01-21-2011, 11:16 PM | #1 |
HotBimmer
36
Rep 112
Drives: 2016 335GT & 2000 Z3M Roadster
Evo rear spoiler restoration project
Hey;
Was given a Evo rear spoiler with the factory clear coat peeling, chipping and badly yellowed. Apparently, this is a known issue with this model. Really bad shape!! Unfortunately, I never took a picture before I started it (thought I had, but apparently not). Here's the project pictures from about 1/3 way through initial sanding through to finished spoiler: Now Ready for Clear Coat: Just like new (actually in this case; better cause this won't yellow, chip or peel) :thumbup: |
01-21-2011, 11:44 PM | #3 |
HotBimmer
36
Rep 112
Thanks, about 6 hours of wet sanding to get it done!!!
01-22-2011, 12:06 AM | #6 |
HotBimmer
36
Rep 112
NO real tricks here.
1. Wet sanded starting with 220, then 400, 800 + 1000. Kept washing and drying regularly to ensure I wasn't cutting too close. 90% of sanding done with 220 grit. About 3 sheets of 220 required. about 2 sheets of each of the other grits. 2. Clear coat. Used BASF DC92 base, DH42 rapid hardener and UR50 reducer (20% for first coat and 30% for second coat; thinner + smoother, but more prone to runs; so have to be real careful). That's it!! Just about 6 hours total of wet sanding. No power tools even though I have orbital sanders, polishers, etc..... didn't want to chance cutting through cloth..... |
01-23-2011, 07:46 PM | #7 |
HotBimmer
36
Rep 112
01-23-2011, 08:36 PM | #9 |
HotBimmer
36
Rep 112
Actually quite proud of it..... as I said previously, I was real concerned about damaging carbon fiber base as the clear was sooooo badly damaged...
01-23-2011, 09:08 PM | #10 |
2154
Rep 5,364
Very good work. Painting isn't impossible and when you get the hang of it and remember a few rules you'll be able to keep doing good. Got any pics of your car?
01-23-2011, 09:27 PM | #11 |
HotBimmer
36
Rep 112
Setting the gun is the biggest challenge now! Have a decent compressor running it.... 60 gallon, 18.5 cfm @ 100psi; Tsunami 3-stage filtration and a DeVilbiss GFG-670 Cup feed. One drawback is I'm running 1/4" pipes.... Need to install the 1/2" manifold and 5/8 high flow fittings. I've had the parts for the manifold on the floor for the last 4 months; been crazy..... Takes a while to setup gun each time... Have test pieces I spray to check flow, etc before spraying anything to be finished.....
Here's a couple of pics of my car: The rubber @ top pf lip was just until I properly fitted it.... Notice it's gone in the above picture...... After installation of a DCT shifter and transferring all functions, I needed custom manual shift boot. Going to be cutting down about 1" or more soon!! Engine Bay Pictures: Those engine covers now are almost done and look like this.... Last edited by Nachos23; 01-23-2011 at 09:42 PM.. |
01-25-2011, 08:23 AM | #13 |
HotBimmer
36
Rep 112
Thanks. That's a SICK ride dude!!
01-25-2011, 09:14 AM | #15 |
HotBimmer
36
Rep 112
Thanks! Took alot of time to hand sand to this finish.
Tags |
carbon, clear coat, evo, restoration, spoiler |
