BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    rotor resurface
      07-12-2022, 01:36 PM   #1
jivom5
74
Drives: audi a7, c7 grandsport
rotor resurface
just curious has anyone attempted to resurface the f90 rotors before switching to new pads, mine are at 17k and have slight grooving on the fronts. i don't track the car nor do i take it to the back roads often.
      07-13-2022, 10:43 PM   #2
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Can be done but most shops don't like to turn drilled rotors for fear of cracking them.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      07-14-2022, 07:10 AM   #3
pbonsalb
5234
I would do it with just 17k miles. I have had drilled rotors turned before with no issue. Mine have 38k and I will just replace them in a couple of years when they will probably have 60k. I drive year round and find that drilled rotors holes fill with rust over time, reducing their efficiency.
      07-14-2022, 12:32 PM   #4
shawnhayes
1834
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
I've been dealing with the question for EONS.
Here's an OEM answer.
https://www.powerstop.com/resources/...-brake-rotors/
From my standpoint, if the brakes are working AS ADVERTISED, and stopping the car without ignorant levels of noise, do nothing. Absolutely nothing. Even if you change the pads (but only if they're worn out). Make sure the rotors meet minimum specs, but other than that, pad change only if they're worn.
NO ONE has EVER been able to prove me wrong on that. No study. No objective data. Nothing. It's all "well, that's what we've been doing since the beginning of time".
Shawn
      07-14-2022, 01:47 PM   #5
jivom5
74
Shawn
i appreciate the info, mine are currently screeching louder than a 18 wheeler. my last m4 had loud brakes but this is just obnoxiously loud that's why my question was asked.
      07-14-2022, 01:48 PM   #6
jivom5
74
got it thanks!
      07-14-2022, 01:50 PM   #7
jivom5
74
appreciate the info, mine arent rusting or anything as I'm in Cali, however the noise level is whats bothering me and occasionally the car takes a bit longer to stop at slow speeds i just assumed it was because they're slightly grooved.
      07-14-2022, 03:11 PM   #8
pbonsalb
5234
I would not resurface to try to stop squeaking. I’d have to feel the grooves. If they are really bad I would replace the rotors but I can’t imagine they could be badly grooved at 17k.
If the car really does take longer to stop, that wound be strange. Pad deposits on the rotor are an increasingly common problem since all the good stuff has been taken out of pads. I have read of people borrowing a set of race pads and driving with them for a day or two to clean the pad deposits off, but I have not done this myself. Most of these brakes squeak. You could try a few hard stops from 100 to 20 to see if that helps. I do those occasionally and it helps briefly but my normal lazy driving recreates the squeak before long.
      07-14-2022, 05:38 PM   #9
shawnhayes
1834
Good info. Under those circumstances can we get a picture of rotor and pad thickness?
Shawn
