M235i H&R sway bars with Ground Control adjustable front endlinks |
01-16-2016, 08:40 PM | #23 |
38
Rep 233
Has anyone installed just the rear upgraded swaybar? It should help with understeer? Also minimize body roll to a degree?
Or is it pointless without upgrading the front as well? |
01-25-2016, 05:17 PM | #24 | |
Supreme Allied Commander
3875
Rep 54,430
Drives: F80 M3
01-28-2016, 04:38 PM | #25 |
Rep 4
Hotchkis Sway Bars for N20 and N55 Chassis In-stock
Guys,
Looks like Ketema got and early set of our bars (thank you) but for those wanting to know more, they are finally back in-stock. We worked hard testing on the street and at Willow Springs to develop these Bars. Good for autocross, road course and open road-racing applications too. Let me know if you have any questions? Check them out at: http://www.hotchkis.net/search-by-ve...md=23967&sm=20 22840 Fits Platforms: F22 - BMW 2-series 4 cylinder (N20) 2014+ 228i F30 - BMW 3-series 4 cylinder (N20) 2012+ 320i, 328i F32 - BMW 4-series 4 cylinder (N20) 2014+ 428i Specifications 4 cylinder (N20) 2014+ 228i: Lightweight & durable 32mm tubular steel front sway bar Lightweight & durable 16mm tubular steel rear sway bar Front Rates: 170%/195%/225% stiffer than stock BMW 228i Rear Rates: 115%/130% stiffer than stock BMW 228i Premium mounting hardware including upgraded brackets & greasable polyurethane bushings 22841 Fits Platforms: F22 - 2-series 6 cylinder (N55) 2014+ M235i F30 - 3-series 6 cylinder (N55) 2012+ 335i F32 - 4-series 6 cylinder (N55) 2014+ 435i Specifications 6 cylinder (N55) 2014+ M235i: Lightweight & durable 32mm tubular steel front sway bar Lightweight & durable 19mm tubular steel rear sway bar Front Rates: 100%/115%/140% stiffer than stock BMW M235i) Rear Rate: 80 lbs/in (100% stiffer than stock BMW M235i) Premium mounting hardware including upgraded brackets & greasable polyurethane bushings http://www.hotchkis.net/search-by-ve...md=23967&sm=20 |
01-28-2016, 09:14 PM | #26 | |
463
Rep 957
You can, esp. If you go with a square tire setup. I run my hr bar on the front on the soft setting. |
12-25-2016, 08:48 AM | #27 |
124
Rep 211
Hi guys. Apart from Ground Control end links, anyone using other brands of end links? How are they holding up? Any one using Hotchkis end links?
Did you guys upgrade the rear end links as well? Thanks! |
12-26-2016, 12:00 AM | #28 | |
3875
Rep 54,430
Drives: F80 M3
http://www.hpashop.com/HP-Autosport-...-HPAEL-F3x.htm |
Anthony235715.00 |
