09-01-2023, 09:12 PM | #1 |
112
Rep 216
Two Piece Lightweight Steel Rotor set
TLDR - I need lightweight 2 piece rotor recommendations. Labor Day weekend sale prices would make it even better!
Alright, I have scoured for the last couple months for F&R real 2-piece rotors. I found the Racing Brake setup for $3100 with their own pads. Their rotors are 5mm smaller but seem pretty insignificant. I recently went with EBC blue stuff pads on OEM rotors and when I installed the pads they were a little tight in the calipers. On my second bed in cycle the pads got hot and one hung up and get really really warm and has me leary of keeping these rotors on the cars the pads I had to sand some of the painted/powdercoat from the edge as it made the pad fit too tight. I definitely need/want new rotors. Thinking of running two sets of pads, a track pad and a street pad that I will swap out before we hit the track. With that said, who, besides Racing Brake makes a true two piece rotor for these cars? SHW does a pinned two piece (OEM) that has honestly done great. The dissipate heat and are genuinely great brakes. Just looking for that next edge and first hand experience examples would be great! |
09-01-2023, 10:04 PM | #2 | |
133
Rep 392
Drives: 2021 M5C
09-01-2023, 10:35 PM | #3 |
112
Rep 216
09-04-2023, 10:29 AM | #5 |
112
Rep 216
I am unaware if Coleman or any others. I have a contact that has made custom hats for misc cars including doing custom hats for a 2005 excursion so we could run ginormous brakes and calipers due to what we were towing couple with 22” wheels and big tires. I figured worst case I can explore having him do the hats.
10-06-2023, 02:48 PM | #8 | |
112
Rep 216
They have a host of machine patterns for the disc with their J-hook being most aggressive. Last edited by CrashCade; 10-06-2023 at 07:41 PM.. |
10-06-2023, 09:15 PM | #9 | |
133
Rep 392
Drives: 2021 M5C
10-13-2023, 04:58 PM | #13 |
112
Rep 216
I will weight mine when they show up. The options available for machining seem beneficial even if weight reduction isn’t a drastically haven’t a more aggressive pattern should be.
10-24-2023, 01:08 PM | #15 | |
IG: @M5RCY_
365
Rep 317
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
10-25-2023, 04:15 PM | #16 |
497
Rep 234
Drives: 2020 M5 Competition
11-01-2023, 01:33 PM | #17 | |
1834
Rep 1,326
Shawn |
11-01-2023, 10:10 PM | #18 |
133
Rep 392
Drives: 2021 M5C
I tried to call as well with no luck. Hope another option appears this winter.
shawnhayes1834.00 |
11-02-2023, 06:58 AM | #19 |
112
Rep 216
I will shoot these guys an email and ask what that is all about. They definitely are not cheap. For the amount of money, you would hope customer service is at the top of the game.
shawnhayes1834.00 |
11-02-2023, 07:09 AM | #20 | |
1834
Rep 1,326
Sounded like somebody running parts out of their garage. Maybe so. And maybe they’re fine. The DID call me back. They DID leave a message. But first impression was not inspiring, especially when BMW OEM rotors, which work well on the street AND track are 1/2 of that. Not so much. I’ll wait until somebody else gets them and uses them. Shawn |
11-02-2023, 07:53 AM | #21 |
5234
Rep 10,616
Since Shawn tracks his car a lot and says stock steel or ceramic brakes both work well, the advantage of the more expensive true 2 piece rotors would be weight savings. Reducing unsprung weight does improve handling, but Shawn actually removed his light weight carbon rotors and installed much heavier steel ones and is not saying there is a significant difference.
The OP’s 2 piece aluminum hat and steel rotor ring combination is going to be closer in weight to stock steel rotors than to the factory option carbon rotors so even less of a performance benefit. |
shawnhayes1834.00 |
11-02-2023, 12:34 PM | #22 | |
1834
Rep 1,326
HOWEVER, if this two piece rotor was from Brembo, or stoptech, or girodisc? In a heartbeat. I'd at least TRY it. Maybe end up going back to the BMW's. Shawn |
PDOT133.00 |
