05-07-2014, 01:42 PM | #1 |
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1578
Rep 2,593
how to fix "sticky" buttons on console/dash
So my wife did something to our X3, she says its coffee, and the #1 and #2 buttons on the dash no longer work properly (hard to push in and then will not go back into place) and the traction control button on the center console also is sticky in that it pushes very slowly and doesn't really pop back (instead of the button press feel it should have).
I am guessing that the substance (lets say it was coffee) got behind the button and created a sticky situation behind the buttons. I am also guessing going to BMW to fix it will cost $$$ because of the labor involved to take apart both panels (and the center console might require a new aluminum piece since I think its glued down). Any suggestions on how to get rid of the sticky substance that is causing me headaches? |
05-07-2014, 02:22 PM | #2 |
7444
Rep 11,857
Drives: MY24 G01 AW Msport
trims are not glue and can be removed carefully
05-07-2014, 04:15 PM | #5 |
26
Rep 131
Did your wife really spill coffee on t or not? If she did then I'm sure the dealer will see the brown stains and feel the sticky remains and then charge you for it.
Otherwise if she didn't and you are honest with the dealer and have no idea why the buttons are sticking the will fix it under warranty. |
05-07-2014, 07:14 PM | #7 |
7
Rep 101
05-08-2014, 08:50 AM | #9 | |
Rep 109
I suggest looking up your car on realoem.com using the last 7 digits of your vin, look at how the parts fit together. The trim pieces are very easy to remove. You just need to take your time and be careful. You'll need a trim removal tool, which is sold in a 5 piece set, such as what you can find at harbor freight, a small screwdriver set, and a few thin towels to protect the plastic trim. The assembly the buttons are housed in is very easy to disassemble. There are small springs on the back of the buttons, so be careful when you get the back cover off. The coffee residue can then easily be cleaned from inside the button assembly. Good luck, and again take your time. |
05-09-2014, 04:25 AM | #11 | |
25
Rep 642
I used to be really into cars and things......then I just let it go. My car is still super clean.....but I no longer obsess over it and don't sweat the small stuff.....can't tell if it's all cars or just because I drive a diesel crossover.....but car ennui has set in at my house! |
05-09-2014, 08:47 AM | #12 | |
99
Rep 2,323
05-09-2014, 11:16 AM | #13 |
23
Rep 70
Rubbing alchohol on a paper towel, enough to ooze behind the buttons, maybe a lot to ooze behind the buttons. Push the buttons while things are wet. Test a small portion of out of the way plastic first to make sure it doesn't do bad things to it.
Non-Sport
All Options Except Lane Change Warning and Cold Weather II Car Name: Princess |
05-09-2014, 11:42 AM | #14 |
99
Rep 2,323
Thats a good idea, might want to try plastic safe contact cleaner at your local electronic store as well. It goes without saying, make sure your car is off while you are doing it.
05-09-2014, 12:09 PM | #15 | |
13
Rep 79
Use like a clorox wipe or baby wipe to try to clean the buttons. Otherwise you have no choice and you're going to need to open it up. I remember a classmate who spilled soda into her keyboard. Even after a good cleaning outside the key would crunch everytime you pressed it. Took the keyboard off used rubbing alcohol and no more crunching. Whenever I was over I would go straight to her computer just to press the key that crunched just for fun. |
05-10-2014, 11:23 AM | #16 |
Rep 85
I would try spraying some contact cleaner and then try moving the buttons.
I'm anal about keeping my car clean but not about people getting it dirty. My car is a tool not a museum piece. If you worry so much about it that you cant fully enjoy it go get a beater.
X3.5m | A4 Avant
05-10-2014, 11:26 AM | #17 |
99
Rep 2,323
05-11-2014, 12:15 AM | #18 |
Rep 85
I find it enjoyable to have a nice car that my family and friends can enjoy as much as I do without fretting the what ifs of getting it dirty. My milk spilling, cheerios eating 1 year old, active 6 year and coffee drinking wife are my witnesses.
X3.5m | A4 Avant
05-11-2014, 07:28 AM | #19 |
99
Rep 2,323
May I suggest a minivan then, I think Honda makes one with a build in vaccum
05-11-2014, 12:23 PM | #20 |
Ultimate Driving Machine!
170
Rep 274
05-11-2014, 12:25 PM | #21 |
170
Rep 274
I agree with you as well. Makes sense. Although I have no kids I think if I had kids I would be on the same level you are on.
05-11-2014, 05:43 PM | #22 | |
46
Rep 162
Do you have a stiff upper lip by any chance?
-Experienced driver; cocomats
