Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > How to reset FTM (RPA) Flat Tire Monitor warning with INPA
      10-11-2022, 10:09 AM   #1
eljay
1453
Drives: ///M + E91
Lightbulb How to reset FTM (RPA) Flat Tire Monitor warning with INPA
I am posting this as I didn't find a solution anywhere for this scenario.
If you have iDrive-equipped car and the monitor or iDrive fails and you happen to get a flat tire warning message/icon, there is no way to reset or re-initialize FTM (Flat Tire Monitor, aka RPA - Reifen Pannen Alarm) via the steering column stalk. You must use iDrive menu and controller.
In my case, I installed new tires and my iDrive screen is blank, so I was driving around with the FTM warning icon and no way to reset it.
I searched around ISTA, but there was no option I could find to reset it. I finally found a way to do so in INPA.
Steps to reset FTM (Flat Tire Monitor aka RPA) warning:
1. Load INPA and press F3 (or click E90) to select E90
2. Select Chassis > Dynamic Stability Control DXC (this is for xdrive cars, select the option above for RWD)
3. Press F5 (or click on 'Status')
4. Press F3 (or click on 'RPA')
5. Press F1 (or click on 'RPA Reset')
6. There will be a brief message confirming a successful reset (RPA Data Written OK)
DONE
Appreciate 3
      04-26-2024, 04:13 PM   #2
mygive
Drives: 530i e60 2004
Like you i could not find a method that would reset the FTM flat tyre monitor warning symbol in the instrument cluster. (Note: this is not the TPMS system that has a sensor inside every tyre that communicated by wireless to a module)
Searched Google and YouTube but nothing worked.
The car's CCC (Note: not the later CiC or even later iDrive) is not working, constantly rebooting, so I could not use it.
The indicator stalk has separate Check and BC (BC = onboard computer) buttons but nothing else. (Note: no rotary toggle switch)
As with google and youtube advice i tried the ignition switch in position 1 or 2 or engine started but it made no difference, nothing worked and the red flat tyre warning symbol remained.
You're idea worked with a few different choices in the inpa software perhaps because the car is a e60 model, early year model or different version of inpa.
Just registered to say a big, super really big thank you.
Appreciate 2
eljay1452.50
POBEP367.00
      04-26-2024, 07:57 PM   #3
eljay
1453
Drives: ///M + E91
Excellent! I'm glad to hear it helped.
Thank you for posting and confirming for E60.
Yes, it can be in different places/modules depending on model platform. I'm glad you found it.
      04-26-2024, 10:07 PM   #4
sdbmwcoding
Drives: BMW M3
You can also remove idrive 6VA or 609 from vehicle order, factory code kombi/cluster and you’ll be able to reset ftm or tpms with bc stalk
Appreciate 2
POBEP367.00
eljay1452.50
      04-28-2024, 08:59 AM   #5
mygive
Hi
That sounds like a solution to my problem.
The CCC is faulty, constantly rebooting at the logo.
Would you explain what I would be doing? Do you mean the car's VO (vehicle order) has assigned control of the FTM to be managed only by or through the CCC and by removing some setting the control/management of the FTM will go the indicator stalk's BC button?
I'm willing to have a go, how do I go about doing your suggestion?
Tags
idrive, inpa, reset ftm, rpa, tpms
