11-27-2019, 05:45 PM | #23 | |
516
Rep 382
11-29-2019, 10:01 AM | #24 |
Rep 28
You can add me to the list. Either it turns on and then immediately hesitates like it’s not getting enough fuel and then recovers normal idle RPM. Or it turns over and runs for a second and goes off. Happens every 10-15 times I drive. I wish BMW would issue a recall because I mentioned this to my dealer and they couldn’t diagnose it.
11-29-2019, 02:38 PM | #25 |
91
Rep 159
Just posting here as there are multiple threads on this and want to make it easy to see the volume of people experiencing the same issue.
https://f90.bimmerpost.com/forums/sh....php?t=1648197 |
11-30-2019, 09:57 PM | #26 |
340
Rep 536
I wonder if there is any connection to this issue and this other thread. Anyone else with both issues?
New M5 owners whine on startup question https://f90.bimmerpost.com/forums/sh....php?t=1663117 |
12-02-2019, 05:50 PM | #27 | |
///M
6651
Rep 3,683
Mine guess would be the fuel pump
Life is too short...enjoy your life
///M |
12-19-2019, 08:24 AM | #28 |
516
Rep 382
Welp, I finally gave up and took the car to the dealership. Of course the thing started fine every time for them. ¯\_(O_o)_/¯ Guess I am going to try the fuel cleaner mentioned above and see if that helps.
12-23-2019, 06:54 AM | #29 |
194
Rep 459
So this Lucas product helped alot....frequency dropped.....so will try some more plus another fuel injector cleaner by Lucas.....will report back.......regardless bmw needs to fix this defect
ambletx515.50 |
12-23-2019, 07:51 AM | #30 |
Rep 1
Had this happen to me about a year after use. 24K miles. I took it into service and they replaced the fuel pump saying the pressure was too low at the initial startup.
They installed a gauge to monitor the fuel pump pressure when it was stalling or dropping RPMs at startup, and found the pressure to be too low during those times through this method. They replaced the pump and monitored the pump pressure again and it was all good. I think you might be better off just having the pump replaced. |
12-23-2019, 09:06 AM | #31 |
516
Rep 382
I just wanted to give a quick update on my experience here so far with the Lucas lubricant. So after the dealership said they couldn't find anything I ordered this stuff (link above) off Amazon. I have run through 2 tanks of gas so far (using the Lucas lubricant in both tanks), and the car has not died on startup. The dealership even agreed that since they can't reproduce the problem that the Lucas lubricant was good stuff and worth trying.
12-23-2019, 09:21 AM | #32 | |
///M
6651
Rep 3,683
Fuel pump is most likely the problem. It was a issue from the gecko.
///M |
A Need For Speed377.50 |
12-23-2019, 01:07 PM | #33 |
516
Rep 382
12-23-2019, 05:56 PM | #34 | |
///M
6651
Rep 3,683
They can't fix it it's a lemon for you and get a new one
///M |
ambletx515.50 A Need For Speed377.50 |
12-24-2019, 06:55 AM | #35 |
200
Rep 327
Drives: BMW M5 Competiton
Location: Northwestern Switzerland veeeeery close to the German Autobahn
Just a general assumption/question... could it be shitty gas quality?
2019 - BMW M5C MY2019 (Individual Urban Green)
2016 - VW Passat B8 2.0 TSI (276 bhp) R-Line (sold) 2013 - BMW M135i xDrive 3.0 (316 bhp) (sold) 2010 - Mazda 3 MPS BL 2.3 (256 bhp) (sold) |
12-24-2019, 03:17 PM | #36 |
378
Rep 544
12-25-2019, 09:42 AM | #37 |
194
Rep 459
12-25-2019, 08:01 PM | #38 |
378
Rep 544
12-30-2019, 05:09 PM | #39 |
30
Rep 101
I had both high and low pumps replaced about 2 weeks ago and haven’t had issue since. Yet. Can’t say whether was low or high but the combo so far works.
12-30-2019, 06:03 PM | #40 |
194
Rep 459
Will be going to dealer soon.....wassy did they reproduce issue? If not they still went ahead with repairs? Not sure they will reproduce as it happens rarely
12-31-2019, 12:27 PM | #41 | |
30
Rep 101
For other issues but so far the starting issue seems solved. For now. |
12-31-2019, 12:43 PM | #42 |
378
Rep 544
Thought I was but no. They couldn't reproduce issue so will have to wait. Should be a recall on this as so many reporting it.
01-01-2020, 03:20 PM | #43 | |
///M
6651
Rep 3,683
That was coupe years ago, it was one of the first on the market.
///M |
