11-01-2021, 12:53 AM | #23 |
29
Rep 105
Good timing, ashmostro! I was about to post per below.
Got the M5 back from my dealer last Friday (Oct 29). Prior to the tech taking my car back into the shop, I was able to replicate the thud/shudder "event" once, as I sat in the drive-up service bay with both my Shop Foreman and Service Advisor in the car. They both said to me that they heard and felt something just after ignition cut-off. However, I told them that not all events I experienced had occurred with the same degree of intensity. This time, it happened to be on the moderate side, i.e., less noise and less shudder. At least they said they both heard and felt what I was trying to explain. As part of their inspection, they called in a regional factory rep. They also compared my car to another M5 F90 that they fortunately had at the time. They were unable to duplicate the event, and found my car to be operating the same as the other M5. No fault codes were stored for the differential, either resident or in the past. They did remark that the car's multi-disc clutch packs release when the car is turned off. (I sensed that this may be the case, i.e., an "unloading" of some sort.) It appears that this is all that they are able to do. In the end, I wasn't surprised (and thankful, actually) that nothing could be found. The event has been a matter of record, at least if and until something" occurs that hampers performance, causes part breakage, etc., and is something that I will have to live with. To use my son's expression, "I'm not trippin'." Last edited by delta; 11-01-2021 at 12:56 AM.. Reason: further clarity of explanation |
ashmostro1254.00 |
11-01-2021, 01:25 AM | #24 |
2511
Rep 4,381
With the "hand" brake off and auto hold off, the car will tend to creep forwards, so there is an amount of energy held in the drive train when stationary that will be released when the engine is switched off.
Any play in the drivetrain might then reveal itself as a clunk or shudder as the load on it is released. I guess the engine idle speed is as expected? As a data point my 2019 car doesn't have the same characteristic. |
11-01-2021, 10:34 AM | #25 |
1254
Rep 4,088
Good to hear and thanks for the update delta! Hopefully it’s a “within spec” issue and as you say, you are now on the record if something were to happen in the future.
11-01-2021, 12:55 PM | #26 | |
29
Rep 105
From the sound and vibration, I also think there is a release of energy somewhere. The only puzzling part is the fact that most F90's do not appear to demonstrate this particular thud/shudder characteristic. Luck of the draw. |
11-01-2021, 02:56 PM | #27 | ||
Plenipotentiary
2614
Rep 3,046
Before removing pressure from the brake pedal: - Engage the parking brake via the switch. Auto Hold uses the service brakes with the engine running; not the parking brake as eluded to up thread. If using Auto Hold, there is a change-over from the service brakes to the parking brake at shutdown. - Select P on the gear selector to engage the parking pawl on the transmission. - Ignition: off |
11-02-2021, 11:24 AM | #28 | |
29
Rep 105
On your point about inclined surfaces, the event does seem to have a vague relationship to inclined surfaces or just after climbing an inclined surface. For example, it occurs more often just after I have traveled up and remain on an incline (parking on a hill) or entering my garage (inclined driveway). In the former example (i.e., parking on a hill) my wheels were turned to the left before shutdown when the event occurred. Any relationship between the event and the brakes I have yet to fully sort out. I have tried to isolate the relationship between shutdown and applying/not applying the brake pedal, parking brake or Auto Hold prior to shutdown. I have tried your suggested sequence a few times; I remember at least one occurrence under those circumstances. One sequence I do not remember trying is to cut off the ignition in "D," just after stopping and after releasing the footbrake. Gotta try that. Appreciate your thoughts. (In regard to the parking brake vs. Auto Hold, I did not know that the function uses the regular brakes rather than the parking brake. Good to know.) |
11-02-2021, 01:17 PM | #29 | |
1408
Rep 868
Drives: M8 GC || M5 Comp || X7 40i
I will no longer be trippin, either 🙂
2024 M8 GC Black/Black || 2021 M5 Carbon Black/Midrand beige || 2021 X7 40i Amertin metallic with Ivory white merino
2019 M5 F90 || 2018 X5 s35i || 2017 M5 F10 with Arkapovic Exhaust || 2016 535 || 2012 535 hated it after the E60 || 2010 535 E60 - my fav || 2008 528 E60 my first |
11-02-2021, 01:56 PM | #30 |
29
Rep 105
11-02-2021, 03:30 PM | #31 |
113
Rep 67
Just got my 2021 M5 Comp and this happens for me too.
Current Garage:
2021 Nardo Grey M5 Competition - MPerformance Diffuser, Lip and HAS 2016 McLaren Mexico Blue 675LT with Roof Scoop 2018 Porsche Graphite Blue Metallic GT3 Touring Manthey Racing and Akrapovic 2018 BMW Yas Marina Blue M4 Competition Convertible |
11-02-2021, 04:02 PM | #32 |
29
Rep 105
What is your M5's build date, neoprufrok? I'm tracking the build dates of those on this thread who are having the same issue.
Thanks. Last edited by delta; 11-02-2021 at 04:03 PM.. Reason: That's some garage you've got, neoprufrok! |
