08-16-2020, 02:34 PM | #45 |
In the Details
1812
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
The reason the car runs a bit rough with cold start off is because there are other tables in the tune that aren't properly recalibrated for running a lower RPM at a given coolant temp. The cold start off function is just a hard switch off that lowers the idle when you start the car. Typically you need adjust cold fueling and spark modifiers as well as base running airflow type tables. It's not because it "needs RPM to warm up," that is incorrect.
