BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Nardo Grey 2019 M5, by windtendo
      12-28-2018, 12:06 PM   #45
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
A lot has happened lately... The HP fuel pump went out with only 400mi on the odometer. That took the car out of commission for 5 days. Then I just picked it up from getting the KW HAS kit installed. I have to say, this kit is EXACTLY what I was looking for. In fact, I’d argue it’s just as if not more comfortable than stock due to the progressive spring rates. I didn’t max out the front and rear which I’m sure helped. Going out of town for a few days and I’ll post some more pics when I get back in. Anyone on the fence about this should feel good about pulling the trigger on it.
Appreciate 6
      12-28-2018, 12:18 PM   #46
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Originally Posted by windtendo View Post
A lot has happened lately... The HP fuel pump went out with only 400mi on the odometer. That took the car out of commission for 5 days. Then I just picked it up from getting the KW HAS kit installed. I have to say, this kit is EXACTLY what I was looking for. In fact, I'd argue it's just as if not more comfortable than stock due to the progressive spring rates. I didn't max out the front and rear which I'm sure helped. Going out of town for a few days and I'll post some pics when I get back in. Anyone on the fence about this should feel good about pulling the trigger on it.
Car looks awesome man!!!
About progressive spring rate.... stock springs are also progressive spring rate.
You can see that on variable pitch, this is called multiple rates.
It will depend if is dual or triple rate for our cars.
Most likely is dual rate, but it also depends what the pre loads are and what deflection leads are getting used.
To make it short, the only way to find out is to check F.L., loads and rates
Anyway car is top notch man
Love it, planning any other mods?
Life is too short...enjoy your life
///M
      12-28-2018, 12:24 PM   #47
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Most likely is dual rate, but it also depends what the pre leads are and what deflection leads are getting used.
Ok thanks for explaining, wasn’t sure what it was stock but it’s a really comfortable ride with the KW kit on
Next up most likely Akra in Jan/Feb. I just added a couple of quick snaps before I leave to the last post above.
      12-28-2018, 02:38 PM   #48
norbtx
norbtx's Avatar
337
Drives: 2019 BMW M5
Man that’s a nice drop. Where’d you get it done?
      12-28-2018, 03:13 PM   #49
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Eurocharged did it, and I would absolutely recommend them. Once they finished the install, they had me back over to dial in the correct height— even using calipers to make sure both fronts and both rears were completely even. Very reasonable as well.
      12-28-2018, 08:52 PM   #50
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Looks great!!!
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      12-30-2018, 07:12 PM   #51
mrp3846
78
Drives: 2019 M5 CP
2019 BMW M5 CP  [0.00]
awesome and congrats..
      01-02-2019, 10:37 AM   #52
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Originally Posted by josec70 View Post
Looks great!!!
Thanks man, it's nice to have that done. I was worried about the install but it went rather smoothly. Now that it's had time to settle, I'm considering going just a tad bit lower.
Will try to knock that out Friday along with an alignment.
      01-02-2019, 11:10 AM   #53
josec70
josec70's Avatar
Looks great!!!
I usually do the same after they've settled so that you can really dial it in; alignment is a good idea.
I'm still waiting on my wheels so will be doing the KW HAS at the same time as the wheels.
      01-02-2019, 02:34 PM   #54
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Wheels AND a drop... Your car is going to completely transform overnight! Looking forward to the end result!
Care to share which Velos wheel you went with? My guess is the S3.
      01-02-2019, 03:52 PM   #55
josec70
josec70's Avatar
Will PM you.
      01-07-2019, 08:43 AM   #56
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Wasn't able to readjust the height with the KW HAS kit on Friday now that the springs have settled, but I did have time to get a good wash...
Appreciate 3
      01-07-2019, 01:37 PM   #57
///M ARMY
1003
Drives: F90
How's the has kit? I heard it's pretty bouncy
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      01-07-2019, 04:05 PM   #58
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
The ride feels exactly like stock. I'm going to go another 1/8 to 1/4 inch all the way around so I'm expecting it to firm up ever so slightly. I've seen some on here where the rear seems a little lower than the front, and that will absolutely make it bouncy. As long as the front is slightly lower or even with the rear it rides just fine
      01-07-2019, 05:26 PM   #59
josec70
josec70's Avatar
I've had KW HAS on two F10 M5's and will be going this route on my F90 M5C. In my experience (limited to F10 platform) they've been phenomenal w/ much less bounce than fixed height springs (H&R in my experience).
      01-11-2019, 11:20 AM   #60
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Close up from yesterday... The only chrome left is the exhaust -- I'm on a mission!
Appreciate 3
r33_RGSport12971.00
josec704074.00
      01-12-2019, 08:46 AM   #61
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Bouncy is relative word.
Some people are ok with H&R spring, some says it is bouncy. (Same car, same spring).
But KW HAS, as applies to any other lowering, if you go too low and you are riding on the bump stop. Then it will be bouncy.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Miko M6655.50
      01-12-2019, 09:30 AM   #62
josec70
josec70's Avatar
The great thing about the KW Kit is that you can adjust as much as you want to minimize the bounciness and experiment with different ride heights.
With fixed height springs you're basically stuck w/ what you get.
      01-12-2019, 10:07 AM   #63
r33_RGSport
Agreed.
      01-12-2019, 12:17 PM   #64
Miko M
///M
Miko M's Avatar
There is NO bouncy Springs!!!!
The only thing you can change on Spring is the preload and the Rate.
Like Ben sed if is to low you might hit the stops.
///M
r33_RGSport12971.00
      01-14-2019, 10:04 AM   #65
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Agreed! I lowered it an additional 0.2" around and it still rides exceptionally well. It's slightly noticeable now as far as firmness goes. Basically feels like Sport mode (not Sport +) is the new Comfort mode setting. Keep in mind, this is on a base m5, so M5C owners may not feel a change at all.
      01-15-2019, 06:37 PM   #66
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Quick Target run last night and walking back to the car I just HAD to...
Appreciate 2
