Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA Connected Drive Remote Services
      12-01-2019, 07:27 PM   #89
akzz
37
Drives: '19 330i M-Sport
So my CarPlay has decided to stop working altogether.
It worked fine a few weeks ago and now just refuses to connect.
Anyone else currently experiencing the same issue?
      12-02-2019, 12:32 AM   #90
achk
Australia
133
Drives: BMW U11 iX1 Xdrive 30
Have you tried resetting your phone and also iDrive (long press power button)? This seems to fix the problem.
      12-02-2019, 05:22 AM   #91
akzz
37
Yep. Tried multiple times with no success !
      12-18-2019, 04:10 AM   #92
NoSUV4Me
NoSUV4Me's Avatar
61
Drives: G20 330i M Sport
Has anyone's remote services conked out again?
42 deg today and car decides it couldn't be bothered to set a ventilation time remotely
      12-18-2019, 11:26 PM   #93
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
What software version are you on? I specifically asked dealer to update the iDrive software prior to delivery. My version is 03/2019.45.
Carplay works fine with me with no dropouts. Bluetooth audio is also working well when Carplay is not in use.
Remote services seem to work intermittently now but still haven't been able to get a remote 3D image successfully.
Is this resolved? Ive just got an M340i and discovered that you need to set up your personal driver profile before 3D remote services work. It wont work on the Guest profile. I guess that makes sense as you need to log on to your connected drive app to use 3D remote so it will only work with the same driver registered to the app.
      12-19-2019, 02:31 AM   #94
Astera
Drives: G20 330i
Called BMW today to see what was going on as lost all ConnectedDrive internet connection services for the last few days and if it was perhaps just a local glitch with my car, but was told is a network-wide issue - should be fixed tomorrow apparently - we'll see
      12-21-2019, 09:41 AM   #95
digitallust
digitallust's Avatar
Australia
99
Drives: 2019 G20 BMW 330i M-Sport
Are they still using that line "it'll be fixed by tomorrow" they told me that back in July when I took delivery of mine
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
      12-21-2019, 12:59 PM   #96
Astera
Drives: G20 330i
Started working again mid-afternoon yesterday while driving - RTTI finally appeared again mid-journey as too weather.
      12-21-2019, 01:25 PM   #97
Vossy
United Kingdom
110
Drives: G20 330E M Sport
Greetings from the UK
I’m sorry to hear of your issues but if it makes you feel any better we’ve had big problems with Connected Drive. I’m on the latest 11/2019.40 software but the BMW Portal and Connected Drive App ( two star rated on Apple App Store) is at best meh and at worst total wank.
      12-23-2019, 05:20 PM   #98
akzz
37
All my services are now working perfectly after the dealer updated the software. The graphics have changed and even the instrumental cluster map graphic is no longer just lines, has proper building maps etc.
      12-27-2019, 09:08 PM   #99
NoSUV4Me
NoSUV4Me's Avatar
61
Finally!
What version software?
Pic of the instr cluster map?
What's caring car-does that come with a particular option pack?
      01-07-2020, 06:58 AM   #100
stevenp67
Drives: BMW G20 330i
My 330i is on 11/2019.35 not sure why my car has no update available if the latest software is 11/2019.40???
      01-10-2020, 03:45 PM   #101
akzz
37
Finally!
11/2019.40 is the one they upgraded me to.
Pic of cluster below:
      01-10-2020, 08:17 PM   #102
NoSUV4Me
NoSUV4Me's Avatar
61
Finally!
Thanks akzz
      01-13-2020, 08:27 AM   #103
digitallust
Australia
99
Finally!
Yeah looks much better I received the centre map change in my update to 07/2019.75
Not a lot of other notable changes other than enhance to existing features. Apps are now all coloured and Hey BMW assistant has menu changes everything else seems to be going well
      01-13-2020, 08:28 AM   #104
digitallust
Australia
99
Since the update the BMW connected app works perfectly now. Even 360 view works every time. Not that I use the app that often but it's good to see it's a priority to have it working
      01-13-2020, 09:15 PM   #105
mcdav
Drives: 330i G20
Interesting - I still haven't got 360 view working yet
      01-13-2020, 11:32 PM   #106
digitallust
Australia
99
Do you receive any errors? Or does it not work. What worked for me after the OTA, was to completely delete the iOS app then redownload and sign in.
It looks like the 360 view process isn't doing anything initially but it just takes a few minutes to push on through
mcdav3.00
      01-14-2020, 05:06 PM   #107
mcdav
Drives: 330i G20
Tried again last night and it worked! Not sure what value it adds, but at least we are slowly getting there with functionality.
      01-15-2020, 05:02 PM   #108
achk
Australia
133
Finally after 8 months of ownership I can say for the first time that all the connected drive functionalities are working. This is after a software update to 11/2019.41 at the dealership. I can also now subscribe to the drive recorder through the connected drive store. 😊
      01-15-2020, 07:29 PM   #109
digitallust
Australia
99
Glad it's all working for you. Mine had been extremely stable at 03/2019.60 so will see what my new update brings.
Are there any other notable changes, enhancements in your version
      01-16-2020, 03:24 PM   #110
mcdav
Drives: 330i G20
The one thing i was hoping for was proper Spotify integration, but now with ACP for life I'm not sure I care so much.
g20
