E90 - anyone used the Varta car battery instead of OEM?
06-20-2016, 09:54 PM | #23 | |
44
Rep 249
haha formula seems off mark then. unfortunately no Ah ratings on the new batt. Would dividing by 2 then adding 16 be close to your 80AH ? What RC rating is it? Edit: Doh perhaps next time i'll just google it off against the battery model. http://www.centurybatteries.com.au/r.../din65lh%20agm 70 Ah. Last edited by rooks335; 06-20-2016 at 10:04 PM.. |
06-20-2016, 11:33 PM | #24 | |
899
Rep 6,285
http://www.centurybatteries.com.au/r.../din65lh%20agm |
06-21-2016, 12:18 AM | #26 | |
541
Rep 3,131
Drives: 2011 335i e92 DCT
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
06-21-2016, 01:58 AM | #27 |
44
Rep 249
AGM wasn't in stock and besides this is a 335ionabudget haha.
The century battery I got is old skool ! maintainable! Planning to put some Innox magic battery fluids in it to extend the life out. |
06-21-2016, 03:11 AM | #28 |
4545
Rep 11,903
Varta FTW !!!
06-21-2016, 06:09 AM | #29 | |
899
Rep 6,285
that inox battery conditioner is good stuff, I use to always use that in my cars before most wet cell batteries became sealed! |
04-29-2020, 07:30 PM | #30 |
Davy Jones, Giant Squid
271
Rep 913
Sorry to resurrect an old thread but I'm in the market for a new battery
Here are the ones i've been looking at so far: https://www.batteryworld.com.au/Vart...780CCA-Battery https://www.batteryworld.com.au/Vart...760CCA-Battery https://www.independentbatterydistri.../bosch-574.035 https://www.centurybatteries.com.au/.../din65lh%20agm I believe the only difference between the two Varta batteries is one is AGM and the other isn't? Seems as the consensus here is either Varta or Bosch?
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
04-29-2020, 08:16 PM | #31 |
114
Rep 410
Are you replacing the original battery? 10 years would be acceptable life expectancy.
Have a look and see what specifications are marked on the battery as I would expect that it exceeds those you have linked. A quick visual method is AGM is black top and flooded cell is white top. Replace with AGM if by chance the original has been replaced with a white top. |
04-29-2020, 10:55 PM | #32 | |
271
Rep 913
I sometimes get a low battery notification on the iDrive, i have a CTEK MXS 5.0 (12V 5A) Battery Charger which i use to charge back up overnight. I checked and its a black top Varta, the Varta AGM's are really expensive though. Was hoping to find something a bit more affordable
04-30-2020, 01:47 AM | #33 |
44
Rep 249
Went with the Varta F18 from Autobarn. Was less then $400 if I remember correctly.
AGM would have been ideal but yeah no budget for a varta AGM. F18's spec is 85ah 800cca 38 months warranty |
04-30-2020, 06:17 PM | #35 | |
271
Rep 913
Ultimately i would like an AGM as that is what is currently in the car. From the research i have done seems as though the consensus is around the community is get an AGM but im not 100% convinced that its really necessary. Does an AGM really provide more benefits then a non-AGM to justify spending? I've seen a few OEM type non AGM's that run between $2-300.
04-30-2020, 06:32 PM | #36 | |
4545
Rep 11,903
If you are still on the original battery you are doing very well but on borrowed time imo The argument re standard vs AGM battery has been going on a while Both do what they are designed to do, some from one point of view they are much of a muchness From personal experience, I always used a high quality standard lead acid battery, professionally fitted and coded. Was lucky to get a couple of years out of them and constantly getting low battery light, pop up on dash if running in aux for more then 10 mins Have switched to a AGM on my last battery change, closing in on about 18 months and has been great and no issues with low battery lights running in aux Def looking to swap the battery in the 320d to a AGM when it is next due |
04-30-2020, 06:40 PM | #37 | |
271
Rep 913
They do have the Varta E44 which i assume is the equivalent of the E39 AGM?
04-30-2020, 06:44 PM | #38 | |
271
Rep 913
04-30-2020, 09:55 PM | #39 |
899
Rep 6,285
FWIW i bought a Varta F21 AGM for $450 from battery world been good last 12 months..
My last bosch crapped out after 18 months, got it replaced under warranty and sold the replacement to get an AGM varta. If you're not in a rush, autobarn stock Varta and occasionally have 30% off them. |
04-30-2020, 10:22 PM | #40 |
1495
Rep 3,148
Yeh I had 2 Bosch batteries which crapped out (I see this is an old thread and my previous post is in here)
Went with the Varta F21 80AH because it lines up with one of the available codable options. Did not want to fit a battery that was like 85AH since the nearest codable capacities only fall on 80 or 90ah. I know in theory it should not make any difference since the battery ages and loses capacity over time anyway (and the IBS monitors battery capacity), but after 2 dead 74AH batteries just didn't want to deal with another failure
04-30-2020, 11:06 PM | #41 |
271
Rep 913
The f21 fit no problems? Seems slightly larger in length (~37mm) compared to the e39 which is recommended when searching by vehicle on the Varta website.
05-01-2020, 01:22 AM | #42 |
1495
Rep 3,148
On an E9x/E8x the tray has multiple bolting points to accomodate longer or shorter batteries. On an F30 theres only 1 bolting point so in that case the battery length matters but no such worries on e9x.
BM3Rrrr271.00 |
05-12-2020, 04:35 PM | #43 |
33
Rep 164
My Varta e44 has come up to 3 years. Perfect timing that i'm now starting to have battery issues i.e date resetting, would get a battery symbol on the dash after sitting in the car for less than a minute with the radio on. Only obvious thing in Sydney is that its colder now.
Have charge numerous times with my ctek but after a few days same symptoms. Granted i'm not driving car as much due to COVID-19. Anyways would anyone by any chance know whether the supercharge gold MF88HSS would fit? |
