12-17-2018, 02:02 PM | #1 |
7
Rep 34
Car shut off after startup intermittently
So my car went in for its second service at approximately 5900 miles and dealership informed me of recall which they performed.
After picking up my car, it now sometimes shuts down right after I start it and shows no errors or faults. I took it back to dealership where they did a PUMA case and IRAP session to update software and was told that should fix the issue. I got the car back and its still doing it. I just left I at dealer again awaiting now to hear what they have to say regarding this... Has anyone else had this issue? |
12-17-2018, 07:17 PM | #4 |
255
Rep 255
Mine did it once. I now have 3700 miles on it, and that one time was a couple thousand miles ago. It looks like they performed the software update for you that was the recommended fix.
Keep us updated on what they find out. |
12-18-2018, 07:39 AM | #5 |
15
Rep 44
A few times now mine has died immediately after a cold start up, forcing me to start it again. Does yours do it only on cold startup or even when warm?
12-18-2018, 08:32 AM | #6 |
4067
Rep 5,231
I have not experienced this.
12-18-2018, 09:02 AM | #7 |
83
Rep 193
Ive had the same issue multiple times also.. About 10,500 miles on car as of now i would say it happened atleast 7 times since i got the car... literally right when you start the car it shuts off right away.
2014 Bmw M5 Singapore Grey (sold)
2014 Bmw M5 Frozen Blue (sold) 2016 Bmw M5 Sakhir Orange (sold) 2017 Bmw M6GC Frozen White (sold) 2018 Bmw F90 M5 Donington Grey (current) |
12-18-2018, 09:31 AM | #8 |
15
Rep 44
If all of these are from a cold start, it sounds like something off in the tune/calibration. Cold start generally has a different fuel requirement and it just feels like it's right on the edge of not enough fuel so it stumbles/dies. I've heard mine stumble/miss quite a bit more than it has died.
12-18-2018, 10:49 AM | #9 |
255
Rep 255
My one experience differed slightly, because the car was still very warm, due to its having been only off for about 20 minutes on a warm day. It sounded like a normal start for 2 or 3 seconds, then stumbled and died. Fuel starvation went through my mind at the time. So far its never exhibited a problem on a cold start.
12-18-2018, 01:34 PM | #10 |
7
Rep 34
To clarify it does not happen at cold start. Usually happens after car has been driven and sits for about an hour...
So dealer just informed me it seems that the car is losing fuel pressure. Awaiting to hear from TSE to see what will be done to mitigate issue. |
12-18-2018, 06:43 PM | #11 |
7
Rep 34
Confirmed that it's a fuel pump issue and they need to replace fuel pump. Was told pump is on back order and will take about 15 business days to arrive from Germany
12-21-2018, 03:38 PM | #12 |
1691
Rep 2,699
Drives: 23 X5MC
02-10-2020, 12:01 PM | #13 |
85
Rep 42
I am having this exact same problem. It happens on cold start, once every 15-20 starts. I'm taking it to the dealer tomorrow for evaluation. OP, did the new fuel pump resolve the issue?
Current: 997.1 Turbo 6 speed manual | '16 McLaren 570S | F90 M5
Past: B5 S4 6 speed manual | C7 S6 | '17 718 Cayman |
02-10-2020, 04:29 PM | #14 |
37
Rep 56
Drives: 2018 M5
There have been other threads discussing this. I have it happen to me every 10 or so "lukewarm" starts. Was able to take video of it, but the dealer was unable to find any problems. I told them that others on the forum had fuel pumps replaced, but as of now they are unwilling to do anything until it is replicable by them.
02-10-2020, 06:00 PM | #15 | |
392
Rep 279
02-11-2020, 08:35 AM | #16 |
Twisted Fister
30
Rep 58
I had this early on as well, and they replaced fuel pumps. Has not happened since. do a search in this forum and you will see the threads on it.
03-30-2020, 04:34 PM | #17 |
85
Rep 42
I took my '18 M5 into dealer. They ran some pressure tests on the high and low pressure fuel pumps. They found critically low pressure from the low pressure pump on startup. They replaced the low pressure pump and left the high pressure as is. Apparently after the change they retested the pressure and it was within constraints. Thus far around 1 month out I haven't had the problem recur. Note that they didn't need to recreate the stalling problem itself (fortunately).
04-04-2020, 05:02 PM | #18 | |
194
Rep 459
