12-06-2018, 01:02 PM | #1 |
2118
Rep 2,014
HRE Wheels | Track Ready F90 M5 with HRE RC104's in Satin Gold!
Here we've got a lovely F90 M5 which will see some track time for sure! For his Track Beast we wanted to get a set of RC104's on there to help lower the weight significantly and to also give it some updated looks! 20x10 fronts with 285/35/20 tires 20x11 rears with 295/35/20 tires HRE RC104 - Satin Gold Finish Thanks for taking a look! |
12-07-2018, 10:00 AM | #4 |
2118
Rep 2,014
I weighted the wheels before we released them to the customer, here are the weight figures as compared to OEM, it's quite impressive:
HRE RC104: 20x10 - 22.00lbs 20x11 - 23.20lbs BMW OE Competition Wheel Weight 20x9.5 - 28.00lbs 20x10.5 - 29.50lbs Weight info was taken from this post HRE Weight Savings for RC104 Fronts - 6.00lbs per wheel saved - 12lbs in total up front Rears - 6.30lbs per wheel saved - 12.6lbs in total on the rear Total weight saved, 24.60lbs of unsprung weight. For those of you who want to save even more, then these bad boys would do the trick, a set of R101 Lightweights in 20": HRE Weight Savings for R101 Lightweight Fronts - 9.8lbs per wheel saved - 19.60lbs in total up front Rears - 10.7lbs per wheel saved - 21.40lbs in total on the rear Total weight saved, 41.00lbs of unsprung weight. |
12-07-2018, 10:24 AM | #5 |
3619
Rep 4,532
20” cast oem front = 35lbs. Rear = 36lbs. That would be a 52lb savings in rotational weight with the HRE.
HRE_Wheels2118.00 |
12-07-2018, 01:30 PM | #6 |
1182
Rep 1,658
Unbelievable weight savings with these. I think a Brushed Clear finish would bring out the design of the RC104's even more. I can't wait to get a few of these on some F90's. |
HRE_Wheels2118.00 Quickburn7956.00 |
12-24-2018, 08:34 AM | #10 |
1182
Rep 1,658
12-24-2018, 12:30 PM | #12 | |
1182
Rep 1,658
The ones shown weighted above were for our F90 client who was the very first to get the R101 LW's on an F90 M5. We've been building the R101 LW's for this vehicle at ET 23 & ET 29. Feel free to email me directly if you'd like more information - David@WheelsBoutique.com |
Jonathan G.9.00 |
01-03-2019, 03:21 PM | #13 |
232
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Here's my RC104 w/tires vs OEM setup comparison.
HRE_Wheels2118.00 Jonathan G.9.00 |
01-03-2019, 05:09 PM | #14 |
36
Rep 84
01-03-2019, 11:33 PM | #15 | |
232
Rep 1,481
Complete build can be tracked here: https://f90.bimmerpost.com/forums/sh....php?t=1568373
01-13-2019, 04:05 PM | #16 |
70
Rep 175
The gold is an interesting look. Have you got any images showing the gold in more of a gloss finish or even the hre 540 with the gold/gloss lip?
01-14-2019, 04:41 PM | #17 | |
1182
Rep 1,658
Here's a good look at Gloss Gold on S101's. For the 540's I see a Brushed Gloss Gold done but not a Gloss Gold. I can share those images with you as well - David@WheelsBoutique.com |
01-14-2019, 06:10 PM | #19 |
36
Rep 84
I've got a question for all you wheel and tire gurus.
I want to go with 21" wheels but stick with the PS4S tires, rather than go back to PSS's. That means I'll probably stick with a 275 tire on the front (same as OE width), but go to a wider 295 on the rear (given there is no 285/30/21 size for the PS4S). Does this present any issues for the 4WD system etc? Since I've gone one size wider at the rear but stuck with OE at the front, and the diameter of the new tire combination is a slightly bigger difference between front and rear? Anyone upgraded to the below sizes and have any feedback? F: 21 x 9.5 275-30-21 Michelin PS4S R: 21 x 11 295-30-21 Michelin PS4S |
01-15-2019, 01:47 PM | #20 | |
2118
Rep 2,014
01-15-2019, 08:07 PM | #21 | ||
70
Rep 175
Meaning how much are they? |
