07-20-2019, 11:20 AM | #68 |
4429
Rep 4,109
07-20-2019, 12:28 PM | #69 |
349
Rep 1,246
negative
07-20-2019, 01:06 PM | #71 |
4429
Rep 4,109
07-20-2019, 04:40 PM | #72 | |
463
Rep 524
When you log on the jb4, what values are you seeing for throttle position? Is it always open fully, or near there? Running my car at the drag strip, with race chip, throttle stays open all of the way (logs say 80ish percent which is normal). I went back, with rc removed, and with a mild ecu flash (a starting point), the throttle closes by over half sometimes, which lowers achieved boost and timing. Now, I did read that BMWs operate this way, and that they can make full power when the throttle isn't open all of the way. We are looking into it from an ecu file perspective, and will solve it, just wondering what others are seeing. Reading other threads, it seems as some other ecu tuners experienced this as well, mentioned they would work through it shortly, but I did not see a resolution. My amateur reading also turned up that overboost and/or loss of traction can cause the throttle to close partially. |
07-20-2019, 05:18 PM | #73 |
550
Rep 949
Throttle is used to regulate boost on the platform and both throttle blades are largely oversized for the power levels. You can make full power at around 50% throttle. If you log the factory tuning you'll see they cover around 75% most of the time. More than open enough not to limit power in any way but closed enough to be responsible to boost corrections as needed with the EWG system.
FloridaM5462.50 |
07-20-2019, 05:30 PM | #74 | |
463
Rep 524
If I added jb4 on top of the flash, and made some tweaks there, controlling the ewg system, would this allow for keeping boost (and all) higher through the end of the run? |
07-20-2019, 06:13 PM | #77 |
54
Rep 210
07-20-2019, 06:15 PM | #78 |
463
Rep 524
it did man....I meant data from the ecu or jb4. dragy looks fast
07-20-2019, 06:25 PM | #79 | |
54
Rep 210
07-20-2019, 06:27 PM | #80 | ||
54
Rep 210
07-20-2019, 06:30 PM | #81 | |||||
463
Rep 524
07-20-2019, 09:07 PM | #83 | |
575
Rep 754
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
limeypride4429.00 |
07-20-2019, 09:26 PM | #84 |
4429
Rep 4,109
It has JB4, pump gas + octane booster and BMC filters--so not quite stock but I was pleased.
For the 100k-200k data in the thread below and short of me working out an equation that ignores physics and is purely math driven, I'm curious to know if there's some 'known' formula that attempts to bring the disparate results closer to an apples-to-apples comparison? Here's what I mean outlined from both perspectives: : 60mph <--> 130mph = 97kph <--> 209kph … in MPH, timing starts sooner and ends later relative to KPH : 100kph <--> 200kph = 62mph <--> 124mph … in KPH, timing starts later and ends sooner relative to MPH |
Catchmeifyoucanf9054.00 |
07-20-2019, 09:29 PM | #85 |
4429
Rep 4,109
Who's on first2464.00 |
07-20-2019, 10:20 PM | #86 | |
IG @bmwF9xG80
3816
Rep 7,594
Says you're in California ? why using 100-200 (EU standard) should use Units 60-130mph
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
07-21-2019, 05:36 AM | #88 | ||
463
Rep 524
