08-16-2022, 12:39 PM | #67 |
1027
Rep 482
08-26-2022, 04:08 PM | #68 |
1027
Rep 482
Tint removed and new PPF on hood and headlights.
Closer to showroom fresh. |
09-23-2022, 01:52 PM | #69 |
1027
Rep 482
Grandad and the grandkid.
ResinThirteen190.50 |
09-28-2022, 08:55 PM | #71 |
270
Rep 367
10-04-2022, 03:50 PM | #73 |
1027
Rep 482
Installed stainless brake lines, new bleed nipples, e9X clutch delay/lock valve, new DOT4 LV fluid and flush.
The CDV is a must, what an incredible difference... especially combined with the clutch bump stop. |
asbrr544.50 ResinThirteen190.50 |
10-04-2022, 04:10 PM | #75 |
1027
Rep 482
10-24-2022, 11:24 AM | #77 |
1027
Rep 482
Swapped out the factory plastic coolant flange for the billet version from rein.
Peace of mind. Factory piece wasn't too bad, but it was definitely weakened. |
asbrr544.50 parameter416388.50 |
10-25-2022, 05:52 AM | #78 |
389
Rep 195
[QUOTE=Fishee;29475450]Swapped out the factory plastic coolant flange for the billet version from rein.
Peace of mind. Factory piece wasn't too bad, but it was definitely weakened. The replacement piece is sitting in my trunk, just haven't got around to installing it yet. |
Fishee1026.50 |
10-26-2022, 10:04 AM | #79 | |
1027
Rep 482
[QUOTE=parameter416;29478227]
I'll be changing out my diff fluid... |
10-31-2022, 11:16 AM | #80 |
1027
Rep 482
Oil change, differential fluid change, stupid retention clip popped off the top helper spring pin on the clutch pedal (pain to reinstall), replaced a couple of mashed jack points, washed and waxed...
06-04-2023, 05:57 PM | #85 |
1027
Rep 482
06-07-2023, 11:09 AM | #87 | |
1027
Rep 482
Initial bite when cold and around town, significantly improved confidence over OEM. Firmer pedal feel, very predictable and progressive initial bite (not grabby), and much stronger feeling response. High speed, same result as around town - just a better pad in every category (well, while they're new anyhow, time will tell). Low noise, really low dust, more confidence and better feel. I can now see why they're popular. Honestly, the amount of dust is about 1/10th of oem. |
asbrr544.50 |
06-08-2023, 08:54 AM | #88 | |
545
Rep 1,233
Fishee1026.50 |
