07-29-2015, 07:34 PM | #23 | |
59
Rep 741
Drives: E87 130i
Thanks again to those who have contributed. |
07-29-2015, 08:45 PM | #24 | |
130
Rep 351
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
07-29-2015, 09:34 PM | #25 |
29
Rep 363
Pad: EBC Yellow/GD Rotors
Fluid: SRF Suggested use: Hybrid Actual use: 90% street 10% track Dust: Same as OE Rating for actual use: A little noisy on the street especially when the transfer layer wears off. Decent cold performance. Good on the track for me(intermediate student) I've run them at NJMP and Summit Point Main. I never had any fade but I run PSS so they gave up before the pads did. I am on stock power. No signs of dust boot problems or piston issues yet. |
08-03-2015, 09:25 AM | #26 |
23
Rep 50
Pad: PFC08 (front & rear)
Suggested use: Track only Actual use: Street, track(HPDE) Dust: A shit ton Rating for actual use: Recommended w/ caveat. With Ti shields and F30 backing plates and stock wheels they held up pretty well for 20 minute sessions on a medium speed track. Only minor fading. On a higher speed track with wider front wheels I started to experience fade again. This is a function of cooling rather than the pads themselves though, I believe. They do rather well on the street, but are VERY noisy and VERY dusty. |
08-04-2015, 04:15 AM | #27 |
113
Rep 614
Drives: BMW 120d e82 M Sportpaket
Pad: Endless MX72
Suggested use: street and trackdays Rotors: oem BMW M135i rotors Fluid: Motul RBF600 Actual use: street and track Dust: a bit more than OEM Rating for actual use: very good pads, they can perform on the street with spirited drive and on the track (that's their prefered place) On the track, they stop with a lot of power your car, that's quite incredible. Notes: be carefull when they are cold, the car don't stop immediately ... A bit weird the very first time. Mounted on F2x brakes on my E82 and love them ! Initial bite on the street: like OEM Initial bite on the track: very good, far way better than OEM Cons: the price ...
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
08-04-2015, 01:51 PM | #28 | |
223
Rep 542
08-16-2015, 06:53 PM | #29 |
23
Rep 50
08-20-2015, 02:55 PM | #30 |
89
Rep 527
08-20-2015, 10:05 PM | #31 |
32
Rep 209
I found the DS2500 to be too loud on the street and lack the cold bite for a daily driver. Doable, sure, but to the point that you have to warn someone else that may be driving your car.
Sounds crazy, but I just put on some Centric PosiQiuet Semi Metallic for the street. Very good and super cheap. Will help me preserve the track pads. Just bought a set for the wife's e90 (street only). Looking forward to trying PFCs for track after I wear out the 2500s. |
09-13-2015, 05:32 AM | #32 |
59
Rep 741
Drives: E87 130i
Updated initial post with the reviews here. Where pads are listed multiple times they have been grouped/linked.
I'm a fan of my P.Mu HC+ Is this worth stickying? |
09-16-2015, 03:17 PM | #33 |
130
Rep 351
Track Review - Mid Ohio Full Course (no chicane)
Pad: PFC08 (front & rear) Fluid: Motul RBF 600 Suggested use: Track only Actual use: Street, track(HPDE) Dust: I'd say middle of the road Rating for actual use: Excellent Notes: First time using these pads but based on the recommendations here it was money well spent. As a note I didn't have shims so I was getting pad clunk when going in reverse/forward while braking. Not a big deal, I'll get some shims to fix it. Break-in/bedding procedure was about 10-15 hard stops at various speeds starting at 40mph up to 70mph. I did about 5 stops at a time with a cool down. Each time the pedal got firmer and brakes were working better. By the end they were smoking/burning off the grime and I had really good feel. As I figured, they got even better after a full cool down. If anyone is interested I'm using Centric premium high-carbon rotors (Stop Tech blanks) and they held up perfect. I put about 200+ miles on them at the track with little issues. They took about 2 full laps to get to temp (quite noisy before full temp) but after that they were very consistent. Overall feel was quite good and easy to modulate. Pads once warm provided medium/high bite with minimal pedal effort in the short braking areas with excellent consistency lap after lap. Hard braking zones were almost as consistent with a couple fading issues. Back straight I was seeing between 135-140mph coming into a hard braking zone and I noticed a little fade over the next couple turns but quickly went away. This was only after about 20 minutes of hard lapping that I started to see fade, but as I noted it quickly went away. Pads and rotors showed minimal wearing, better than expected. I'm sure I have several more events before these are ready to replace. I give these pads a high rating because they were not only excellent on track but also the 500 miles to and from. They're quite quiet for a dedicated track pad and really didn't make a lot of noise on the trip. I am switching out these pads and rotors for my stock~ish setup (OEM rotors and Stop Tech Pads) to save them for track only days. Unfortunately my lapping season is done for this year but it was a great end to the season. Reviewer: E82MSport
dcaron9999157.00 lab_rat394.50 |
09-16-2015, 04:43 PM | #34 |
California-bound
385
Rep 1,480
I've got a few contributions to add.
Pad: EBC Yellowstuff Suggested use: Street and Track Actual use: 90% street / 10% track Dust: Comparable to OEM, but lighter in color Rating for actual use: Excellent dual purpose pad, excellent step up from OEM Notes: A bit harder on rotors than most street pads, but does well holding up at the track if you're not super fast/or running too much tire. It's a good match for street tire levels of stick. Used these pads for two track days on 225/255 staggered Dunlop Star Specs, and it was a good balance between brake strength and tire grip. As noted before, now that I've progressed in pace, I feel like I could overwhelm these pads when really pushing, but nice and safe for the beginner to intermediate HPDE driver. Pretty quiet as well. Has decent "cold" manners, one or two slow speed stops (i.e. leaving the neighborhood) is enough to get the pad in it's happy spot. Reviewer: Ginger_Extract
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 Last edited by Ginger_Extract; 09-16-2015 at 05:05 PM.. |
09-16-2015, 05:04 PM | #35 |
California-bound
385
Rep 1,480
Pad: Hawk DTC70 (F), DTC60 (R)
Suggested use: Track, limited street use Actual use: 80% track, 20% street Dust: Terrible, a lot of it, requires strong scrubbing/wheel cleaner to clean wheels. Dust will also cover fenders, but cleans off easily enough. Rating for actual use: Excellent on track, will not fade. Suck on the street and at autocross. Notes: Right up front, the DTC70 are too much front pad for my car's level of tire grip, 255 square Hankook RS3. DTC60 front and rear would be much better. Easily manageable on track, but terrible at Autocross, will cause front tires to lock up frequently on less than perfect surfaces. As noted above, the brake dust is brutal, invest in a quality wheel cleaner product. I have gone through 1.5 sets of front pads, and halfway through the original rears. They last about 6-9 track days depending on the track and level of street driving they see. They will never fade, no matter how hardcore you get out there. Speaking of street use, they are AWFUL on the street. They make a constant cyclical "whirring" noise when cold, which is all the time on the street. When actually stopping they are sometimes silent, sometimes noisy, hit or miss. Takes one or two really good stops to have a decent brake pedal, with the first stop of the day being a bit nerve-wracking if you don't allow some extra braking distance. Wear on thwe street is poor as well, they will wear out faster with street driving than they would with 100% track driving. Hard on rotors, lots of rotor cracking, but rotors are cheap, and my original set that I paired with the first set are still hanging in there (just). I got a bunch of these pads for cheap, so I'll be sticking with them for a bit. Next go around, will either use DTC60 up front, or move to a different brand/compound completely for the sake of experimentation. If you use slicks or R-comps, these are the pads for you. Reviewer: Ginger_Extract
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
09-17-2015, 03:11 AM | #36 | |
59
Rep 741
Drives: E87 130i
01-20-2016, 12:10 PM | #37 |
Jedi Wannabe
7
Rep 34
Great thread. Looking at the EBC Redstuff for my 128i. I only need to replace the rears right now but they seem to fit the bill according to the reviews. This is my daily driver and I like to have some fun. Basically some backroad driving but no track. Looking at my rims, I am thinking that anything will be better than the pads that are on there - unless I want to save some money on darker rims lol
2009 E82 128i ZSP, Space Grey
2001 E46 330ci ZSP, Topaz Blue (Gone but not forgotten) 1995 FZJ80 Toyota LandCruiser, White |
01-26-2016, 10:16 PM | #38 |
171
Rep 2,682
Old Pads
Pad: Cool Carbons Suggested use: Street and Track Rotors: ECS 2 Piece Fronts, BMWP Rear Dimpled and Slotted Fluid: Castrol SRF Actual use: Street and Track Dust: Minimal Rating for actual use: Good street pads, bad track pads Notes: They don't make any noise and there is hardly any dust. Cold bite is reasonable but better once warmed up slightly. Very linear feel to them. They do however leave very significant brake pad deposits and stick to the rotor whenever you wash the car. Causes significant brake shudder when on the track. On the track I really wouldn't recommend them. They wear incredibly quickly on the track and will fade significantly if pushed. Reviewer: froop Pad: Ferodo DS2500s Suggested use: Street and Track Rotors: ECS 2 Piece Fronts, BMWP Rear Dimpled and Slotted Fluid: Castrol SRF Actual use: Predominantly track with minimal street driving Dust: Similar to OEM, reddish colour, very noticeable Rating for actual use: Good street pads. Good track pads. Notes: Linear feel, no pad deposits, some moderate squealing on the street. Need a little warmth in them before they properly bite but not unsafe at cold temps. No slot to fit brake pad wear sensors. They wore at a moderately quick pace but did notice some significantly crumbling towards the end of its life. Mild fade on the track but never goes completely off. Reviewer: froop Current Pads E82 Pad: ProjectMu HC+ Suggested use: Street and Track Rotors: ECS 2 Piece Fronts, BMWP Rear Dimpled and Slotted Fluid: Castrol SRF Actual use: Minimal street driving, not yet taken to the track. Dust: Slightly less than OEM Rating for actual use: Good street pads Notes: Linear feel, no pad deposits, some moderate squealing on the street, strong bite. Need a little warmth in them before they properly bite but not unsafe at cold temps. OEM shims don't actually fit due to the width of the backing plate so there is some movement of the pads with associated sound within the caliper when rolling backwards and forwards. Have yet to take them to the track so will give an update when I do. Reviewer: froop Current Pads E88 Pad: ProjectMu NC400 Suggested use: Street Rotors: IAP/Dura International (OEM BMWP) Drilled/Dimpled and Slotted Rotors Fluid: OE Fluid Actual use: Street Dust: Minimal Rating for actual use: Good street pads but very noisy Notes: Linear feel, no pad deposits, good bite. Need a little warmth in them before they properly bite but not unsafe at cold temps. OEM shims don't actually fit due to the width of the backing plate so there is some movement of the pads with associated sound within the caliper when rolling backwards and forwards. They are currently extremely noisy. I used a generous amount of brake grease when installing them but I also haven't done any brake bedding procedure so it's possibly due to that. Still, very very loud which is odd for a street pad. Reviewer: froop
12-21-2016, 05:55 PM | #39 | |
128
Rep 303
One additional note I was unable to fit the brake pad sensors into the front pads and zip tied the sensors with no CELs. Pad: EBC Yellow/Stock BMW 2 Piece Fluid: Motul RBF600 Suggested use: Hybrid Actual use: 90% street 10% track Dust: Same as OE Normal Driving/Track even more or crumbling depending on high temps |
12-28-2016, 11:28 PM | #40 |
Ex '87 Carrera
248
Rep 1,259
Anybody got any input on Meyle ceramic pads for purely street use? ECS has them for extremely cheap. I've had good luck with other Meyle products in the past...
Anyone? ianc
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA |
04-21-2019, 03:10 PM | #41 |
Save the manuals!
6026
Rep 6,753
Bumping this old thread for info on these Meyle OE pads that are supposedly low dust. Anyone have feedback from using these on their 135i brakes?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
04-22-2019, 03:37 PM | #42 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
These are with F30 335i Brembos on my 128i. It's a fairly popular mod, so I thought it relevant. I believe these pads are also available in 135i and 128i fitments.
Pad: Porterfield R4 Suggested Use: Track Days, Time Trials, Racing Rotor: Stoptech Sport Slotted 340x30mm Fluid: ATE Type 200 Dust: Moderate Actual Use: Track Days Rating for Use: Excellent. Wear is extremely slow, they seem very friendly to rotors, and are compound-compatible with the street-oriented R4-S, making for easy swaps between pads. Pad: Porterfield R4-S Suggested Use: "Enthusiastic" Street Driving Rotor: Stoptech Sport Slotted 340x30mm Fluid: ATE Type 200 Dust: Extremely Light Actual Use: Very "Enthusiastic" Street Driving Rating for Use: Low dust, smooth, and quiet. Compound-compatible with the track-oriented R4 which makes pad swaps very easy.
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
04-22-2019, 04:35 PM | #43 | |
Ex '87 Carrera
248
Rep 1,259
ianc
05-20-2019, 10:10 PM | #44 | |
Supreme Allied Commander
3885
Rep 54,487
Drives: F80 M3
chris_flies3027.00 |
