BMW M5 F90 (2018+) General Forums Cosmetic Modifications    Autotechnik Front Lip issue
      06-01-2020, 04:58 PM   #23
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
Got a call from Autotecknik and they have gone the extra mile and sending a replacement free of charge. I did add betalink this time. Really happy with the outcome and 5 stars to them and Emnotek.
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
Appreciate 3
JRod1980391.50
MXNSITH198.50
r33_RGSport12971.00
      06-02-2020, 12:21 PM   #24
jko2001
36
Drives: 2019 M5 Comp
Great outcome. I’m a bit surprised they went that far given that they didn’t install it (at least that’s what I understand).
Appreciate 2
GTATX1105.00
r33_RGSport12971.00
      06-05-2020, 03:51 PM   #25
BMWDriverX
Drives: G12 750i X-Drive
That's really nice that they are sending you another one, based on your dirty bumper i think it was an installation error. I had the same lip and hit over 130mph multiple times and it never moved. I also can't believe in all the posts no one has mentioned the 3M adhesion promoter, that's the only way you are supposed to install anything to the body of your car when using the 3M double sided tape, I use it on both sides, on the lip before i apply the tape to it and then after cleaning the underside of the bumper right before installation i use the promoter on the bumper, that's how you are supposed to do it and I have never had anything come off.
      06-05-2020, 04:16 PM   #26
GTATX
GTATX's Avatar
Lip already had 3M on it. Also pic was taken after few hours of lip being flown off as I didn't even know it happened. This time I paid for beta link and that should help it become permanent part of the car.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      06-05-2020, 05:28 PM   #27
BMWDriverX
Yeah it's def not coming off with beta, still crazy to me that no one here mentioned the 3M adhesion promoter, makes all the difference when installing these types of parts to the body of the car.
      06-06-2020, 02:31 AM   #28
Burnsey
Just A Regular Guy
Burnsey's Avatar
320
Drives: G80 M3 Competition X-Drive
I don't think anyone mentioned it, as 3M tape on a lip isn't a secure fitting, so why bother mentioning it?
The carbon M-Performance side skirts are supplied with a strip of 3M, which is useful to secure in place whilst drilling, but that is it's single use.
Agree, use promoter if relying on 3M, but not on a front lip.
      06-06-2020, 09:25 AM   #29
MDJAK
82
Drives: 2020 M5
Do I need the promoter to install a cf trunk spoiler?
      06-06-2020, 01:23 PM   #30
Burnsey
Just A Regular Guy
Burnsey's Avatar
320
Yes, if using 3m tape.
Betalink doesn’t need tape, but the area should be thoroughly clean and the pack includes the correct solution.
      06-08-2020, 12:59 AM   #31
GTATX
GTATX's Avatar
I can attest with betalink lip is rock solid. Cleaned the area real good with provided fluid. Applied betalink thoroughly to the lip contact area and screwed everything in. Used clear packaging tape from under the lip to the bumper really tightly so no gaps until betalink dries. Left it like that for 3 hours and lip was attached to bumper like it was part of it.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      07-04-2020, 03:54 PM   #32
AbelM5
Drives: BMW M5
Welp, this is currently being installed on my comp as we speak, I didn't specify if they should use outside adhesives so hopefully it doesn't fly off after install. It's PFS here in Southern California so it should go well 🤷🏻
      07-06-2020, 05:28 PM   #33
YanoM5
505
Drives: 2018 Individual Nardo M5
Also waiting for my lip to come in. When using betalink, is the removal similar to 3M tape where you'd just need a heat gun? Haven't worked with the stuff before. I do know on a couple of my installs, side skirts and previous vehicles, I also grab the 30 pound one and most parts had supporting screws.
      07-06-2020, 05:48 PM   #34
GTATX
GTATX's Avatar
I think Betalink is pretty permanent.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
YanoM5504.50
      07-06-2020, 11:55 PM   #35
YanoM5
505
yikes...good to know as I may want to try some other lip down the road.
      07-30-2020, 01:59 PM   #36
Jocko78
104
Drives: M5 / X3 M40i
+1 Betalink holds on like there's no tomorrow, its essentially permanent unless you spend hours and hours slowly rubbing it off....had to do a few spots for my rear spoiler, brutal but doable.
      08-01-2020, 06:40 AM   #37
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Don't recommend betalink if you want to remove later. It can be done as you have to to remove the oem rear spoiler. You can get the part off easy enough with a heat gun and fishing line but the betalink will stay behind and then begins the fun part. Took me over an hour to get it all Off and then it left a bit of marring on the clear that needed paint correction. Now if you have a buffer it's much easier to remove. Ind has a video of a spoiler install and they got the stuff off pretty easy with it.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
