08-23-2014, 08:05 AM | #45 | |
171
Rep 1,536
08-23-2014, 10:42 AM | #46 |
7
Rep 55
They put in 10W-60. I found this just now, dated from 8/13:
*The following is the only recommended and approved synthetic oil for BMW M (Motorsport) vehicles in the US market with gasoline engines, at the present time. BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles equipped with S54, S62, S65 or S85 engines Castrol EDGE Professional TWS Motorsport SAE 10W-60 Synthetic Engine Oil, BMW part number 07 51 0 009 420 or Castrol Edge Professional OE 5W30 Synthetic Engine Oil BMW part number 07 51 0 037 195 |
08-23-2014, 10:52 AM | #47 |
16
Rep 102
That Castrol Edge Professional 5W30 BMW P/N 07 51 0 037 195 comes back as an oil for Diesel engines.
Am I reading this wrong, or BMW saying you can use this lighter oil intended for diesel engines? |
08-23-2014, 10:58 AM | #48 | |
64013
Rep 24,851
And need to say engine runs smoother with EDGE ! BTW.....sad to see about the damn bearings , and wish you good luck with the new S65 !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
08-23-2014, 05:52 PM | #49 | |
177
Rep 2,301
There are a few other factors that influence bearing wear besides oil thickness, and clearances. Heat build up, and also dirt particles stuck under the bearings during assembly. Lastly, my point is that if we all think the way you think, then my high mileage M3 makes next to no sense for it to be functioning without any issue. Proof positive that it is NOT a universal issue.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
08-23-2014, 07:04 PM | #50 | |
188
Rep 1,755
08-24-2014, 01:16 AM | #52 | ||
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
No S65 bearings that I have seen have shown signs of wear due to extended oil change intervals/lack of maintenance. In fact, even at the full BMW service interval for the TWS 10W60 still has some TBN remaining showing it is still serviceable. As for the contamination under the shells, I have seen the photos where that happened, but that was only in two instances, (maybe three) out of all of them, and even those bearings had not failed as a result of it, they just had added wear directly above the debris. As for your M3 being fine at 100K miles, that is definitely possible. If the tolerances on all of your rods are at the max of spec and your crank journals are at the min of their spec you may have an S65 with around 0.0018" of oil clearance on the rods which would be just fine and should last a long time. Will all S65's suffer rod bearing failure, of course not, but many will. Don't forget that I own one of these cars too and I am no more happy about this than you are, but I understand and accept the issue. If you intend on keeping your M3 plan on inspecting/replacing the bearings at some point, it may save you $20k. |
08-24-2014, 05:46 PM | #53 |
7364
Rep 7,320
How can we guarantee that the replacement bearings don't have a worse tolerance stack than before? Is Plastigauge good enough?
Also, the wear seems to be most aggressive on a few cylinders. Is there a way to determine clearance on these after the fact? I would be curious to know if it's looser, tighter, etc. |
08-24-2014, 08:23 PM | #54 |
7
Rep 55
I had the oil changed every 7500 miles or so. I didn't beat the car at all, no track time, rarely red-lined it. Original owner.
Here is where I got the oil listing: http://www.google.com/url?sa=t&rct=j...73612305,d.aWw |
08-25-2014, 05:58 PM | #55 | |
Grease Monkey
295
Rep 2,646
Diesel engines are far more taxing on oils due to much higher valve train loads as a result of their higher valve spring seat pressure and higher compression ratios. Diesel engine oils as a rule are more robust hence BMW recommending this particular oil for the S65. |
08-26-2014, 02:46 AM | #56 | |
2511
Rep 4,381
Ring BMW AG and they will absolutely confirm that. |
08-26-2014, 04:56 PM | #57 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Was told the 5w30 oil was for the new M3/M4 the other day when I went to pick up a quart of 10w60.
08-26-2014, 05:42 PM | #58 | |
569
Rep 3,742
Who is "antonio010"? Is that someone whose engine failed and had to pay for a replacement out of pocket? |
