BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    what size tires for stock 20" rims
      11-18-2019, 07:22 PM   #1
Catchmeifyoucanf90
54
Drives: f90 white m5
I want to put 305/35/20 in the rear and then 285/35/20 , will that fit or cause problems. Also have any advice on what size or brand. I'm looking at Michelin pilot cup 2 sport
      11-18-2019, 07:34 PM   #2
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
I run 295s rear and 285s front--no known issues after 4,000 miles. 305s will probably fit onto the rear wheels but it'll be a stretch both figuratively and literally (perhaps others that have done it can comment). My worry would be the tolerances of the Xdrive system between front and rear. I've spoken to folks offline who are running your proposed setup and have experienced oddities--tough to say whether it's the imbalance in the rolling circumference.
I run Michelin Pilot Spot 4Ss since I need a bit of wet-weather capability. I can't speak firsthand to the Cup 2s but reviews indicate they're amazing performance/track tires--perhaps overkill for road-only scenarios.
      11-18-2019, 07:56 PM   #3
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
i wouldnt change the ratio of tire size. if youre doing 305 rear the. you should check to see if you can fit 295 front.
or risk destroying your diff
      11-19-2019, 01:22 AM   #4
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
Yep, you need to keep the ratio as close as possible. You'll need 295 in the front.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
      11-19-2019, 06:35 PM   #5
Catchmeifyoucanf90
54
What's a good price on these tires by the way?
      11-19-2019, 06:38 PM   #6
limeypride
limeypride's Avatar
Long thread, lots of suggestions--which tires?
      11-19-2019, 07:03 PM   #7
Catchmeifyoucanf90
54
      11-19-2019, 07:20 PM   #8
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
That's about a 1.8% + on circumference between front and rear versus 1.1% OEM. As long as you stay within 1%+/- from OEM you should be fine.
Been running 295/30/21 & 275/30/21 on my M5C for 6k miles w/ zero issues ... this setup is also +1.8%
Good luck
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      11-19-2019, 07:30 PM   #9
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
If you're doing the SC2 in 20", the closest front to rear ratio to stock are the 285/30 and 305/30. Michelin doesn't make a 35 sidewall in either the 295 or 305, so you have to go almost an inch less in overall diameter compared to stock, but the ratio front to rear is still very close. Closer than the difference BMW allows for their winter tire combo of 285/40-19 and 265/40-19.
I just referred back to the email BMW sent out 11/1/19 which linked to their catalog recommendations for winter tire fitment. I wanted to confirm and they did specify the 285/40-19 and the 265/40-19 tire combination for winter use.
I hadn't considered the 295/30-20 SC2 for the front, but now I wonder if it would have fit? I'll have to check my clearances with the 285/30-20 at full lock to see if the wider 295 will actually work. I'll do that next time if it will. I do have aftermarket 10" front and 11" rear wheels.
      11-19-2019, 07:59 PM   #10
josec70
josec70's Avatar
I just referred back to the email BMW sent out 11/1/19 which linked to their catalog recommendations for winter tire fitment. I'm quite sure when I first looked at it there were two pages for the 2019 M5, now they aren't there! It stops at the M3/M4, very odd. They did specify the 285/40-19 and the 265/40-19 tire combination for winter use. Has something changed?
The 265/40/19 and 285/40/19 setup is a +2.6% on circumference. I don't want to speculate but maybe that's a higher tolerance than they're willing to recommend .... just a thought.
      11-19-2019, 08:09 PM   #11
Used2be
Perennial PFC
Used2be's Avatar
I went back and looked at the email again. I had clicked on the summer tire section, not the winter. The M5 is still listed with the 265/40-19 and 285/40-19 tire selection for the winter. Maybe sizing isn't as critical as we make it out to be? I'd like to know for sure!
      11-19-2019, 08:12 PM   #12
josec70
josec70's Avatar
I agree on the sizing .... even at +2.6% you should be fine more so if BMW is offering this setup.
      11-19-2019, 08:41 PM   #13
limeypride
limeypride's Avatar
Good info, guys—that's gonna be useful going forward.
      12-12-2021, 07:41 AM   #14
hjl113
hjl113's Avatar
South Korea
17
Drives: F10 M5
Is your front 285/35/20 and rear 295/35/20 on the OEM wheel that came with the car? Any noticeable difference in cornering?
      12-12-2021, 08:56 AM   #15
limeypride
limeypride's Avatar
It was. Now I run that setup but with a 30% profile. Other than slightly less chirp during launches, it feels the same.
      12-12-2021, 09:21 AM   #16
hjl113
hjl113's Avatar
South Korea
17
Drives: F10 M5
Good to know that 285 can be safely put on 9.5 oem wheels.
Any reason to go from 35% profile to 30%?
      12-12-2021, 01:39 PM   #17
limeypride
limeypride's Avatar
Looks.
