07-29-2021, 01:06 AM | #1 |
218
Rep 548
Coolan temp dropping
Anyone else notice their coolant temp dropping when on the highway after city driving? I hit the freeway home and noticed the coolant temp drop a few mm under the 100c mark... Typically its slightly over 100c driving around town...
07-30-2021, 09:37 AM | #2 |
4154
Rep 7,169
Drives: F90 M5 / F15 50i
Lot more air flow over the engine…pretty standard.
'07 Yamaha R1 (sold)
bimmerbeast7169.50 |
07-31-2021, 07:45 AM | #4 |
1913
Rep 4,128
Drives: M235i & G30 540i
I think he means engine temperature.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
07-31-2021, 10:35 AM | #5 |
218
Rep 548
No, its not pretty standard, most engines have spring pressure thermostats that regulate operating temp ~95c, most of my vehicles regulate around that temp, but this M5 seems to drop down quite a bit from normal operating temp which is usually slightly over 100c... I guess it might be hard to tell since there isn't a numbered digital read out how far its actually dropping, but it seems like quite a bit.
07-31-2021, 06:11 PM | #6 |
218
Rep 548
Just drove 400km to the mountains at about 140-150kmh, car ran slightly above 100c…
It seems to drop when rip around town and after hitting a freeway for a min or two… |
08-03-2021, 02:54 AM | #7 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
I haven't looked into the specifics of this M5, but on previous M's (and non-M's for that matter) that I've owned, the temp gauge isn't really connected directly to coolant temperature in the classic sense of direct temperature reading. It's a gauge who's output comes from the computer, which is an amalgamation of oil temp and coolant temp and who knows what else.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
08-03-2021, 06:43 AM | #8 |
5293
Rep 10,686
My 2018 runs at 250F. I almost always drive in efficient mode. Time in Sport mode is intermittent and I have never paid attention to see if oil cooling is better then.
250F is 120C. I agree it is hotter than I would choose and probably done for fuel economy. Likely someone makes lower temp thermostats but I am not sure whether coding or tuning is needed for any related computer stuff. |
08-03-2021, 03:02 PM | #9 |
83
Rep 37
2018/2019 M5 temperature gauge measures oil temperature. Fully synthetic oils can run at temperatures above 150c/300f so a fully warmed up reading of 120c/250f is fine. 2020 and newer M5's measure coolant temperature. If your oil temperature was only getting up to 100c/212f when the vehicle was full warmed up you would cause water buildup in the crankcase as the oil would never get hot enough to boil off condensation that forms when the engine oil cools to ambient temps.
VPRKLR63.00 |
08-03-2021, 05:59 PM | #10 | |
47
Rep 58
bimmerbeast7169.50 Pugnacious82.50 |
08-03-2021, 11:23 PM | #11 | |
4154
Rep 7,169
It's also electronically controlled vice mechanically if I recall a previous post discussing "colder" thermostat mods. I did one on my AMG but the main issue discussed here is that since the ECU controls it, how effective would it be. Either way I'm generally not concerned if my engine is running cooler than normal. Especially when it's cooler outside as you stated. Maybe it just hadn't warmed up all the way yet. Maybe it's just taking longer.
08-04-2021, 02:50 AM | #12 | |
170
Rep 229
08-04-2021, 02:53 AM | #13 |
170
Rep 229
08-04-2021, 03:05 AM | #14 | |
170
Rep 229
Optimal operating temperature range for motor oil is 180-220°F Which makes you love BMW even more as it always keeps my oil at 190-200.. only when driving it hard will it touch 217°F Dudes get horse cum in their motor from never getting their motor up to operating temperature (200°F) .. like driving only 3 miles to work or keeping it in the garage all the time and only driving it a few miles to get gas and then back to the garage for months and months but 250°F?? hell no. your motor is too hot if it goes over 220°F Last edited by bimmerbeast7; 08-04-2021 at 03:41 AM.. |
08-04-2021, 03:07 AM | #15 | |
170
Rep 229
Running high revs/running hard in a hot environment will make any motor hotter |
08-04-2021, 03:30 AM | #16 | |
170
Rep 229
lower engine temperatures equal higher performance (m car setup) They build M cars to run cooler because motors makes more power at cooler temperatures (And you'll hear educated individuals say that coolant systems on m cars are very well sorted) beginner stuff here. intercoolers purpose is to push fluid through it and lets air pass through it to cool that fluid. more air and cooler air = better cooling and lower temps so of course if you're in stop and go traffic your motor is relying on only the fan to push air through the intercooler as opposed to you actually driving and the big grills and inlets on the front of the m5 are able to gobble up some air and pass it through the intercoolers and cool the motor, coolant, and oil all much better and more efficiently I assure you the car likes to run at about 185-190° for the most power and once you push it hard it will get up to 210 220 but not any higher if it does you need to stop driving it so hard and chill out and let it get air (A.k.a. drive it at a decent speed at low RPM , not stop at a red light..) and never cut your car off hot. never. worst thing for a motor Ive found 2500 RPM pulls coolant through the motor fast enough but it's low enough RPM that it can cool and cools it the quickest Cruising in Top Gear at 1500 RPM doesn't really push coolant through the motor fast enough and doesn't do the best job at cooling my F10 was tuned with downpipes and it never went over 212°F unless it was over 85°F outside hot air doesnt cool very well Most interesting part I learned from the F10 though was if I drove over 100 miles the oil and coolant temperature would get better and better at stabilizing and both would get 190°F and wouldn't budge because all the oil and coolant had fully passed through the system and was all fully acclimated fun stuff |
08-04-2021, 07:10 AM | #17 |
5293
Rep 10,686
These intercoolers are air to water units. Air from the turbos passes through and coolant in them that is cooler than the air cools the air. Since the coolant is absorbing heat, it is then pumped through an additional radiator to cool the coolant so it can keep doing the work of taking heat out if the air. The intercooler coolant system is entirely separate from the engine coolant system and operates at close to ambient outdoor temperature.
As for engine oil and coolant, oil runs hotter than coolant and it should. As others noted, condensation from warming up a cold engine can add a tiny bit of water to the oil and the oil needs to reach the boiling temperature of water or 212F to eliminate that water. It is perfectly OK to have oil much hotter than coolant. Modern oils can handle 250F no problem. Coolant temperature should be lower. Pressurized coolant might not boil until 265F, but running the engine that hot can result in detonation. I agree with sticking to the range of 180-220F for coolant if possible. I have actually not yet paid any attention to the coolant temp. I will take a look. Down the road, if I keep the car, I will look into modifications for the cooling system, oil cooling system, and air to water intercooling system. For now I am OK with the performance in the relatively cool New England area where I live, with just a JB4, 93 pump gas and water methanol injection. Last edited by pbonsalb; 08-04-2021 at 05:55 PM.. |
08-04-2021, 05:18 PM | #18 | ||
83
Rep 37
///M Power-Belgium64827.00 |
08-04-2021, 05:54 PM | #19 |
121
Rep 201
There's so many electronics in this car, you pretty much have to rely on the car's fault message prompts to notify you if there is an issue. When BMW decided to do away with the dipstick for the oil, I had to just rely on the system to tell me when I needed to top off the oil on my F10 550i and same now with the F90 M5.
08-05-2021, 09:32 PM | #20 | |
170
Rep 229
but normal operating temp is 180°F to 220°F .. If either your coolant tip or oil temp is reading 250°F your car is crying for you to take care of it and let/help it cool down |
08-05-2021, 10:39 PM | #21 | |
83
Rep 37
When my M5 is fully warmed up after 5 to 10 miles of driving the temp stays right at the middle 250F mark. The 2018/2019 M5 had the "old style" instrument display. I have never seen the newer display in person but I did find an image of a 2021 UK spec M5C on the internet and it was clearly marked 100C with the little oil symbol under the °C marking. Now I am assuming that is the oil temp but I know the newer display has a lot more features than my 2019 M5 and as some have stated on this thread you can read both coolant and oil temp on the newer M5 whereas my 2019 M5 only has a idiot light for coolant. So my seemingly stupid question is, do the 2020 and newer M5's with the new instrument display run at a lower oil temperature (100C/212F) as my 2019 is running great with no oil consumption at 250F. |
08-05-2021, 11:33 PM | #22 |
218
Rep 548
My 21 runs oil at 100c.
Coolant runs slight over 100c, then randomly drops like there is a second thermostat that opens.. It must drop down to around 90c or lower, its a very noticeable drop.... A solild 2/8th or 1mm under 100c mark... |
