06-15-2022, 08:56 PM | #89 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
06-15-2022, 10:22 PM | #90 | |
4140
Rep 7,160
06-16-2022, 06:46 AM | #91 |
5234
Rep 10,616
Yes, sometimes you have to get creative with the pressing and receiving forms. To do on the car you need a receiver as well. Before buying I would measure the outside of the unshouldered part of the monoball for a pusher form that will push against the stock bushing metal sleeve and estimate how much bigger a receiver you would need if doing on the car (can’t go too big or it won’t stay in place on the arm and will cockeye. I have not studied the monoball or arm yet.
Maverik2594140.00 |
06-17-2022, 12:04 PM | #92 | |
4140
Rep 7,160
06-28-2022, 09:42 AM | #93 |
294
Rep 195
I installed my set of Dinan monoballs yesterday and can confirm that they are transformative to the car's steering response and feel. I can feel my that inputs are immediately transferred to the tire and that they only delay in lateral response is down to sidewall deflection of the tire. In addition, the car feels much more planted at the onset of heavy braking.
I was able to complete the install on both sides in around 2 hours. I completely removed the tension struts per the BMW shop instructions so that I could use my 20 ton shop press to remove the stock bushings. After a little cleanup with a scotchbrite pad and removal of one burr with a file the new bushings slid right into place. It's not an interference fit, which would require a press or heat/cooling to install, but the tolerances are very tight. |
Holset274.00 |
06-28-2022, 10:27 AM | #94 |
5234
Rep 10,616
Did the ball joints in the hubs come out easily and without pulling the axles? I did not have the BMW shop instructions and had to improvise and it was not easy.
06-28-2022, 11:16 AM | #95 | |
294
Rep 195
Holset274.00 Autoregression71.50 |
06-29-2022, 05:45 AM | #96 |
41
Rep 131
Currently my car shakes a little with the rpm fluctuations while idling, I don't know if your car does the same, will changing to stiffer mounts reduce the shake in cabin or make it even worse?
06-29-2022, 05:51 AM | #97 | ||
41
Rep 131
06-29-2022, 01:29 PM | #99 | |||
4140
Rep 7,160
07-02-2022, 10:45 PM | #101 |
4140
Rep 7,160
07-03-2022, 02:10 PM | #102 |
5234
Rep 10,616
I am on my iPhone 8 right now and the pdf can be downloaded/opened from the link at the end of the post and read. Maybe I have adobe on my phone?
07-04-2022, 04:15 PM | #103 |
4140
Rep 7,160
Hmm. Maybe I'm just retarded. Which post is it that has the pdf and I'll check again.
07-04-2022, 04:52 PM | #104 | |
294
Rep 195
07-05-2022, 09:22 PM | #106 |
4140
Rep 7,160
I think someone took pics back in the 1st or 2nd page trying to see if the CS was monoball like the rear is.
07-05-2022, 09:23 PM | #107 | ||
4140
Rep 7,160
07-06-2022, 03:51 PM | #109 |
4140
Rep 7,160
Sorry I attached a photo. But i didn't notice it didn't go through. Opened on my iPad. No pdf either. You sure it's attached to that specific post?
