07-19-2022, 12:21 AM | #111 |
72
Rep 164
Anyone here know why the Dinan rear kit come with 4 arms while the carbahn only has 2? Or is the Dinan kit made more for the base car and the carbahn for the comp cars that already have the other ball joint?
The front kits look similar i only noticed difference in the rear kit |
PDOT130.00 |
07-19-2022, 07:21 AM | #112 |
5234
Rep 10,616
The Dinan kit does seem to make more sense for the base car, which is why I ordered one and am waiting months instead of just buying the Carbahn.
07-19-2022, 07:38 AM | #113 | |
294
Rep 195
07-19-2022, 07:43 AM | #114 | |
130
Rep 391
Drives: 2021 M5C
07-19-2022, 08:51 AM | #115 |
130
Rep 391
Drives: 2021 M5C
That's the part that makes me wonder what Carbahn knows that made them only create the part. I saw in Steve's interview it looks huge, idk what Dinan's piece looks like in comparison
07-19-2022, 03:33 PM | #116 |
72
Rep 164
After talking with Carbahn I went with theirs. They say the other arm for the rear isn't necessarily and they seem to be beefier than Dinan. Both are probably really good quality
08-17-2022, 12:45 PM | #117 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
idk why bmw always wants to replace them. they're not aluminum bolts and nuts.
'07 Yamaha R1 (sold)
08-17-2022, 01:29 PM | #118 |
4140
Rep 7,160
This is what i've found so far. The other bolts and nuts are a bit confusing as the diagrams don't exactly line up and they're all called the same thing but cost different, lol
axel bolt: 31-20-6-866-022 Clip nut: 33-30-6-760-349 Lateral Arm Retainer Nut: 33-30-6-760-349 Lateral Arm Bolt: 31-10-6-871-189 thoughts?
Holset274.00 |
08-17-2022, 01:47 PM | #119 |
5234
Rep 10,616
I typically don’t replace everything the bmw manual says to replace, but I am just a DIYer. Aluminum bolts, yes — I changed those on my E90 M3 and E61 535xi oil pans when doing rod bearings and of course the rod bearing bolts. But when I installed the Dinan monoballs on the M5, I reused the suspension bolts and nuts.
Holset274.00 Maverik2594140.00 |
08-17-2022, 01:54 PM | #120 | |
Perennial PFC
336
Rep 1,275
Two 31-20-6-866-022 collar screw w/spring Two 31-10-6-871-189 torx screw with collar Two 07-14-6-875-114 hexagon nut One 31-10-6-867-561 clip nut. left One 31-10-6-867-562 clip nut, right This what I needed for the tension strut when I did the monoball. |
Holset274.00 |
08-18-2022, 05:53 PM | #121 | |
294
Rep 195
(2) 31106780613 - Combination Nut (2) 31106871189 - Torx Screw w/ Collar (2) 31206866022 - Collar Screw w/ Spring (2) 33306760349 - Self Locking Nut - This is an alternative for the clip nuts. You'll need to knock the nut out of the clip and insert a new one. The reason for replacing all this hardware is that it is all torque to yield. You can tell from the torque + additional angle torque spec. TTY hardware can only be properly torqued once since it stretches permanently. |
Maverik2594140.00 |
08-18-2022, 09:08 PM | #122 |
5234
Rep 10,616
That is not necessarily true. BMW has simply determined that angle torque is more reliable than a specified lbs or NM as the final stage since it reduces friction variables. It does not mean BMW is pushing the spec closer to the yield point.
Ideally you would measure the bolt length to determine if it has stretched but you need the original measurement spec. Certainly it does not hurt to buy new hardware anytime you change a bolt that has been torqued, whether or not the final stage is angle or lbs/Nm, but you do not necessarily have to spend the money. |
08-22-2022, 12:45 PM | #124 | |
4140
Rep 7,160
Edit: well I suck at these kinds of things. I probably couldn't tell the difference between the base and a comp much less a CS lmao. I never know what suspension setting I'm in. With that said. I think I can notice a difference haha. I can't tell if it's just wishful thinking but I think it feels more responsive in the turns. Steering feels more connected too. Cost me $500 to install and do an alignment. They claim they didn't have to remove the bearings either which I found interesting.
02-18-2023, 07:13 AM | #126 |
608
Rep 747
For those of you that have been running these for a while now: Are they making any “noise” or otherwise adverse sound? Also, do they require regular greasing/maintenance? If so, what is that process and is it easy DIY?
02-18-2023, 09:31 AM | #127 |
Perennial PFC
336
Rep 1,275
I’ve only had them installed for a year, but no noise at all. The bearings are sealed and with the minimal movement they travel through and the nylon lining I’d imagine they will last many years with no maintenance.
02-18-2023, 12:26 PM | #128 |
608
Rep 747
thanks so much for the feedback! Everyone seems to love them so super excited to get them on in a a month or so
04-14-2023, 11:26 AM | #131 |
608
Rep 747
Just got mine installed and thoroughly enjoyed my drive back from shop ripping down the twisty backroads! As cliche as it sounds, the car handles like an extension of my hands now
Dinan_Engineering3910.00 |
04-14-2023, 09:58 PM | #132 |
258
Rep 234
Drives: 2022 M5C /// 2023 XDrive40i
Glad you got this done. It was literally one of my first mods when I got the car (even before any cosmetic items) - in a bid to get the steering feel to be like the BMWs of yore.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
