02-26-2022, 09:42 PM | #1 |
67
Rep 144
burning smell
I'm just on the verge of taking my car in for service to find out what the hell is burning under the hood. I figured I would check here first to see if anyone else has encountered this. The smell is ever present when I stop after a drive. It's especially strong after driving the car a bit harder. This smell is not that of oil burning or even rubber but to me smells like an electric motor that is fried or maybe even electrical wires burning. Honestly to me it smells eerily similar to what a ceiling fan motor smells like after it burns up. So the only thing I can think of is that the cooling fans are possibly going out, which would be the most concerning. Any ideas?
02-27-2022, 02:15 AM | #2 | |
1543
Rep 2,021
02-27-2022, 06:17 AM | #3 | |
988
Rep 1,806
02-27-2022, 04:34 PM | #5 |
67
Rep 144
02-27-2022, 05:25 PM | #6 |
1839
Rep 1,328
I smelled this faintly for my 2018 at all times.
I also smell it in my CS during break in so far. But it's "faint". Very small. If you have a change, get it checked. Shawn |
02-27-2022, 06:55 PM | #8 | |
1743
Rep 1,665
My M550 has been in twice with low coolant errors on I Drive 7 within 1000 miles and they say its good to go because they pressure tested it. P.S. - I was stationed at Warner Robins from 2003-2010 |
02-27-2022, 07:40 PM | #9 | |
Rep 15
02-28-2022, 12:53 AM | #10 | |
67
Rep 144
03-16-2022, 03:16 AM | #11 |
420
Rep 862
Expansion tank gasket leaking.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
03-16-2022, 07:51 AM | #12 |
988
Rep 1,806
03-19-2022, 10:52 PM | #13 |
420
Rep 862
Defective gasket, design, or assembly.
Coolant is leaking onto the coils and injectors, causing the burning smell and requiring replacement of those parts. This happened to my 2019 M5C and my advisor said it's not uncommon. It smelled like burning plastic, most evident when the car was still.
03-20-2022, 02:09 PM | #14 | |
988
Rep 1,806
03-20-2022, 10:51 PM | #15 | |
420
Rep 862
I'll try to get more info the next time I see my service advisor, which will be soonish.
03-22-2022, 02:58 PM | #16 |
Rep 1
I've just started noticing a smell that sounds very similar to what you're describing. Mainly notice it when I pull in the garage after driving home from work. Initially thought it was the "hot engine smell", but it's recently become more prominent. I have a 2018 as well. 26k miles.
03-22-2022, 09:58 PM | #17 |
776
Rep 569
Drives: 2019 M5 Competition
I had the expansion tank leak, replaced under warranty, I didn't smell anything burning or melting smell with my f90. However with my f10 M5, I did have a burning, hot electrical smell. Brought it in, and tech told me something about one of the battery cables. I dont recall which one, but he mentioned it was not the first time he saw it. Where someone put in a new battery and didnt attach something properly, and it was causing some sort of short that didnt affect drive-ability, however when inspecting the battery cable, one of them was definitely melted and burned. He said he's seen several car fires from this. Luckily for me they just replaced the cable, new battery, and on my way. He made it sound like a simple error whoever installed the battery made. Either loose, or something touching it, not sure. Try inspecting the battery cables if the expansion tank doesnt fix it.
