BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Drivetrain issue
      05-12-2020, 09:20 AM   #1
Akokar
16
Drives: M5
Drivetrain issue
Any suggestions what to do.
19 comp with secondary delete and jb4
      05-12-2020, 10:47 AM   #2
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
When I bought my car, it was sitting in the showroom and it was not attached to a battery tender. Once I left the dealers, this message popped up and car ran like shit. Went away on its own after 2 weeks and hasn't been back since. I've had the car at the dealers to get it checked and they found nothing.
Not sure if it's tune related but maybe my situation might help
      05-12-2020, 03:49 PM   #3
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
clear it on JB and see if it shows up again.
map 1
      05-12-2020, 03:58 PM   #4
A Need For Speed
A Need For Speed's Avatar
378
Drives: 2019 M5 Comp Nardo/Aragon
map 1
What map and octane are you using? Clear codes and send log to Terry.
      05-13-2020, 01:28 AM   #5
Akokar
16
Drives: M5
So was on map1 on 93 octane and night before launched it 4/5 times
Drove it back home was driving fine.
Started the car in morning and this sign was on but no check engine light. Turn it off n on 3/4 times and sign went away. Now driving fine i didn't push it though. Will check tomorrow will try to launch it again.
      05-13-2020, 05:02 PM   #6
Aronis
Aronis's Avatar
2270
Drives: 2018 M5
Did you do a scan for a more specific code? I had similar with a bad coil pack. Was an easy fix. I ended up buying a scanning tool. That reminds me I want to check for updates since the F90 was not on the list of that scan tool. LMAO.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      05-13-2020, 06:45 PM   #7
A Need For Speed
378
93 and Map 1 should be more than fine. You could likely do Map 2. Send logs to Terry at BMS. None better. He will take care of you.
      05-14-2020, 12:11 AM   #8
Akokar
16
Drives: M5
Man I m even scared from map1. When i launch it I think my tires were not warmed up. Car went side ways. Even in awd. Car has insane amount of power. But m goin to do some logs n send it to terry. Thanks.
