09-02-2022, 09:15 AM | #155 | ||
988
Rep 1,806
09-02-2022, 09:57 AM | #156 | ||
Rep 10
09-02-2022, 10:25 AM | #157 | |||
988
Rep 1,806
09-02-2022, 05:23 PM | #158 | |
134
Rep 254
09-02-2022, 05:36 PM | #159 | |
88
Rep 164
only $500 for a tune.. $500 to tune a $60k motor.. there are many factors too much to dissect but the price is all i need to higlight |
09-02-2022, 06:15 PM | #160 |
116
Rep 282
09-02-2022, 06:21 PM | #161 |
134
Rep 254
Rubbish for performance but not for safety. They are very light/conservative tunes so for someone who wants something at least faster than stock and conservative/safe it’s not a bad option. For $2500 you can also end up with an overly aggressive tune if not done right can kill the motor too.
09-02-2022, 07:33 PM | #162 |
5281
Rep 10,678
09-03-2022, 06:59 PM | #163 |
551
Rep 638
09-03-2022, 08:15 PM | #164 |
5281
Rep 10,678
A used motor like the one in the used M5 with the broken motor is $20k at most and $5k at most to put it in. I could install a built motor in my car for under $25k. Hopefully the $60k was paid by a warranty or insurance. If not someone got bent over.
09-04-2022, 07:03 AM | #165 |
988
Rep 1,806
That was for a warranty repair due to an engine that failed in a car with around 700 miles. So the repair involved a new BMW engine and parts as well as installation by a BWM dealership at BMW labor rates. I checked a BMW parts website, and a short block is $28k. I assume they replaced the long block, so around $60k is probably in the ballpark.
09-04-2022, 08:07 AM | #166 |
5281
Rep 10,678
Right, no one paid $60k for a motor because they used a BM3 tune. And everyone knows BMW dealer prices are ridiculous for parts and labor.
09-04-2022, 08:50 AM | #167 | |
106
Rep 182
$60k was dealers cost. Engines today on car-part cost between $10,000-$27,000. $5,000 installation is a bit much, I would say under $2,000 is a good price. |
09-04-2022, 10:35 AM | #168 | ||
Rep 10
09-05-2022, 12:58 AM | #169 | |
134
Rep 254
09-07-2022, 06:29 PM | #170 | |
551
Rep 638
who the hell is installing an m5 motor for 2k? Pedro at the gas station? Delusional. |
09-07-2022, 07:30 PM | #171 |
5281
Rep 10,678
It seems to me to be more than a 1 day job for someone who has done it before. I wrote $5k thinking that was very generous. I agree $2k is low. It is way more than just bolting the engine and trans in place. The suspension needs to be reconnected and an alignment must be done, the wiring harness must be connected, at least some fluids must be replaced, etc. I have read of one shop pulling an M5 motor, rebuilding it, and reinstalling in 5 days and one shop doing it in 4 days, but those shops had experience doing the job and of course all the parts on hand.
09-08-2022, 09:13 AM | #172 | |
1-800-STOCKAF
157
Rep 383
75-100 increase in power just from a tune is the safest range.
F30 320i Stock
09-08-2022, 10:11 AM | #173 |
5281
Rep 10,678
800 may be crank hp not rwhp. 800 crank is probably 700 rwhp. Plenty of cars have been making that without blowing up. Stock, some have been dyno tested at around 600 rwhp.
Also, it’s the torque that blows up the motors not the horsepower. The torque peak occurs at much lower rpm, where cylinder pressure is higher and detonation more likely. You can feed in the boost more slowly and still make 800 hp but not have low/midrange torque be as risky. |
Holset278.50 |
09-08-2022, 01:15 PM | #174 |
134
Rep 254
It’s around 720whp. F90s are fine with that power. Only reason it blew up obviously is because octane was too low, not matched for the tune. In that situation it’s VERY high risk running 91 octane on a 93 octane file. He had a very safe torque limit on it of 960nm which again is fine for the stock engine, so low octane is the culprit, even for just the ONE time he did it.
09-08-2022, 03:39 PM | #175 |
5281
Rep 10,678
That was dumb. If you don’t have easy access to 93 or will be traveling where it won’t be available, keep a couple of bottles of boostane in the car (or reflash to a lesser tune).
09-10-2022, 09:18 AM | #176 |
1416
Rep 1,564
Here is a great recipe for putting your wallet on a 25-40k diet (depending on what options you go with on the rebuild):
1 - 91/93 octane gas. 2 - Tune that cranks the boost at low rpm. 3 - Leave the transmission in manual mode stuck in high gear and low rpm (7th or 8th gear and around 1200-1500 rpm is perfect. (Side note: It is possible to do this in normal drive mode also but will take longer to find the perfect throttle position to allow maximum boost at low rpm before kickdown is applied) 4 - Punch it! Approx 75-90 percent throttle is what you are aiming for. The tune will allow you to reach peak boost at very low rpm, and as long as you don't completely floor it, the transmission won't kick down. This will now create the perfect the perfect environment for a LOW SPEED PRE IGNITION event! 5 - It may take several attempts to reach the desired results but rest assured bent rods, nuked pistons, and wrecked bearings are inevitable with this fool-proof financial diet plan! In all seriousness, anyone with a tune should be absolutely paranoid about LSPI. That is what is wrecking engines, not an additional 100-150hp. Mix in race gas & e85 as insurance (96+ aki should be the goal) and carry around a bottle of boostane as a backup. Google LSPI and educate yourself about it if your running a tune. This is not a knock (pun intended) against tunes, rather it is important to educate yourself on what could happen as tuned engines are much more prone to LSPI and even stock engines can suffer from this in the right circumstances. LSPI events will place 3000-4000+ psi loads on your pistons and rods and shatters the oil film protecting your bearings. Bumping your Horsepower up another 150hp doesn't even come within 5 percent of those numbers. Last edited by Sophisticated Redneck; 09-10-2022 at 10:02 AM.. |
