04-04-2019, 04:01 PM | #23 | |
12971
Rep 18,716
It is not high grade Titanium. High grade Titanium can't be bent and exhaust noise will be raspier. Akrapovic is using stainless mixed Titanium, and charge you a full Titanium price. Stainless is softer material and make the exhaust noise deeper.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-04-2019, 07:07 PM | #24 | ||
///M
6656
Rep 3,683
You can bend full Titanium tubes. There are tubing bending Maschine. Similar to mandrel bending. It needs to be formed very slow and, if radius is small, tube needs to be heated first. All depending on radius and wall thickness. I have done it mine self
Life is too short...enjoy your life
///M |
r33_RGSport12971.00 M 4EVER191.00 |
04-04-2019, 09:17 PM | #25 | |||
12971
Rep 18,716
When I used to work for Japanese company that do Full Titanium exhaust, we have to do pie cut and weld the pipes to do turn. And compared to Akra, it is much2 lighter for a similar full system like Akra.
04-04-2019, 09:52 PM | #26 | |
1716
Rep 1,909
Drives: 2023 M5C
r33_RGSport12971.00 Miko M6655.50 |
04-04-2019, 10:01 PM | #27 | ||
12971
Rep 18,716
They do have good product.
04-05-2019, 01:31 AM | #28 |
876
Rep 1,319
How many have just changed the rear silencer only, and left the center pipes alone ?. This seems to be our only option atm in Europe, because of the dreaded opf. Does it make a big difference, just changing the rear silencer ?.
04-05-2019, 05:56 AM | #29 | ||
///M
6656
Rep 3,683
Number 1 most pure Titanium Grade 1-3 mainly get used for Medical application Grade 4,7,11 grade 4 is good to form used for tubing, heat exchanger Grade Ti 6AI14V which is grade 5 mainly get used for engine components, aircraft, aerospace To 6AL-4V ELI grade 23 springs Grade 12 mainly for heat exchanger Ti 5AL-2.5Sn Aircraft, airframe
///M |
04-05-2019, 10:04 AM | #30 | |
19365
Rep 10,166
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
04-05-2019, 11:12 AM | #31 | ||
///M
6656
Rep 3,683
///M |
04-05-2019, 05:25 PM | #32 | |||
191
Rep 292
I noticed that you can make cool stuff, I wish I would have your skills. Is there any other material that is good besides stainless steal and titanium? |
Miko M6655.50 |
04-05-2019, 05:35 PM | #33 | ||||
///M
6656
Rep 3,683
You can use inconel material for exhaust, which is very expensive but it's great for heat and is very corrosion resistant. I would go Inconel 625 for exhaust I make Springs out of Inconel wire X750 special heat requires over 1000 deg. for 5 hours. Also Inconel wire is not magnetic at all. I pretty much use any material that is out there, silver gold and even platinum.
///M |
M 4EVER191.00 r33_RGSport12971.00 |
04-05-2019, 05:46 PM | #34 | |||||
191
Rep 292
May I ask for what you use such expensive material for? I taught you are making tooling and springs? |
04-05-2019, 06:52 PM | #35 | ||||||
///M
6656
Rep 3,683
Medical parts are what uses very unique materials. Also very small parts... wire diameter that can go below 0.001"
///M |
