08-17-2019, 09:09 AM | #1 |
87
Rep 230
Exhaust - M5 vs M5 comp
I see that only the M5 comp gets the sport exhaust system. Has anyone noticed a difference between the 2 exhausts? Unfortunately, my local dealer doesn't have both cars
08-17-2019, 09:25 AM | #2 | |
4077
Rep 5,235
This is subjective and based on what you like; you can install an x-pipe in the mid-section or go w/ an aftermarket exhaust. I replaced the Sport exhaust on my M5C with an iPE system and I could not be happier. Really depends on what you like and the type of sound you want.
08-18-2019, 03:02 PM | #5 |
4077
Rep 5,235
I don't believe you can option the Sport Exhaust on the standard car if I recall correctly.
08-18-2019, 03:28 PM | #6 |
219
Rep 291
yes, you can
2023 M5 Comp Skyscraper Grey,Executive Pack, Drivers Assistance, B&W, 789's. |
08-18-2019, 03:44 PM | #7 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
08-18-2019, 03:50 PM | #8 |
68
Rep 238
08-18-2019, 03:53 PM | #9 |
4077
Rep 5,235
This is not Sport Exhaust .... this is M-Performance Exhaust.
08-18-2019, 03:55 PM | #10 |
4077
Rep 5,235
Exhaust is all about sound ... power gains are negligible.
08-18-2019, 03:56 PM | #11 |
4077
Rep 5,235
Correct
08-18-2019, 04:02 PM | #12 |
94
Rep 419
08-18-2019, 04:10 PM | #14 |
219
Rep 291
If you are leasing you end up only paying about half the cost. So if you want the base suspension and the M Exhaust from BMW this may be worth it to some so it is all installed by BMW and can be turned in at the end of the lease as is.
08-18-2019, 04:11 PM | #15 | |
4077
Rep 5,235
When I spec'd my M5C the Sport Exhaust was not an option on the Base M5. First Edition M5's did come with Sport Exhaust if I'm not mistaken. This was also the case in the F10 M5 platform.
08-18-2019, 05:16 PM | #19 |
1118
Rep 1,809
Wow 7100!! Better off just buying M5C and getting all the other perf improvements the comp gets
2024 Porsche 911 GTS Cabriolet
08-18-2019, 05:59 PM | #20 |
Rep 11
08-18-2019, 06:14 PM | #21 |
108
Rep 119
08-18-2019, 06:40 PM | #22 |
71
Rep 40
M5C does not come standard with M performance exhaust. It comes standard with the M sport exhaust.
I believe the M sport exhaust is around $1400 option if you want it with a non comp M5. |
