front suspension squeak
04-20-2024, 11:15 PM | #1 |
Rep 15
before you get angry that there are tons of posts already, i saw over 50 articles and could not find anything helpful for my issue.
I have this squeak from front right over bumps or dips. i have brand new sachs struts and shocks. rubber pads on shocks are news. both lower control arms are new with old hardware. shock mount is newer (10k kms). tie rod on front right is also new. I made sure no wires or anything is dangling or rubbing underneath. sound seems to be coming when strut rebounds from normal position or compressed position. I also disconnected both sway bar links to eliminate sway bar links or bushing as the culprit. also checked strut tower braces and they are tight. https://youtube.com/shorts/3NIVPzWKcHo posting a video along with this. This is just driving me crazy. any help would be appreciated. |
04-21-2024, 09:55 AM | #2 |
319
Rep 565
high pitch noise is usually from a ball joint. there are 4 main front arms total, Both (oe/oes)? could be a lot, its either poor install, bad parts, or not enough parts based on what u said.
https://www.ebay.com/itm/28265455896...xPwd4B4WuoS6e8 |
04-22-2024, 01:34 PM | #3 |
27
Rep 47
Any ball joint or something is going on with damper itself. Best way will be to go for some kind of vibration plates, where you can swivel the car with high frequency (In Poland we have something like that during our MOT check). If you want to check ball joint without removing anything, you can take syringe with some kind of lubricant in it and put through rubber boot directly into ball joint one by one. But best way will be just to disassemble everything and check part by part what is going on. Bushings will squeak, but with way lower frequency, like an old sofa.
05-02-2024, 05:30 AM | #5 |
Rep 2
Hi there, have you managed to solve this issue? I think I've got the same problem here. My front suspension produces the exact kind of noise when going over bumps
05-05-2024, 01:31 AM | #6 |
Rep 15
aaronld not yet . i attached chassis ear tool to multiple parts in suspension and found out squeaking coming from the hub, coil and the strut itself. seems like travelling sound from one part to another. I talked to fcpeuro and they are sending me a new strut and I will once again order new rubber pieces and mount. lets see how it goes. i am just so done with this. I will also replace control arm nut and bolt.
05-09-2024, 12:12 AM | #7 |
Rep 2
Thank you for the update.
My story is a bit trickier. I bought this car last year and I had the dealer change out the struts and strut mounts. When I got hold of the car, both sides of its front suspension were producing this distinct noise. The dealer had no idea where it came from. I was so fed up with it that last month I got a car mechanic to change out literally the entire front suspension. That included 2 struts, their mounts, and all bars and rods except for the steering tie rods. And all parts I ordered were OEM parts. Now my right wheel suspension is quiet and good. But the left side still makes that same noise when going over bumps, although it sounds more subdued than before. But I can tell it's still there. The car mechanic is also scratching his head over this. He suggested I drive the car for a while to see if the noise goes away. |
05-22-2024, 09:54 AM | #9 |
27
Rep 47
To be honest the best way will be just to disassembly everything and check every part separately. I was chasing front knock for a year, apart from the fact that I had complete new suspension. When I removed everything from the car I found out that my input shaft from steering rack had little bit of play, at it was cause of my knock. When you have a squeak, maybe you will feel some wired drag when moving ball joint, or you can just push manually on the struts. I know that this will take some hours in the garage, but you can save some money with only couple of beers during wrenching
Tags |
suspension squeak |
