10-20-2022, 09:26 PM | #23 |
91
Rep 74
im at -3.5 camber and im positive 295/30 will fit, i think -2.6 will be close.
10-20-2022, 09:29 PM | #24 | |
91
Rep 74
The Assist m4 is the build im trying to copy lol, that sunbeam f80 is what im talking about. That looks really good. I just ordered a bucket seat for my f80 cant wait to put it in |
10-27-2022, 08:18 AM | #25 |
91
Rep 74
Anyone have any suggestions to raise the seat cushion in the rear. Recaro suggest adding a 7mm + 6mm spacer to the rails to raise the entire seat. I already added a 7mm spacer. Or is a 20mm spacer on a m8 bolt safe? Didn't want to put such a big spacer under the slider.
I'm 5'10 and I have a nice view of my cluster when I'm all the way into the seat. This is the seat at the highest mounting points using the recaro rms rails. |
10-27-2022, 07:37 PM | #26 | |
1099
Rep 924
Seriously though, I'm kinda in your boat. At 6'0, my Cobra seats (the lowest position) are annoyingly low for street driving but perfect for the track days. I'm debating a removable insert cushion for occasional street driving. |
NYG10841.50 |
11-05-2022, 04:57 AM | #27 | |
52
Rep 559
01-16-2023, 08:27 AM | #29 |
91
Rep 74
Finally took the car to the track. Due to some “shop” that didn’t flush my oem fluid out properly. I lost brakes going 120. Had to
Bleed the old oem Fluid out the calipers and completely the flush. But by the 3rd lap I felt my brake pedal getting mushy and softer due to air getting into the system. I think maybe there’s air in the abs Modul now. I couldn’t really get a real feel for the car since my confidence was shot with the brakes. Still managed to drive 2 seconds faster then my pb in my tracked prep s2000. |
01-18-2023, 09:21 PM | #30 |
148
Rep 205
Drives: 14 F30 335i xDrive
That looks like Homestead. Fun track. But those barriers can be scary of the brakes aren’t 100.
02-03-2023, 10:58 AM | #31 |
91
Rep 74
Fabricating some custom brackets for this voltex swan neck I picked up. Probably not going to run it on the track. But I’ll run it eventually!
Also have a laptorr front lip coming in from Japan. Can’t wait |
03-01-2023, 09:45 AM | #35 |
91
Rep 74
Still having brake issues. Around 10 minutes on the track I’m experincing bad brake fade now. Not sure it’s because my rotors basically have zero life left on them. Im in the market for two piece rotors and will be adding brake ducts before the next event.
03-02-2023, 05:50 AM | #37 |
91
Rep 74
03-02-2023, 04:37 PM | #38 |
Rep 1
03-02-2023, 09:43 PM | #39 |
1887
Rep 2,400
you may need to do the dsc bleed procedure in order to get all of the air out. plus if you are running long tracks, consider the pfc07 rear. should shift a bit of brake torque to the rear, but not really a 'solution'. might as well just do an AP racing bbk with the way your build is going especially for long tracks.
03-02-2023, 11:23 PM | #40 |
293
Rep 625
I’m trying to avoid a bbk as long as possible. Currently running Girodisc rotors, ferro ds 1:11 pads, Castrol srf and titanium brake pad shims. So far so good
Planning on adding gt4 ducts. Also considering a set of titanium caliper pistons for the stock calipers. |
03-03-2023, 07:27 AM | #41 | |
1119
Rep 1,315
https://f80.bimmerpost.com/forums/sh...highlight=duct Probably a bit cheaper and less work to set up, might be a good first move and see if it suffices. |
03-03-2023, 08:26 AM | #42 | |
293
Rep 625
http://https://youtu.be/rPP2PZDQMyQ There is I a great video on YouTube that shows how to make the gt4 ducts functional. |
03-03-2023, 11:09 AM | #43 |
91
Rep 74
03-03-2023, 11:11 AM | #44 | |
91
Rep 74
Do the bleed procedure for me. He told me there was a lot of air in the system. But still had brake issues. Zero confidence in them after experiencing the fade |
