05-01-2020, 12:39 AM | #199 | |||
IG @bmwF9xG80
3813
Rep 7,593
Femto is just a flasher, it's not so convenient because it takes so long to switch maps and requiring 2 files lol.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
05-01-2020, 04:57 AM | #200 | |
446
Rep 891
What people dont seem to understand that cant expect to run some crazy nimber on 93 oct. Even if they do they go after dragy times and go wot from low rpm in low gear, and bad fuel, strong map and low rpm wot is a recepie for knock and thats when you bend a rod. At least they could install wmi and not to map the car to depend on wmi rather to have it as a safety precaution, but since most of the cars are leased I understand its hard to go that route. |
FSociety3812.50 |
05-01-2020, 05:56 AM | #201 |
107
Rep 411
DMEs stage 2 tunes do not work in BM3. i requested them from DME and we loaded them and the car continued to throw a CEL when loaded through BM3. If I load his tune (same file) in Femto no problem. I don't think BM3 supports all of the tables he modifies. We called BM3 tech support to resolve the issue and they weren't very helpful. Also, we attempted to load the DME file via upload (the way you are suggesting for evolve) and the option to flash wasn't even available (you couldn't press the button). We contacted BM3 several times regarding issue and they never fixed. This is part of the problem with their email only tech support that takes hours upon hours (sometimes days) to respond. The main reason I bought BM3 is for the very reasons you are stating, but I ran into so many issues that I jumped ship. If you can get BM3 to resolve my issues (ie so I can load my Femto files for DME and Evolve into BM3 and for HCP to send me a strong stage 2 custom map on 93 and E30, which I paid for), then I will load up my BM3 now and exclusively use that tool for all my logging and flashing needs ...in fact, this is what I wanted from the get go and the main reason I purchased BM3 first !!
05-01-2020, 07:07 AM | #203 | |
446
Rep 891
Sorry to hear you had trouble. I have no experience with dme tunes so I cant comment on that. Did you try in BM3 when you select the loaded dme map, can you selet the configuration button like you can with ots map? Where you can select various option such as cats no cats max cooling mode boost by gear etc? I also have flashed a few F90 with Femto and on 1 occasion I had the flash broke in the middle of the process for no obvious reason. Car was left stranded, I couldnt start the car nor flash back to stock (femto,esys etc...) . Solution was I had to take the ECU's out and bench flash it back to stock than code it again back when in the car. So no solution is 100%. |
FSociety3812.50 |
05-01-2020, 07:21 AM | #204 |
73
Rep 174
I asked DME they said its an issue with BM3 they need to fix it. I haven't asked BM3 but I'm sure they will say its DME's issue and they will need to fix it. I have the files I'll try loading them into BM3 as you suggest. Thx!
05-01-2020, 07:43 AM | #205 |
107
Rep 411
Ssm5
The two femto files won't work (I don't believe) because those are files for each DMe. I think you need one file for both DMEs. Did Mo send that ? It's a bigger file than the femto fileS ( I believe) |
05-01-2020, 07:50 AM | #206 |
73
Rep 174
Nope, just the two files. The two files make it even a bigger pain in the ass. Did you get one file? I just wish they would work this shit out and get it working for us. I have a local dyno tuner that said he can even get me working through BM3 no problem. So I don't know what the issue is here.
05-06-2020, 07:51 PM | #210 |
39
Rep 204
That was my concern too since bootmod3 didn't provide anything regarding their maps. I wanted to make sure it won't be annoying for daily use! Which seems it will be lol
05-06-2020, 07:58 PM | #212 | |
73
Rep 174
10-16-2020, 09:55 AM | #214 | |
3323
Rep 8,083
sounds great. I think alot of people are over-doing it with the burbles, it's getting ridiculous. it sounds dumb, and childish. |
10-16-2020, 01:37 PM | #215 | |
IG @bmwF9xG80
3813
Rep 7,593
100-200 KM/H for E30 is 5.0-5.6 range
10-18-2020, 07:22 PM | #216 |
103
Rep 352
10-18-2020, 09:29 PM | #217 |
IG @bmwF9xG80
3813
Rep 7,593
Quality of pump gas is critical and that's what holds back the 100-200 in the USA. But in EU my friends are all 5.3-5.5 on pump gas.
