had it done. Oddly I only really noticed this after the break in service...
2018 BMW M5
11-25-2019, 07:44 PM | #6 |
2270
Rep 3,295
RWD mode is friggen dangerous. No traction control at all. It should have two settings...with and without traction control. If you want to go with rear wheel drive (since BMW always insisted AWD is for babies) then the bastards should allow you to have the traction control on in RWD mode. It is friggen dangerous.
Mike
11-25-2019, 09:10 PM | #7 | |
293
Rep 456
2018 BMW M5
11-26-2019, 12:04 AM | #8 |
288
Rep 371
Interesting, I’ve never had that behavior. I’ve tried DSC Off on an autoX track and it didn’t cut power and will let the car spin 360 with no interference.
I suspect BMW didn’t want to tune the TC for 2WD as the end result will just be it cutting power all the time. |
11-30-2019, 03:40 PM | #9 |
293
Rep 456
I'm surprised no one else has this issue. Again this morning, after installing a JB4, I did a launch, it started to spin and cut the power.
Video: Logs: You can see the ignition go to 0 and the throttle is cut way back. Why is my car the only one doing this? Don't most just spin and shift to 2nd right away?
2018 BMW M5
11-30-2019, 09:22 PM | #10 |
1745
Rep 1,700
You are still in 4wd mode. DSC is not traction control. DSC is designed to keep the car in the intended path based on steering input. Traction control eliminates wheel spin. Two different things.
Put the car in 2wd mode and it will spin to your heart's content. You cannot turn off TC in 4wd mode. |
12-01-2019, 11:32 AM | #11 | |
293
Rep 456
2018 BMW M5
12-01-2019, 03:13 PM | #12 |
1745
Rep 1,700
Understood, and obviously your car has an issue if this is happening, but you still posted a video and graphs in 4wd mode. These are useless because it is expected behavior.
Remove the JB4, then post the graphs in 2wd mode. Then you know if it is the modified chip affecting something or an actual BMW issue. |
12-01-2019, 03:57 PM | #13 |
155
Rep 317
DSC off means also no traction control even on 4WD and 4WD Sport . there is an issue with your car and get it checked . mine spins all 4 wheels when DSC is off and 4WD on wet and snowy roads .
12-01-2019, 07:16 PM | #14 | |
293
Rep 456
2018 BMW M5
12-02-2019, 03:24 PM | #15 | |
407
Rep 2,704
To the OP, I notice in the video you have auto H on, turn off that auto emergency brake bs off, maybe that is causing it. and make sure all tc is off hold the tc button for like 5 seconds. Edit - also check your connections, ignition timing should not drop down like that. |
