05-10-2021, 09:31 AM | #1 |
79
Rep 164
When using cruise control, does the M5 Brake or Coast?
When you use the gas pedal to overtake with cruise control on, does the car brake or coast to return to the set speed? (I hate using brakes esp. at night)
05-10-2021, 09:42 AM | #2 |
295
Rep 199
I’ve experienced both. It seems to depend on the difference between current and set speeds. If you’re fairly close to your set speed the car will coast. If you’re significantly higher than your set speed the brakes will be applied.
05-10-2021, 09:50 AM | #3 |
2284
Rep 3,307
and the brake lights light up.....tested that very question. Holds speed very precisely.
Mike
05-10-2021, 03:21 PM | #4 |
79
Rep 164
05-15-2021, 02:44 PM | #5 |
4152
Rep 7,167
Drives: F90 M5 / F15 50i
agree, that drives me nuts and makes me feel like an a hole.
'07 Yamaha R1 (sold)
asif16398.50 |
05-15-2021, 04:43 PM | #6 | |
721
Rep 786
Why would you feel like an a-hole with brake lights being activated when holding a speed? |
05-19-2021, 01:07 PM | #7 | |
Rep 23
People who need to check their brake pedal is still there every 45 seconds on the highway are the cause of congestion. It's a ripple effect. |
MysticBlue368.50 |
05-19-2021, 01:11 PM | #8 |
2612
Rep 2,685
Drives: '24 X7 M60i
Just don't use cruise control when overtaking people. Problem solved.
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
05-21-2021, 08:03 AM | #9 |
79
Rep 164
that would be annoying turning it off and on all the time, if people suddenly see brake lights on for no reason when youre flying down the highway, they think you are retarded, drunk or theres a cop ahead or even worse brake checking them
05-21-2021, 08:20 AM | #10 |
580
Rep 650
Active cruise control is designed to operate the car in a safe manner, with proper following distances that allow for adequate time for braking at the given speed.
The issue here is that typical drivers on the road do not know, understand or care what a safe following distance is. They will see the gap in front of your car and pull in front of you. The BMW sees a car in front at an unsafe distance and must slow down. Unfortunately, there is no solution for this. We can't control the behavior of other people. |
05-21-2021, 10:31 AM | #11 | |
79
Rep 164
