BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    JB4 Tune
      06-17-2018, 08:55 AM   #23
pilotroger
Cruising in paradise
pilotroger's Avatar
Drives: F90 M5
Originally Posted by onfireX5 View Post
Some beta testers had an alarm if they used the EWG connection, which you really need for the full JB4 benefit. Terry found that adding an extra wire to the loop eliminated the alarm. He is posting a “how to add” on his site. I would do that before installation.
News to me, thanks for the heads up. It definitely looks like a much bigger PITA to install than the JB4 on my previous M4, which I was extraordinarily satisfied with.
      06-20-2018, 11:56 AM   #24
daonlyillwiz
110
Drives: 2018 BMW M5
link to this?
      06-20-2018, 12:12 PM   #25
onfireX5
3619
Drives: F90M5,F85X5M
Originally Posted by daonlyillwiz View Post
link to this?
http://www.burgertuning.com/instruct...b4_install.pdf
      06-20-2018, 01:41 PM   #26
daonlyillwiz
110
Drives: 2018 BMW M5
oh im sorry i was referring to looping the wire
      06-20-2018, 01:48 PM   #27
onfireX5
3619
Terry @ BMS's Avatar
Terry @ BMS Terry @ BMS is online now
Tuner
Report Post
Default 06-15-2018, 11:33 AM
Firmware in the first post has the basic map switching active now.
EWG "fault" is corrected by adding one extra wire to the harness. Fairly easy to retrofit. Email us if you need directions on that.
      06-21-2018, 03:41 PM   #28
M4LAKA
114
Drives: 2022 M5 Comp
Does this clear check engine light caused by catless downpipes?
Currently:
2022 M4 Comp xDrive
2022 M5 Comp
Past:
2019 M5 Comp
2015 M4
      06-21-2018, 03:58 PM   #29
onfireX5
3619
No. Old versions did. New version can not due to EPA.
      06-21-2018, 04:55 PM   #30
pilotroger
pilotroger's Avatar
Drives: F90 M5
Just finished my first test drive after the install. The installation was actually very easy. It probably took less than an hour.
The car is significantly faster. It pulls with a force that actually makes me nervous about the longevity of the engine(but not enough to uninstall 😁 )
For $1k this is a no brainer to me.
      06-21-2018, 05:33 PM   #31
M4LAKA
114
What if you live in Canada with no EPA??
      06-21-2018, 06:15 PM   #32
onfireX5
3619
You could ask Terrry if out of USA units can be set up to clear the code.
      06-22-2018, 02:59 PM   #33
koko f90
12
Drives: bmw m5 f90
Do you have some acceleration Time ?
100-200kmh/62-124mph?
1/4 time ?
      06-22-2018, 07:42 PM   #34
pilotroger
pilotroger's Avatar
Drives: F90 M5
1/4 time ?
Not yet, the Dragy is in the mail so by Tuesday or Wednesday I should have some numbers.
      06-22-2018, 09:06 PM   #35
onfireX5
3619
Have any boost logs you can post up ?
      06-28-2018, 08:44 PM   #36
koko f90
12
Drives: bmw m5 f90
Any news????
      07-01-2018, 07:17 PM   #37
pilotroger
pilotroger's Avatar
Drives: F90 M5
Any news????
Yeah sorry, I’ve been so busy lately but I did do a Dragy run with my JB4 Map 1. 0-60 in 2.87 and a 1/4 mike in 10.78sec. Certainly not record breaking times but that was literally my first and only try. I’ll do a better comparison at a later time where I turn off the JB4 tune and compare that with the Map 1. Needless to say, it feels fast and it is fast.
onfireX53618.50
      07-01-2018, 07:49 PM   #38
onfireX5
3619
That is FAST in this weather !
      07-02-2018, 03:32 AM   #39
koko f90
12
Drives: bmw m5 f90
Any 100-200time
Or 60-130 ?
Btw i did 0-62 in 3 flat and 11.0 flat on my stock f90
My best 100-200 run was 6.91
Average 100-200 is around 7.05-7.1
