car not starting...because of steering wheel lock?
12-10-2009, 10:08 AM | #1 |
39
Rep 703
i had a weird experience this morning. when i got into the car, it wouldn't start when i pushed the button. instead it had a weird icon on the dash of the steering wheel with a lock sign on it.
i pulled the fob out and back in a few times, trying to start the car every time, but no life. a very weird problem. the steering wheel lock would release (i heard it) but it would not start. after about 6-7 tries, i decided to lock the car and then unlock it using the fob. it started right away after that. since i was late for work, i haven't looked up the icon warning light in the manual. anyone know what this is?
2007 Porsche Carrera 4
2007 BMW 335i Coupe (SOLD) |
12-10-2009, 10:13 AM | #2 |
61
Rep 2,334
I had this problem last month, and learned that it's a common problem which is addressed in the TSB. Just take it in to the dealer and have them update the software. That did it for me. Good luck!
12-10-2009, 10:15 AM | #3 |
290
Rep 28,154
thats probably possible, older cars with actual keys used to not allow you to turn the key if the steering wheel was against the steering lock, you had to move the steering wheel away from the lock to get the key to turn
12-10-2009, 10:26 AM | #4 |
Smiling politely
167
Rep 7,931
FYI it's a common issue on the 06 and early 07 models. In mid-07, BMW stopped putting locks in the steering columns (for reasons unrelated to this problem). Apparently, this problem has to do with the electronic lock power draw when starting the car, and a software update normally fixes the problem. If the software update does not work, BMW replaces the steering column.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
01-21-2010, 10:59 AM | #6 |
26
Rep 513
anyone have a copy of the tsb. just had this prob on my e92 and dont want the stealer pulling a fast one on me...
01-21-2010, 12:40 PM | #7 |
40
Rep 1,159
was bored so got you this
TSB ID: 61 28 06 SUBJECT ELV Warning in Instrument Cluster MODEL E90, E91, E92 (3 Series) E60, E61 (5 Series) E63, E64 (6 Series) SITUATION The ELV (Electronic Steering Lock) check control warning illuminates in the instrument cluster and in some cases, engine start is inhibited. Diagnostics reveals fault code A0AA in the CAS (Car Access System) and prompts a control unit replacement. CAUSE Low voltages in the vehicle electrical system when cranking/starting the engine. PROCEDURE This problem has been integrated into DIS diagnostics. Follow diagnostics and relevant test plan using DIS V49.0 or later. hope it goes well for you |
01-21-2010, 05:55 PM | #8 | |
26
Rep 513
thanks. much appreciated.
01-21-2010, 06:27 PM | #10 |
39
Rep 703
curious how this came up today. car refused to start even after moving the steering wheel. tried a number of times over the course of several hours too. roadside assistance towed it to bmw toronto.
01-22-2010, 12:43 AM | #11 |
Rep 29
Well hopefully they take care of it under warranty. If not check out this post and ready my experiance with this same issue and how I fixed it. http://www.e90post.com/forums/showth...ing+wheel+lock
01-22-2010, 08:33 AM | #12 |
39
Rep 703
yeah, it's an 07 and still under factory warranty...and it's a CPO car so i'm covered til 2012. if it can't be fixed today the dealer is offering a loaner.
01-22-2010, 12:04 PM | #13 | |
14
Rep 204
sometimes on occational days a quick wiggle while putting the key in worked. |
01-23-2010, 08:31 PM | #14 | |
22
Rep 1,938
01-24-2010, 05:27 PM | #15 | |
91
Rep 856
Have had this problem before... but its very rare that it has happened to me... just slightly turn the wheel left or right... it should start afterwards
04-14-2013, 09:49 PM | #16 | |
Grozniy
179
Rep 2,602
my car is an 07 e92 with 51k miles.
Do you guys know if this TSB applies only to BMW's that are under warranty? Quote:
-fatman
04-15-2013, 03:51 PM | #17 |
408
Rep 2,704
I bet it's the battery
Test your battery. If its original its already 5-6 years old. This is how I fixed my steering lock problem. I made a thread a few months back, there's some good info in there. |
